Behringer Inuke3000DSP hook up question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-12-2011, 08:41 AM - Thread Starter
03roadking's Avatar
I just built a sonosub with the dayton audio rss390ho 4 ohm single voice coil and bought the Inuke3000dsp to power it.
I have the amp set to bridge mode via the software that comes with it. My question is do I have it hooked up correctly if I am just using channel A on the amp?
Is it truly bridged in 4 ohm mono if I am just using channel A or do I need to somehow hook the sub to both channels to get the max output of the amp?
Thanks for help!
03roadking is offline
post #2 of 4 Old 10-12-2011, 09:18 AM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
Here is the answer you need. Follow this thread I posted some weeks ago.
https://www.avsforum.com/avs-vb/showthread.php?t=1362274
javygonx is offline
post #3 of 4 Old 10-12-2011, 10:47 AM - Thread Starter
03roadking's Avatar
Thank you javygonx! I will try this out when I get home after work. Were the results worth it for you?
post #4 of 4 Old 10-12-2011, 06:11 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
Yes; it works. I can tell its like adding a 2nd sub in terms of output but not smoothing. So I assume it will adds between +3db or +4dBs. Here is another diagram that Behringer sent to me.
Bridged Mode Diagram.pdf 6.0986328125k . file
javygonx is offline
