Beware of Monoprice Cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 67 Old 03-18-2011, 10:06 PM - Thread Starter
zhillsguy's Avatar
Just as a heads up...........
I just purchased on of these adapters to connect a qsc pro amp to my AVR. Initially I got no sound. Using a VOM I found xlr pins 2 and 3 were both connected to the RCA center pin.....say what?
Since it was my initial time using the qsc, although disappointed with Monoprice, it was a relief to find the problem, and doing the fix was easy in the xlr plug. However, for a typical user it may not be so. This is my first issue with any Monoprice items. Though I can't get the parts for what they are selling the assembly for, I can only hope for better quality control from them.
zhillsguy is offline
post #2 of 67 Old 03-18-2011, 10:12 PM
Looneybomber's Avatar
Liked: 29
I have two of those and both work fine. Maybe you're just lucky
YID DIY
Looneybomber is offline
post #3 of 67 Old 03-18-2011, 10:13 PM
LTD02's Avatar
Quoted: 2992 Post(s)
Liked: 3731
what did they say when you contacted them about this?
Listen. It's All Good.
LTD02 is offline
post #4 of 67 Old 03-18-2011, 10:18 PM - Thread Starter
zhillsguy's Avatar
Haven't contacted them yet.....but left a negative review.
post #5 of 67 Old 03-18-2011, 10:21 PM
wormraper's Avatar
Quoted: 401 Post(s)
Liked: 246
I would have contacted them first. sounds like a mistake that got through. I've gotten tons of cables from them and so have a lot of others around here and on other forums. the is the first I've heard of something like that. Personally i'd see how they take care of you before leaving a negative review
wormraper is online now
post #6 of 67 Old 03-18-2011, 10:23 PM
MANTI5's Avatar
I would think contacting them should come before a negative review. They are one of the most respected companies around and I'm sure they would've made it right.
MANTI5 is offline
post #7 of 67 Old 03-18-2011, 10:39 PM - Thread Starter
zhillsguy's Avatar
How can you say not to leave a negative review? Did it work properly? What if I didn't have the capability to troubleshoot and repair? Where would I be now? Paying a tech to troubleshoot my home theater equipment since new cables are not suspect? I feel constructive negative reviews serve the same purpose as my post here.....a heads up. I read all reviews on products and make my buying decision afterward. The review on mp was similar to my first post here as a warning to others. I am still a loyal monoprice customer and will contact them next week, and I am sure they will "make it right".
post #8 of 67 Old 03-18-2011, 10:51 PM
LINEARX's Avatar
Your current review has NO information for other consumers regarding the companies replacement program and no info on whether or not they will give free replacement or refund.
You did it backwords.
Call first, write review second.
LINEARX is offline
post #9 of 67 Old 03-18-2011, 11:02 PM
LTD02's Avatar
Liked: 3731
a few years back, i bought a component vid cable from them for a song and it worked great. annecdotes are unreliable.
LTD02 is offline
post #10 of 67 Old 03-18-2011, 11:10 PM
MrBobb's Avatar
Quoted: 230 Post(s)
Liked: 107
Once I found a MONSTER CABLE (not less) to be unsoldered. THERE!
Don't automatically assume it's a conspiracy. Lots of these things are still hand-made by Chinese cheap labor.
MrBobb is online now
post #11 of 67 Old 03-18-2011, 11:48 PM
Kanaris's Avatar
All my cables are from Monoprice... no problems at all.
Kanaris is offline
post #12 of 67 Old 03-18-2011, 11:56 PM
N8DOGG's Avatar
Quoted: 1354 Post(s)
Liked: 1600
I have over $400 in monoprice cables and have not had a problem with anything.
N8DOGG is offline
post #13 of 67 Old 03-19-2011, 12:08 AM
notnyt's Avatar
Quoted: 3849 Post(s)
Liked: 3789
Same. Running two monoprice rca to xlr here as well as other hdmi cables and stuff
notnyt is offline
post #14 of 67 Old 03-19-2011, 12:09 AM
CZ Eddie's Avatar
Quoted: 108 Post(s)
Liked: 50
Seriously?! Don't you think you're being a little dramatic with the thread title?
I can understand cautioning others about a particular connector purchased from the company. But it's not like Monoprice actually makes the connectors. They just slap their name on all kinds of 3rd party stuff and call it their own.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #15 of 67 Old 03-19-2011, 12:43 AM
Natedog51's Avatar
To expect products to have 0% failure rate is naive. Any educated consumer would have known this and contacted the company and based their review on the total buying experience (product, customer service, etc..) after contacting the company and seeing what their resolution to the problem was.
You are also right in the fact that had you not been able to diagnose the problem yourself, you would have had to hire a technician (or had the pro amp RMAed) but you need to realize that by saving some money and not having a professional hook up your equipment (that you bought from them) you assume those risks. It's part of the Do It Yourself culture of any industry. You can save money by ordering/buying all of your parts/equipment at the best prices possible and then hooking it all up yourself and having to diagnose (or pay someone to diagnose) any problems that arise; Or you can go to a brick and mortar store and have them do everything and not have to worry about any of those problems, but pay about twice as much compared to the other option. It's all about the risk/reward.
I've got some stuff...but I need more stuff.
