Frequency Graph of Songs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-11-2009, 06:40 AM - Thread Starter
vili's Avatar
Just curious if there is a program or anything that I can use to basically see a frequency graph of songs. Preferably something easy to use...ie I can have a song in itunes and it will show a graph of all of the notes. Just want to be able to equate what a note sounds like and what it actually is. I tried to google for a program, but nothing came up.
vili is offline
post #2 of 10 Old 05-11-2009, 08:34 AM
brandonnash's Avatar
Liked: 34
Looking for waterfall graphs? I don't know if the one most people use for movies will work for music too. Don't see why it wouldn't.
brandonnash is offline
post #3 of 10 Old 05-11-2009, 08:40 AM - Thread Starter
vili's Avatar
Just looking for something so I can correlate what I hear to an actual number.
Like at the GTG, Ricci said a certain track had a 14hz note...how does he know that?
vili is offline
post #4 of 10 Old 05-11-2009, 08:58 AM
penngray's Avatar
Liked: 52
Is called Spectrum Lab.
http://freenet-homepage.de/dl4yhf/spectra1.html
This link explains everything you need to know. Its done for movies but music would be the same.
https://www.avsforum.com/avs-vb/showthread.php?t=755493
penngray is offline
post #5 of 10 Old 05-11-2009, 08:58 AM
penngray's Avatar
Liked: 52
Because he measured it
penngray is offline
post #6 of 10 Old 05-11-2009, 09:14 AM - Thread Starter
vili's Avatar
Thank you sir, I'll try to figure out how to use this software.
vili is offline
post #7 of 10 Old 05-11-2009, 09:17 AM
penngray's Avatar
Liked: 52
The links above has lots of info and should help you get everything working.
penngray is offline
post #8 of 10 Old 05-11-2009, 09:17 AM
Liked: 34
The bass I love you track has a 16 hz tone that's recorded pretty hot. It also has a 7 or 8 directly after it that's not quite as loud. Don't know if that's the one you are talking about or not.
post #9 of 10 Old 05-11-2009, 09:19 AM - Thread Starter
vili's Avatar
Yeah, that's the one...I thought it was 14hz for some reason.
vili is offline
post #10 of 10 Old 05-11-2009, 03:01 PM
tvrgeek's Avatar
Quoted: 18 Post(s)
Liked: 33
Search the WEB for SONOGRAPH. Spectrogram, spectrascope and so on.
I also use an RTA to take a look at a ingest of an LP that I want to clean up for transfer to CD. You can spot table rumble, deck rumble, about where it could be rolled off top and bottom, and with some experience a sense of "tilt". Than with tools like GOLDWAVE, you can clean things up.
tvrgeek is offline
