Is my box creating a null?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-10-2011, 04:47 PM - Thread Starter
tgse3's Avatar
I just completed a box with two custom built PSI 18's from 13av.2 motors. The box is 91" H x 24" W x 13" D. I have 110db+ from 10hz-55hz but then drop down to 80db from 55hz-90hz. Should I stuff the cab with polyfil to break up standing waves or come up with a different idea? Or could the subs be the problem and not the box?
tgse3 is offline
post #2 of 4 Old 06-10-2011, 04:58 PM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2230
Is the sub at the "end" of the enclosure. 91" puts the centre of the sub about 2m from the bottom. That's close to the half wavelength of 90hz. It's quite possible. Stuffing the cab would likely help.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #3 of 4 Old 06-10-2011, 07:06 PM
Bill Fitzmaurice's Avatar
Liked: 5776
Picture worth thousand words. If you have the drivers too far apart that would be a problem, one that stuffing won't fix. Can't say for sure without seeing it. The room/placement could also be an issue.
Bill Fitzmaurice is offline
post #4 of 4 Old 06-10-2011, 07:56 PM
Liked: 2230
Correction, if it's in the middle of the box it would be a half wave.
