AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   DIY Speakers and Subs (https://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Help designing Isobaric Sub Box (https://www.avsforum.com/forum/155-diy-speakers-subs/1344460-help-designing-isobaric-sub-box.html)
zordac 06-29-2011 01:57 PM
2 Attachment(s)
A couple years ago, I purchased several subs and two amps. I started building some large enclosure ported subs but my significant other did not approve.
So, now I am hoping to build something smaller.
Subs: 6 x NHT NPT-11-075-2
Amps: 2 x MCM 50-6262
I have included specs for both of these as attachments. In playing around with box designs in WinISD and with suggestions from other users I have decided to try my hand at an isobaric system. Space is a real problem for me.
WinISD says that if I put three pairs of my subs in an isobaric EBS3 configuration I would need an 8.8 cf box.
In theory this would be tuned to 16.5hz with 118db @ 20hz.
Problem is, I have no idea how to design this box. Any help is appreciated.
NHT NPT-11-075-2.zip 0.7080078125k . file
MCM-50-6262.pdf 126.439453125k . file
zordac 06-30-2011 02:40 PM
Ok, so I spent some time in Google sketch up. I put together what I think is the start for a design.
What I am confused about is if the sub sets should be isolated from each other as I have them drawn here. Or, should the cavity between the front three and the back three be open?
Also, my current plan is to power the front three with one amp and power the back three with the second amp.
Thanks in advance for any help.
noah katz 06-30-2011 04:47 PM
I used to be enamored of Isobarik, but now I just think it's a waste of power, since the extra volume required to fit the 2nd driver prevents realizing the supposed half volume.
schan1269 06-30-2011 05:17 PM
The first problem with your design is you have a port. That totally destroys the entire reason to have subs "stacked" on each other. Remove the port and you'll get the desired result.
noah katz 06-30-2011 06:04 PM
Why's that?
schan1269 06-30-2011 06:37 PM
Technically Isobaric subs are sealed.
I've never seen an isobaric that wasn't. Besides, doing a "push pull" with a port...who does that?
schan1269 06-30-2011 06:42 PM
Personally, with the box you've designed...
Remove the port(just remove the entire ported area from the design).
Then mount your woofers on the inside, then the outer, I would get 2 LARGER bass radiators
I have seen push pull bandpass, but that is another animal.
mayhem13 06-30-2011 11:12 PM
The inside drivers need to be isolated from the outside of course and the coupled drivers air space isolated from eachother....just as you have pictured. Your internal volume of 9cuft is a bit much though, as you'll be exceeding xmax above Fb pretty quickly. 6cuft works better with the 11-075's. The 11-083's need the bigger box though. Inner drivers need to be as close to the outers as possible since you're not clam shelling. Driver overall depth - cone depth +1.5(Xlim). If the inner cavities could be round tubes, even better. Limit the airspace in there as much as possible as you're 'coupling' the drivers and the more control of the airspace the better.
A9X-308 07-01-2011 12:07 AM
Nope, that's just one of the possible alignments.
zordac 07-01-2011 10:37 AM
mayhem13,
I thought about a clam shell design but I cannot figure out how to make that attractive. I, and more so my wife, do not want to look at the backs of our speakers. Suggestions on design here would be gladly accepted.
Let me run these subs back through WinISD and see. It suggested 8.8 cu ft for those subs.
schan1269 07-01-2011 11:27 AM
I'll just say, I've never seen anybody do a push-pull subwoofer that was ported.
With a bass radiator, yes...but never ported.
And Isobaric is "how you load them"...not the box design.
Bill Fitzmaurice 07-01-2011 11:32 AM
Isobarics may be sealed or vented. The problem with the OPs diagram is the location of the ports, which should be venting the rear chamber directly to the air rather than via a plenum as shown, and the port area, which appears OK for one pair of woofers but certainly not three pairs.
As you have them is fine as it makes the structure stiffer. Extensive bracing of the rear chamber will also be required.
mayhem13 07-01-2011 12:29 PM
Correct.....it's 'compound'.....Isobaric is 'clamshell'.
PR, Ported.......same thing.
mayhem13 07-01-2011 12:32 PM
Originally Posted by zordac View Post
mayhem13,
The way you have it is fine. For the area between the drivers, just cut squares of material and route a circle in em and stack em.....done! It'll be HEAVY so maybe ply instead of MDF.
A9X-308 07-01-2011 01:05 PM
Push pull is not necessarily isobaric and because you've never seen it doesn't mean it doesn't exist or is not possible. Five minutes with on of he sim programs will show you it is.
Which only changes the mass of the air in the port for that of the diaphragm
Well, duh. I've owned commercially make isobarics (Sara, DMS) as well as made my own, and the only difference between a typical enclosure and a bric is the use of a second driver to reduce the effective Vas and therefore (rear) enclosure size. And twice the driver count and cost for the same output capability as a single driver.
