DCX2496 output configuration? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-11-2008, 07:45 PM - Thread Starter
04FLHRCI's Avatar
Gentlemen,
I've read the manual and messed with the GUI; do I have the proper understanding here? May each of the six output channels be configured to accomodate any desired band (L/M/H)? For instance, if I were to install six subs in my room, three across the front and three across the rear; would the DCX2496 allow me to adjust each sub independently?
I have my three subs finished for the front and will likely not expand upon this until mid 2009; however, having the ability to do so without adding additional hardware would be nice.
Larry
04FLHRCI is offline
post #2 of 6 Old 12-12-2008, 04:36 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Yes The DCX2496 will alow you to have differant settings for each of the 6 outputs....
Cheers....
cinema mad is offline
post #3 of 6 Old 12-14-2008, 06:29 AM
penngray's Avatar
Liked: 52
I use the DCX with 2 3-way speakers so yes you could have ONE input sent to 6 different channels and you can set each of those channels independantly.
penngray is offline
post #4 of 6 Old 12-14-2008, 08:07 AM - Thread Starter
04FLHRCI's Avatar
Thanks for the confirmation guys; I ordered a unit yesterday and will browse the shack to assess what's needed for REW.
Larry
04FLHRCI is offline
post #5 of 6 Old 01-03-2009, 09:46 AM
cptomes's Avatar
Larry
Might as well order a spool of the Dayton balanced cable, six of the XLRs used for the outputs, an RCA and one of the XLRs for the input. Have fun soldering!
cptomes is offline
post #6 of 6 Old 01-04-2009, 11:13 AM - Thread Starter
04FLHRCI's Avatar
Cabling isn't necessary - my system is already utilizing all XLR via BJC.
I spent $12 at RadioShack on two adapters and was playing around with it last night - really great device.
Larry
btw - routing the outputs worked exactly as I desired.
04FLHRCI is offline
