BassThatHz Theater Build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 132Likes
post #61 of 1120 Old 11-29-2012, 09:21 PM - Thread Starter
BassThatHz's Avatar
Quoted: 3659 Post(s)
Liked: 4142
I'm all about functionality first.
Girlies they are always aesthetics first, and like... what's functionality? The total opposite of git er done.
BassThatHz is offline
post #62 of 1120 Old 11-30-2012, 12:59 AM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Originally Posted by Looneybomber View Post
Lucky! The only person I know who works for the DoE is former marine recon and carries nice weapons as his day job. Despite being currently enlisted, I'd rather be in your shoes than in his...except coding is not my strength - BSEE, not CS major. Good luck on the build, and straightening that rats nest of wiring!
The hardest part I find about my job, isn't actually doing my job, rather it's the life-long inability to converse with anyone about my skills/interests and what it is that I do.
First off, only like 1% of the population actually has the ability to understand the fundamental constructs of what I do at a semi-detailed level... for example: as soon as I start talking about asynchronous function pointers and thread contention (just for starters), I see peoples eyes start to glaze over... so I don't even try anymore and everyone that knows me no longer bothers to ask me "what did you do today" wink.gif
So what is it that you say that you do here exactly? I might as well respond: HURR A DURR DERP wink.gif
and then there is the problem of the fact that basically everything is compartmentalized and nearly nothing can be publicly disclosed... unless you desire the inside of a prison cell with no money/job/freedom and be on all no-fly lists and a thing rammed in your bum cheeks instead.
So that only makes one that much more isolated, basically, my work actions so virtualized and abstracted away from physical reality, that I sometimes wonder if there is any correlation between what I create and the ongoings of the world.
Well... 'almost', it's not until you fully activate the software that you finally realize the full extent of the frankensteinian beast that one has just unleashed upon the world. haha
post #63 of 1120 Old 12-01-2012, 08:10 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Progress Report: As you can see, I got all the walls torn down; like 1900 screws.
Taking the ceiling and VB and insulation off tomorrow; and then we are gonna seal that exterior wall right up, maybe some expanding foam or whatever.
Note: The front of the room will be where the two small windows are, all windows are being removed.
post #64 of 1120 Old 12-01-2012, 10:42 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
I went out and bought a 18 Halogen bulb track-lighting system.
I was thinking of 3 pairs of dimmers.
post #65 of 1120 Old 12-02-2012, 10:35 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Report:
I have the inner sides of the exterior walls all sealed up now tighter than an nuns back nine, in prep for the room-in-a-room design.
post #66 of 1120 Old 12-03-2012, 02:12 AM
audiovideoholic's Avatar
Quoted: 669 Post(s)
Liked: 214
What did you use to line all the framing joints?
Whats next? You mentioned spray foam.
Just curious where this is going next. I did the same thing with outlets in columns only just make sure to not have speaker wire running close to it as my electricians had to redo their runs twice for not listening.
Still really wondering what the before and after db readings would be on something being done like this as I cant contain my subs within a 1/4 mile or so.
audiovideoholic is offline
post #67 of 1120 Old 12-03-2012, 02:15 AM
JapanDave's Avatar
Quoted: 174 Post(s)
Liked: 126
Why are you sealing everything up
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #68 of 1120 Old 12-03-2012, 06:57 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Report: The lawn is all dug up now. 8 x 20ft extension
Got a pile of dirt 6 feet high and 16ft wide.
I sealed it up to increase the heating efficiency, keep mold out and to keep bugs out and hopefully keep more sound in.
For the power wires and phone/video/data cables:
post #69 of 1120 Old 12-04-2012, 07:43 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Update: Got the siding off the building and bought 100ft of PVC conduit for data.
I've spent $2200 so far, and that doesn't include the digging/excavator.
I've put in about 30 man-hours of work just on prepping the interior.
post #70 of 1120 Old 12-05-2012, 08:43 AM
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
So to recap:
It's 20x16' currently
It's being enlarged to 20 x 24'
You are pouring 11" thick steel and concrete walls around it.
You are going to build an internal wall in the back for an entryway, and a small equipment/movie storage room ~ 4x6?
What is going to keep the sound from traveling up out of the building- 2' of fiberglass insulation? Maybe you don't care about sound going up- up and into the sky?
djkest is offline
post #71 of 1120 Old 12-05-2012, 12:48 PM
BeerParty's Avatar
I've been working as a software engineer for more than 20 years. And, I have the same problem talking about my job as you do. I've pretty much given up trying to explains my job to friends and family. :sigh:
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #72 of 1120 Old 12-05-2012, 05:43 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
100amp wiring and data conduit is now laid; and back to work I now go...
post #73 of 1120 Old 12-05-2012, 05:55 PM
JapanDave's Avatar
Quoted: 174 Post(s)
Liked: 126
Ok, gotcha.