A9X-308 07-01-2011 01:07 PM
Face to face mount both drivers on the inner baffle in your original drawings, but have the 'sides' (+top/bottom) as they are. Use a fabric grille to enclose that front volume.
noah katz 07-01-2011 02:19 PM
Technically all isobarik does is yield a driver with different T-S parameters.
zordac 07-01-2011 02:22 PM
Is there a performance benefit to mounting the speakers in clam shell format? I just prefer to be able to see my speakers if I want to pull the grill off.
I have two designs I am thinking about if I could get a couple of you to model these and give me feedback.
Design 1
Volume: 8.8 cu ft
Tuning Freq: 16.5 Hz
Vents/Ports: 1 x 4 in dia x 11.3 in length
Design 2
Volume: 6.5 cu ft
Tuning Freq: 19 Hz
Vents/Ports: 1 x 4 in dia x 11.5 in length
In WinISD, both of these show pretty slopes for me and cone excursion is not a problem until 15 Hz. (if I am doing this correct)
The one thing that bothers me with both of these is that the air velocity coming out of the port seems pretty high. If I add multiple ports obviously this goes down, but we start getting closer to port resonance. If I go to three ports, the length starts becoming an issue.
schan1269 07-01-2011 02:25 PM
I'll ask a simple question...
With that many drivers...
Why do you even need the port? Acoustic suspension(as in, no port) is always easier to design, and generally gives you deeper bass.
Bill Fitzmaurice 07-01-2011 02:39 PM
Is there a performance benefit to mounting the speakers in clam shell format? .
It minimizes the size of the plenum chamber connecting the driver pairs. Since the entire reason for an isobaric alignment is to reduce the cabinet size having the plenum any larger than necessary defeats the purpose. Mounting the drivers face to face on the baffle, eliminating the chamber entirely, was the most commonly seen arrangement when these were semi-popular, thirty years ago and more, when huge Vas figures were more the rule than the exception.
Only Vas, which is halved.
schan1269 07-01-2011 03:01 PM
I remember the fad that was the....
Isobarock
So sad the departure of Advent...
(Cymbal crash...)
noah katz 07-01-2011 03:06 PM
Cms is halved
Mms is doubled
Re is halved (parallel connection) or doubled (series connection)
BL is doubled
SPL (reference efficiency) is halved
zordac 07-01-2011 06:08 PM
So I now realize that doing face2face clam shell allows for the smallest possible box and I will consider that. It seems though that I will not be saving that much space over the front2back design. When I consider the over all space requirements for the speaker, the only thing the clam design does is move the space requirements from inside to outside the box. Maybe I am missing something but isn't the only thing going to change, is whether I have cages or cones pointing out? Won't the overall depth of the sub assembly be roughly the same?
As for overall size, to build a "standard" ported sub with the same characteristics would require between 12 and 18 cubic feet. If I can get this built for under 9 cubic feet total then I will be very happy. And, my marriage will be happier also.
mayhem13 07-01-2011 08:03 PM
Trust me.....no need to clamshell. I build 2 2 driver 11-075's compounds and the worked very well. These were 'play things' mind you but they were very responsive and smooth. The NHT buyouts since they require big volumes are perfect for compound systems.
noah katz 07-03-2011 09:59 PM
zordac, have you tried modeling non-isobarik to see if you're really gaining anything?
I suspect it makes much less difference than for a sealed system.
zordac 07-04-2011 03:55 PM
@noah,
Please correct me if I am wrong, but it looks like the iso design gives me a lot more on the lower end, particularly under 35hz.
noah katz 07-05-2011 03:07 PM
Just asking; if it does, it does.
Are you using EQ?
That might give the same output w/less power, though with more power compression.
Dunno, depends on the drivers' power handling and available power; Isobarik might be best.
Bill Fitzmaurice 07-05-2011 06:14 PM
@noah,
Compared to the same size box loaded with half as many drivers in a standard alignment yes, that's what you'd expect to see.
CZ Eddie 07-07-2011 04:33 PM
I've actually been playing around with the isobaric idea for my friends build.
This is going into a cubby hole into his a/v cabinet (wife won't let it go anywhere else). So his max dimensions are 22"W x 16 3/8"H x 25"D.
All I have to give him are a pair of reconed Lab 12 subwoofers. So I've been trying to come up with the best enclosure design possible to eek out every bit of SPL possible for his huge room. Here is what I've come up with. Each of the three enclosure designs houses two Lab 12's and fits within his space requirements. You can judge for yourself whether the Isobaric is a good choice.
Each enclosure is configured with 1200 watts input and 12db 80hz low pass.
3rd pic is X-max and it's 13mm max for the Lab12. That kinda makes the IsoVent look pretty decent in that regard.
The sealed Isobaric is pretty crappy compared to the regular sealed enclosure, when it comes to SPL. But the regular sealed is exceeding xmax BIG TIME.
YELLOW = SEALED
AMBER = ISOBARIC SEALED
GREY = COMPOUND ISO-VENT
noah katz 07-07-2011 05:28 PM
Port velocity looks awfully high.
You have about 4 cf available; I'd also try two sealed and two vented.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