Natedog51 is offline
post #16 of 67 Old 03-19-2011, 01:00 AM
Woodfiend's Avatar
I appreciate the heads up and letting us know about your experience. I have ordered cables from them in the past with no trouble (sorry to hear about your bad luck).................... I also just used your link and actually ordered some more cables I need............... Oh the irony.
Woodfiend is offline
post #17 of 67 Old 03-19-2011, 01:08 AM
Danielson99's Avatar
Quoted: 86 Post(s)
Liked: 73
I suppose it's good you did post your thoughts here. It really confirmed that the majority of people have had nothing but satisfaction dealing with Monoprice. You can include me in that list of satisfied owners of their products. One thing I won't do is 'beware' of Monoprice, they are very established as reputable dealer of affordable cabling. Better quality control?? Puhlease...
Danielson99 is offline
post #18 of 67 Old 03-19-2011, 02:00 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5117
I'm going to go order a Monoprice cable now, thank you!
Just cuz.
Scott Simonian is offline
post #19 of 67 Old 03-19-2011, 04:37 AM
MX48's Avatar
Quoted: 98 Post(s)
Liked: 56
Had a couple of 35 foot HDMI cables go bad. Sent them an email, get an RA number back, sent the cables back and 2 new ones were returned a week or so later. Painless except for having to send the bad ones back.
Moto
MX48 is online now
post #20 of 67 Old 03-19-2011, 04:55 AM
tundrSQ's Avatar
Just cuz.
great post...i like where your head is at...
Tim
tundrSQ is offline
post #21 of 67 Old 03-19-2011, 05:33 AM
flyng_fool's Avatar
Quoted: 190 Post(s)
Liked: 172
My Monoprice cables are great too. No problems whatsoever. I agree that you did it backwards. I guess some people love to complain and are impossible to please.
Television: Vizio E70iA3
Processor: Emotiva MC700
Surrounds: AT 2200 LR Sub: Danley DTS-10Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #22 of 67 Old 03-19-2011, 05:39 AM
kgveteran's Avatar
Quoted: 803 Post(s)
Liked: 238
Moto
I sent mine to a three month program, and they no longer smoke crack or stay out late. When cables go bad, you have to be firm and offer solutions...
Ok, only kidding
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #23 of 67 Old 03-19-2011, 05:48 AM
Quoted: 6016 Post(s)
Liked: 5596
I bought a Maytag washer a while back and on the first load of wash the motor started smoking. Long story short ONE wire was connected to the wrong post in a 20 plus wiring harness assembly. It happens, workers screw up all the time, should it have been caught by QC?, yes. I have a pile of monoprice cables in my theater with ZERO defects.
post #24 of 67 Old 03-19-2011, 05:49 AM
youngho's Avatar
Quoted: 18 Post(s)
Liked: 31
Beware of Zhillsguy
youngho is offline
post #25 of 67 Old 03-19-2011, 05:51 AM
MX48's Avatar
Quoted: 98 Post(s)
Liked: 56
"I sent mine to a three month program, and they no longer smoke crack or stay out late. When cables go bad, you have to be firm and offer solutions..."
Not being a parent I made the assumption they were hopeless. My friends that are parents sometimes wish they could do the trade-in for defective products .
Said they enjoyed the manufacturing process tho.
MX48 is online now
post #26 of 67 Old 03-19-2011, 05:52 AM
kouack's Avatar
Beware of Ford,GM,Toyota,Dodge,Bryston,QSC,Crown,Nad,Harman Kardon,Yamaha,Kawasaki,Honda,Jeep,Naim,Jbl,Peavey,Electrovoi ce, someone had a problem with one of them i'm 100 % sure, dude change the tittle you are so full of it.
Warning to prevent risk of injuries, you should always be smarter than the equipment you are about to use.
kouack is offline
post #27 of 67 Old 03-19-2011, 06:02 AM
pbc
pbc's Avatar
Quoted: 441 Post(s)
Liked: 217
I use the same cables with my QSC, haven't measured them, but assume there are no issues as they appear to work fine.
I have had problems with their HDMI cables though, I now have 2 that have failed on me, one of which was run behind the wall from my plasma which was a PIA to change.
But overall for the money they can't be beat IMO.
My DIY Subs ... https://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #28 of 67 Old 03-19-2011, 07:07 AM
penngray's Avatar
Liked: 52
If the OP contacted Monoprice, they would have fixed the problem and this thread would not exist.
To find a problem and just give a negative review is crazy??? I hope the OP runs a perfect life and runs a perfect business because I wonder if he would like his customers to do the same thing???
Customer service DESERVES alteast a chance to fix ANY problem.
Monoprice replaced my 30ft HDMI cable after 3 months of usage (the end broke off). Monoprice has great customer service and low cost 100% garuntee on working products.
penngray is offline
post #29 of 67 Old 03-19-2011, 07:22 AM
whoaru99's Avatar
Liked: 71
I think the OP has been sufficiently beaten down for the transgression.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #30 of 67 Old 03-19-2011, 07:26 AM - Thread Starter
zhillsguy's Avatar
My apologies to all who got their feathers ruffled.....I agree my title and post could have been different, and the post itself may have served better in another forum. Most folks here would have troubleshooted and repaired like I did......but I stand behind my actions, I am still a loyal Monoprice customer, and recommend purchasing from them.....nuff said.
