Crown CE-1000 Compression? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-27-2011, 12:54 PM - Thread Starter
zhillsguy's Avatar
I am looking at getting a Crown CE-1000 amp for sub duty........is this anything to be concerned about (from the CE manual), or is it simply a limiter?
4.1.5 Compression
A full-time compressor is in-line with the signal,
reducing the risk of damage to your speakers.
zhillsguy is offline
post #2 of 9 Old 01-27-2011, 02:41 PM
michael hurd's Avatar
Quoted: 639 Post(s)
Liked: 692
Honestly I would pass on the CE-1000 or CE-2000 for sub duty, these are in no way related to the CE-4000. ( BCA, PFC )
Google CE 1000 or CE 2000 problems.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #3 of 9 Old 01-27-2011, 05:43 PM - Thread Starter
zhillsguy's Avatar
Thanks Michael..........I think I will stick with good ol' reliable EP2500/4000's (I have two here)......I was just looking for something different. Every time a find a used pro amp (QSC, Crown, Crest, Samson, etc.) on CList, they are usually beat to hell, and the price/performance ratio keeps me coming back to the EP series.
post #4 of 9 Old 01-28-2011, 04:57 PM
Drisco Z71's Avatar
So if I found a ce2000 on craigslist for $400obo you guys would recommend that I wait for an ep2500/ep4000 to come along instead?
Drisco Z71 is offline
post #5 of 9 Old 01-28-2011, 05:13 PM
Quoted: 639 Post(s)
Liked: 692
Yes.
post #6 of 9 Old 01-28-2011, 05:58 PM
Drisco Z71's Avatar
There is also a crown xti 2000 on craigslist for 500obo, is that a good deal or no?
post #7 of 9 Old 01-28-2011, 06:00 PM
jpmst3's Avatar
Quoted: 200 Post(s)
Liked: 316
Skip it and get the EP4000, much better bang for the buck.
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #8 of 9 Old 01-28-2011, 06:27 PM
kouack's Avatar
I guess you should stop looking at craig list and more at flea bay they are cheaper just under 400 for a B stock with warranty.
Warning to prevent risk of injuries, you should always be smarter than the equipment you are about to use.
kouack is online now
post #9 of 9 Old 01-28-2011, 06:38 PM
tsloms's Avatar
Quoted: 67 Post(s)
Liked: 64
I bought a pair of XTI2000's locally for $750 brand new with warranty. Compared to an EP2500 they are a much more versatile amp with the built in DSP. Built in limiters, XO's, EQ. Also the fan is much, much quieter than the EP2500 which I also own.
tsloms is offline
