How many woofers does a center channel really need? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 02-01-2010, 04:12 PM - Thread Starter
TSD444's Avatar
Why do center channel speakers typically have two mids and a tweeter? I'm new to all of this, but I'm planning on building speakers to go under my projection screen and I'm wondering if a single woofer and a tweeter would work ok.
TSD444 is offline
post #2 of 48 Old 02-01-2010, 04:27 PM
Kal Rubinson's Avatar
Quoted: 1427 Post(s)
Liked: 1389
Because they look like they would have a wide dispersion and because a single larger woofer would not fit into a slim horizontal cabinet. Single woofer/tweeter would work best if oriented vertically.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 48 Old 02-01-2010, 04:52 PM
DL86's Avatar
Two or more woofers oriented horizontally is not good at all as this article will demonstrate :
http://www.audioholics.com/education...peaker-designs
To improve the black level performance of your projector: Shine bright light into your eyes every 5 minutes.
DL86 is offline
post #4 of 48 Old 02-01-2010, 05:04 PM
Bill Fitzmaurice's Avatar
Liked: 5783
Close, no cigar. Drivers can be successfully arrayed horizontally so long as they're crossed over to the next element low enough so that they mutually couple throughout their bandwidth without combing. The disadvantage is that a wider source has narrower dispersion. OTOH two smaller woofers can give the same output as one larger driver in a lower profile cab, and that can be an advantage. So it boils down to the usual question of where your priorities lie and where you're willing to compromise to achieve them.
Bill Fitzmaurice is offline
post #5 of 48 Old 02-01-2010, 05:58 PM
Gene DellaSala's Avatar
Quoted: 66 Post(s)
Liked: 59
I encourage readers to check out the article I authored that counters our original article Horizontal vs Vertical center channels referenced here.
http://www.audioholics.com/education...hannel-speaker
Best Regards;
Gene DellaSala (GDS)
President, Audioholics.com
Gene DellaSala is offline
post #6 of 48 Old 02-01-2010, 06:34 PM
kbgl's Avatar
I have a vertical 10" 3-way for a center. I have also used 2-ways with various size woofers.
kbgl is offline
post #7 of 48 Old 02-03-2010, 07:07 PM
dbldare's Avatar
Kinda like this?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #8 of 48 Old 02-03-2010, 07:20 PM
snickel's Avatar
I am making that but with 12 tweeters.
snickel is offline
post #9 of 48 Old 02-03-2010, 07:31 PM
Liked: 5783
Kinda like this?
dbl
Actually, no. With a horizontal line array the situation is quite different than a MTM or WMTMW.
They're not crossed over to the tweeters low enough so that there's no response lobing. Instead the concave baffle reduces the size of the holes between the lobes to render them inaudible. It's not perfect, but if you want line array sensitivity in a horizontal box it's a far better alternative to a flat baffle.
post #10 of 48 Old 02-03-2010, 08:02 PM
stgdz's Avatar
Modern media is really I mean really demanding of the center channel, if you ever have the chance disconnect or turn down the fronts and the surrounds to see how much goes through the center channel. Try it on the fronts and turn the center down. All music and some effects go through the fronts with very little dialogue. The center carries all of the dialogue and a suprising amount of effects from what I played around with.
stgdz is offline
post #11 of 48 Old 02-04-2010, 01:44 AM
Drew Eckhardt's Avatar
Unfortunately perceived timbre comes from both direct sound (where people aren't far enough into a lobe to have problems) and early reflections where human perception takes into account that attenuation goes with delays (IOW, a low level signal with a longer delay is given more weight).
While listeners are not far enough off-axis to cause problems with the direct sound, even a centrally seated listener will have a significant notch from the side-wall reflections due to the path length differences to the two mid-bass drivers in their pass-band (although the cross-over frequency itself will be wonderful with odd order filters as in a D'Appolito array). The effect is somewhat analogous to a phantom center image from two speakers sounding darker in the center seat than off-axis or a physical center speaker.
I don't hear accurate sound from vertical MTM arrays with conventional cross-over frequencies and would correlate that with research showing the ceiling/floor first reflections to be important for timbre as well.
I'd encourage readers to check out Floyd Toole's book
_Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms_
http://www.amazon.com/Sound-Reproduc.../dp/0240520092
Drew Eckhardt is offline
post #12 of 48 Old 02-04-2010, 01:56 AM
LTD02's Avatar
Quoted: 3003 Post(s)
Liked: 3765
random opinion fwiw...forget the center channel, use good mains with controlled directivity and phantom center. alternatively, get acoustically transparent screen and put a very capable center behind it.
Listen. It's All Good.
LTD02 is offline
post #13 of 48 Old 02-04-2010, 04:38 AM
lennon_68's Avatar
Well, that book is certainly well-reviewed! The top three (all 5-start) reviews on amazon.com are listed as being from Siegfried Linkwitz, Paul Scarpelli, and Kevin Haskins
lennon_68 is offline
post #14 of 48 Old 02-04-2010, 07:52 AM
Looneybomber's Avatar
Liked: 29
To answer your question, how many woofers does a center channel really need? They need just as many as your L/R's because they should match.
YID DIY
Looneybomber is offline
post #15 of 48 Old 02-04-2010, 08:31 AM
Genelec Man's Avatar
Quoted: 13 Post(s)
No shortage of woofers here.
