aluminum speaker enclosure. okay or not? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-25-2011, 06:41 PM - Thread Starter
Schino's Avatar
im about halfway through building a set of aviatrix in the mltl configuration for my buddy/coworkers wedding gift. we work in a machine shop me being one of the programmer and setup guys for the cnc mills we have. i was thinking of doing an aluminum veneer on the front of his speakers which are made of mdf now and it got me thinking...
long story short. i bought 4 more aviatrix kits (8 speakers) and was thinking of doing a pair totally out of aluminum the sealed version not mltl. is there any disadvantage to doing this sound wise? the advantage i see is it would look awesome i could do some holographic milling patterns into the surface to make it look real trick. material would be thick and bolted together.
thanks,
mike
Schino is offline
post #2 of 12 Old 08-25-2011, 07:30 PM
michael hurd's Avatar
Quoted: 638 Post(s)
Liked: 687
It would work ok as long as the enclosure is well damped ( dynamat or the like applied to the interior...) and braced ( parallel surfaces connected ) to be rigid.
Funky Waves Audio built a subwoofer enclosure out of thick aluminum, and it was bolted together as well.
http://funkywaves.net/gallery/gallery1_large.png
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #3 of 12 Old 08-25-2011, 07:35 PM
Looneybomber's Avatar
Liked: 29
Aluminum will transmit lots of mechanical sounds and resonances which would normally be absorbed by MDF. Putting a sheet over MDF would be better, but it can still work. Just get a lot of dense sound deadener. That old school asphalt people used to use in their cars would be nice...but smelly.
YID DIY
Looneybomber is offline
post #4 of 12 Old 08-25-2011, 07:42 PM
cavu's Avatar
You simply need the mass equivalent to the MDF to prevent resonances (plus internal damping material).
One of my favourite pair of small monitors is milled out of aluminum!
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #5 of 12 Old 08-25-2011, 09:07 PM
LTD02's Avatar
Quoted: 2960 Post(s)
Liked: 3694
steinway lyngdorf model d are aluminum. ;-)
Listen. It's All Good.
LTD02 is offline
post #6 of 12 Old 08-25-2011, 09:22 PM
Steve_Vai_rules's Avatar
magico. their measurements look pretty good too.
Matt
"The main reason Santa is so jolly is because he knows where all the bad girls live." - George Carlin
Steve_Vai_rules is offline
post #7 of 12 Old 08-26-2011, 12:29 AM
kgveteran's Avatar
Quoted: 792 Post(s)
Liked: 237
OMG
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #8 of 12 Old 08-26-2011, 11:56 AM
eat meat's Avatar
how about some thing pourable -plaster, concrete ,resin/epoxy with lead/steel shot or sand?
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #9 of 12 Old 08-26-2011, 05:04 PM
mrevo2u's Avatar
Quoted: 60 Post(s)
Liked: 26
Meridian did some towers out of 5' tall solid billet aluminum for around $28,000/pair -something along those lines.
mrevo2u is offline
post #10 of 12 Old 08-26-2011, 05:18 PM
Java Doc's Avatar
Java Doc is offline
post #11 of 12 Old 08-27-2011, 03:22 PM - Thread Starter
Schino's Avatar
those magico's are nice!! to bad they cover up the nice aluminum on the outside... thanks for the input guys. ive got some big chunks of alum that would be awesome for a hog out but they arent big enough for the aviatrix. would make a nice little bookshelf though
Schino is offline
post #12 of 12 Old 08-27-2011, 07:35 PM
DonH50's Avatar
Quoted: 3298 Post(s)
Liked: 3393
http://www.moonaudio.com/titan_spkr.htm
Hope I can live in them as they cost much more than my house...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