My build thread
post #74 of 1120 Old 12-05-2012, 07:50 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
All the windows have now been removed.
post #75 of 1120 Old 12-06-2012, 01:35 PM
BeerParty's Avatar
So, when does the extension start? Are you doing that yourself or hiring it out?
Chris
post #76 of 1120 Old 12-06-2012, 06:36 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Update: The cement extension has been laid and is in the process of hardening, and the ditch has been filled.
I ripped out the old amp panel. The framing starts on Monday.
post #77 of 1120 Old 12-08-2012, 03:48 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Here's my Wall O' Subs #1
and Wall O' Subs #2.
But unfortunately I never did get around to finishing the second set, one day... one day...
however with two 10kQ clones it may now be within my reach, if I could only afford a 400amp service and a nuclear power plant in my backyard... this hobby is getting a bit out of control!!! redface.gif
post #78 of 1120 Old 12-08-2012, 11:07 PM
Quoted: 669 Post(s)
Liked: 214
Why cant you get a 400 amp service? I got mine for free minus the actual meter base. Think I spent around $700 on labor and meter base but electric company provided the power and ran the line for free.
post #79 of 1120 Old 12-12-2012, 06:23 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Update: Framing is half-way done.
I changed the plans, I'm doing a door-box instead of a hallway.
New Entrance:
ZeGhostbear likes this.
post #80 of 1120 Old 12-13-2012, 06:28 AM
mastermaybe's Avatar
Quoted: 549 Post(s)
Liked: 410
Ok, full disclosure: I think this is absolutely fkn stupid and an incalculable waste of time, money and other resources in an effort to achieve something that will rarely- if EVER- be used to 50% of its potential.
good luck brother, this is going to be 10/10.
James
My Parlor and Theatre: "Jimbo's Dugout" : https://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #81 of 1120 Old 12-13-2012, 06:32 AM
Quoted: 549 Post(s)
Liked: 410
I'm almost 100% certain it has to do with geography.
Some areas will give you the world for free, others, well, have the checkbook handy.
James
post #82 of 1120 Old 12-13-2012, 06:44 AM
BeerParty's Avatar
Progress on the building - very nice.
The 'overkill' subs - excellent.
I'm looking forward to seeing this one through.
Chris
post #83 of 1120 Old 12-13-2012, 09:57 AM - Thread Starter
BassThatHz's Avatar
Liked: 4142
James
Actually in all my vids I'm using 100% of the output of the 9 completed subs, most of the time it is either: thermally, excursion, or distortion limited. Hence-why so many of them. That and my room was j-shaped before, which is like, the second-worst acoustical layout possible (next to a cube).
I bleed the 8400watts from my 10kQ clone dry, like it's nothing (Basshead) eek.giftongue.gif
post #84 of 1120 Old 12-13-2012, 06:34 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Status Update: The roof is on and the first wall layer is done.
post #85 of 1120 Old 12-13-2012, 11:29 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
post #86 of 1120 Old 12-14-2012, 07:50 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Huge Update: I got a new door and 95% of the framing is done.
Now I'm going to add a second layer of sound proofing insulation, and then it is dry wall time.
The speed is starting to pick up, it is finally starting to feel like a structure.
Door Box:
Amp Closet:
Room-in-Room:
Old entrance closed off:
New Door, solid core with metal backing.
Door-sweep seal:
1ft thick-ass door frame:
360 degree:
post #87 of 1120 Old 12-14-2012, 10:23 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Titanium, 8400watts, 2-ch mode:
post #88 of 1120 Old 12-15-2012, 06:33 AM
Looneybomber's Avatar
Liked: 29
BUSTED?
“This video contains content from The Harry Fox Agency, INC. (HFA), EMI Music Publishing, Sony ATV Publishing and EMI, one or more of whom have blocked it in your country on copyright grounds."
YID DIY
Looneybomber is offline
post #89 of 1120 Old 12-15-2012, 02:06 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Big Brother has blocked it from half the world (because they can)... it is still available but you have to proxy in from one of these countries to watch it frown.gif
Isn't the first time, isn't the last time.
AndorraAustriaBelgiumBouvet IslandFranceFrench GuyanaFrench PolynesiaGuadeloupeIndiaMartiniqueMayotteMonacoNew CaledoniaNorwayReunionSaint BarthelemySouth SudanSvalbard and Jan MayenSwedenSwitzerlandWallis and FutunaWest Bank
post #90 of 1120 Old 12-15-2012, 08:43 PM - Thread Starter
BassThatHz's Avatar
Liked: 4142
Let's try something more exotic shall we? I bet you $20,000 that BB doesn't have this one on their no-fly list! ha tongue.gifbiggrin.gif
Ah... such 1st-world problems we must deal with!
Meanwhile... in Syria and Ethiopia and other such ...ia's and ...stan's!!! eek.gif