Genelec Man is offline
post #16 of 48 Old 02-04-2010, 10:46 AM
noah katz's Avatar
Quoted: 2368 Post(s)
Liked: 863
"forget the center channel, use good mains with controlled directivity and phantom center. alternatively, get acoustically transparent screen and put a very capable center behind it."
Exactly what I was going to do, but it turns out Audyssey strongly recommends against it when using DSX height speakers because some center information will end up there.
Noah
noah katz is offline
post #17 of 48 Old 02-04-2010, 10:56 AM
stgdz's Avatar
It wouldn't surprise me but is that some ones home theater? The white door looks like a home install.
stgdz is offline
post #18 of 48 Old 02-04-2010, 10:58 AM
zamboniman's Avatar
Only problem with this approach is that the dolby digital spec has you handcuffed. Meaning that some level of dynamic compression will be enabled when choosing no for the center. There is no indication of this and from what I have seen no way to get around it.
zamboniman is offline
post #19 of 48 Old 02-04-2010, 12:26 PM
Quoted: 13 Post(s)
It is a "private screening room". From the looks of it I would guess it's in a home! Unbelievable. Those speakers are the newest QSC cinema speakers. The subs are a 21" design. The projector isn't normal for home either.
post #20 of 48 Old 02-04-2010, 12:38 PM
Quoted: 13 Post(s)
better pics. The mains use a 10" midrange. 21" subs are the latest B&C drive units. BTW the best approach for a center is to utilize the same as your L&R no matter what type it is.
post #21 of 48 Old 02-04-2010, 02:11 PM
Split the signal in the analog domain.
I'd use two dual channel op-amps. Each channel would get an inverting summing stage with -3dB gain input for "center" and 0dB input for left or right followed by an inverting unity gain buffer.
post #22 of 48 Old 02-04-2010, 03:11 PM
Liked: 5783
No matter what the digital spec is using L/R only will never duplicate the imaging of L/C/R. I can't imagine going back to a 4.1.
post #23 of 48 Old 02-04-2010, 04:43 PM
tvrgeek's Avatar
Quoted: 18 Post(s)
Liked: 33
I am about to toss the entire 5.1 out and go back to stereo full-range tri-amped for everything. I guess I care for music quality over special effects.
I will admit, if you sit far off-center, then the center fill will help the sound placement on the screen. I don't have that problem sitting between the mains. My MTM center actually stands on end under the TV. As I did not build this speaker, I can not say if it was constructed to DeApollito design, or is just thrown in the box. I suspect the latter as it does not control the dispersion that much either way. Speakers built to his technique can clearly be heard by moving around them in both positions.
tvrgeek is offline
post #24 of 48 Old 02-04-2010, 05:00 PM
vantagesc's Avatar
Liked: 37
Can you describe this in more detail?
Which is worse, a center that is below the screen or L/R? I might agree with you in an ideal setup, but most people's home situation is far from ideal.
vantagesc is offline
post #25 of 48 Old 02-04-2010, 05:16 PM
Perpendicular's Avatar
Quoted: 307 Post(s)
Liked: 146
That's Bill Gate's new Home Theater room.
Perpendicular is offline
post #26 of 48 Old 02-04-2010, 05:27 PM
stgdz's Avatar
Yeah if I ever had a "private screening room" I would want the screen as big as possible so I can view as many naughty movies as possible
stgdz is offline
post #27 of 48 Old 02-04-2010, 07:53 PM
Liked: 5783
A center below the screen is fine, assuming you're listening from more than four feet out. Your brain will still place the source at the center of the screen because it's hard wired for visual location cues to over-ride audio triangulation. To some extent that will happen with L/R too, but the L/R sources never 'disappear'.
Just turn off the decoding when listening to music. I never watch TV in stereo and I never listen to music in 5.1, because video sound tracks are mastered in x.1, music is mastered in stereo.
post #28 of 48 Old 02-04-2010, 08:16 PM
Liked: 1389
Most is but not all. I listen to multichannel music, recorded and mastered in multichannel, about 40% of the time.
Kal Rubinson
post #29 of 48 Old 02-04-2010, 08:35 PM
LTD02's Avatar
Liked: 3765
"Exactly what I was going to do, but it turns out Audyssey strongly recommends against it when using DSX height speakers because some center information will end up there."
noah, you are pushing for diminishing returns--not that that is a bad thing, just way beyond the question in the op. i'm curious to see what you choose.
"I am about to toss the entire 5.1 out and go back to stereo full-range tri-amped for everything. I guess I care for music quality over special effects."
tvr, a good compromise might be to go with awesome stereo speakers and then add a pair of side mounted thx-style bipole speakers to add ambience by providing diffuse reflected sound off of the front and rear walls for movies.
(for example: http://www.jblsynthesis.com/products...=US&Region=USA)
LTD02 is offline
post #30 of 48 Old 02-04-2010, 10:00 PM
vantagesc's Avatar
Liked: 37
I have not found this to be the case in my experience. For a one person theater, I prefer a center behind an AT screen or no center. Can't even tell my L/R speakers are playing when there is only dialog "on screen". Again, this is only for a one person theater. Maybe I need to let my brain go and just concentrate on the movie. Edit: I will add that I can envision certain setups where the center channel is close enough to the center of the screen where you would be okay, especially if the screen is small. The added intelligibility that a center could offer may be worth the tradeoff that I perceive.
YMMV.
