Lilmike's LilWrecker - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 169Likes
post #991 of 1017 Old 10-08-2019, 09:25 AM
Liked: 0
Most amps actually have two amplifiers in them. One for each channel. Unless it's a mono amplifier. The left and right channels work completely separately, so it's easier to think of them as two different amplifiers. When you bridge the channels you give on the opposite signal of the other, so you drive the speaker with two opposite signals to get twice the power. Some amps are not capable of this, and you must divide the driver impedance by 2 because each channel gets half of it. So bridging a 2ohm stable amp with one 2 ohm driver would break it. But a 4ohm driver would give 2ohm per channel and would be fine.
The engineers for the kicker CWR152 planned for this specifically. So instead of one 4ohm voil coil they gave it two 2 ohm coils. So each can be powered with a separate channel. It just makes it easier on you. So the coils could be wired in series to give 4ohms, in parallel for 1ohm or separately for 2 ohms x2. Because your amp is 2ohm stable, I would go for doing them separately. You could wire them in parallel for 4 ohms then bridge it on your amp, then each channel would be doing 2ohms, but I think it will sound better separately. Either way you are going to 1000 watts (kindof, they exaggerate their figures by a bunch).
Lenard explains Bridging on his website under the output stage of amplifier pages. I can't link to it because this is only my 3rd post
It's mostly useful for cars where they have very little supply voltage. Not necessary for home applications where you have as much as you want.
RedmundJBeard is offline
post #992 of 1017 Old 10-16-2019, 09:17 AM
Liked: 0
Hey Folks!
I’ve been studying this sub approach for months now in preparation for a build. I recently came across Fitzmaurice’s Tuba HT and was wondering which Wrecker (Lil, House, Micro, or F-20) it might best compare to AND is one of the Wreckers going to easily outperform it, such that I might start there instead?
Room: 16’ x 29’
5500 cu.ft. (Vaulted ceiling)
Polk RTi150 x 2
Polk CS400
Polk RT35 x 2
Def Tech Bipolar surround
mijotu is offline
post #993 of 1017 Old 01-14-2020, 04:54 AM
drxlcarfreak's Avatar
I am working on building a microwrecker currently and am using pocket screws for most of the panels as it is just easier for me to install them by myself. Do I need to fill the pocket holes? Will they make some kind of acoustic annoyance with the air blowing over them, or are they too small to worry about?
drxlcarfreak is offline
post #994 of 1017 Old 01-14-2020, 08:43 AM
notfastenough's Avatar
Quoted: 218 Post(s)
Liked: 242
I don't ever recall seeing anyone fill them. I highly doubt that they'd cause any noise form the pocket. It would be more likely for them to leak from one side to the other, but overall, not very likely if installed correctly with plenty of glue on the panel edge surface.
Craig S King likes this.
notfastenough is offline
post #995 of 1017 Old 01-15-2020, 01:45 PM
Fair enough. I only saw one person using pocket holes and they had opted to fill them in. My worry was the air rushing by them may cause a small whistle. I plan to use the PL Premium lilmike suggested, so hopefully that is thick enough to not allow leakage.
post #996 of 1017 Old 01-15-2020, 02:20 PM
Quoted: 218 Post(s)
Liked: 242
It won't hurt anything to fill them and better safe than sorry. I would say you don't HAVE to use PL in the pocket holes and could use some cheaper silicone instead. There have been several people that have made horns with pocket holes @hd0823 @BryceDH @asarose247 and others with experience that will hopefully chime in. I didn't use pocket holes for mine, so no noise regardless.
Be sure to take some pics and share impressions! Everyone loves hearing DIY feedback!
post #997 of 1017 Old 01-15-2020, 02:26 PM
Oh duh... I wasnt thinking of just filling them with PL. I am use to bondo or wood putty and was fretting the fill/sand x3 to make a paintable surface.
Just quickly filling with some PL or silicone is easy peasy! Better safe than sorry in that regard.
Sent from my SM-N960U1 using Tapatalk
notfastenough likes this.
post #998 of 1017 Old 01-15-2020, 02:33 PM
hd0823's Avatar
Quoted: 946 Post(s)
Liked: 1796
You'll be fine without filling them all my boxs dont have them filled and I get no sounds coming from them. The first box I started to fill them and decided it was taking to much time lol
Sent from my SM-N975U using Tapatalk
hd0823 is online now
post #999 of 1017 Old 01-15-2020, 04:27 PM
BryceDH's Avatar
Quoted: 176 Post(s)
Liked: 163
I didnt fill mine. I figured the glue on the "bottom" would do the trick. The sub sounds great.
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
post #1000 of 1017 Old 01-16-2020, 11:56 AM
asarose247's Avatar
Quoted: 1340 Post(s)
Liked: 1177
Ditto on the "no need to fill"
except when exterior finishing
then there's that piper to pay
ID:	2670868   Click image for larger version
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #1001 of 1017 Old 01-16-2020, 12:19 PM
Quoted: 247 Post(s)
Liked: 238
FWIW those little wood plugs they sell for pocket holes are actually easier and faster than trying to fill with filler. They sand down really fast with an orbital.
Denon X1300W/DIYSG Fusion 12 LCR/Volt-10 Rears/Micca M-8C Heights
2 @ VBSS End Tables - 2 More VBSS complete!
Epson 2030/DIY 110" AT Screen
Eosone RSF1000 for Enjoying Music
jevchance is online now
post #1002 of 1017 Old 01-18-2020, 10:40 AM - Thread Starter
lilmike's Avatar
Quoted: 119 Post(s)
Liked: 289
I've never filled any of mine. I pocket screw most of the bracing in my sub cabinets, occasionally the panels too. I've never noticed a problem.
asarose247 likes this.
lilmike is offline
post #1003 of 1017 Old 01-19-2020, 03:10 PM
Thanks for the input, like you said I decided not to fill them. I also went against the grain of the thread and used MDF. Since I built this to use up the existing sub and amp I had sitting in my garage, I didn't want to spend the extra money for the decent plywood because it'll just get beat up anyways. I am waiting on a more powerful 12v power supply (and speakon terminals), but at 500 watts, it fills up a 30x30 garage pretty well. I cant imagine how it will sound under full power, much less in a properly sound deadened HT.
One thing I did notice and its probably because I used MDF was the top panel, even with the bracing, vibrates a decent bit. The rest of the box is very solid though. I think I am going to laminate another sheet on top to see if that helps reduce the vibrations.
ID:	2672376   Click image for larger version
ID:	2672378   Click image for larger version
ID:	2672380   Click image for larger version
rezag and asarose247 like this.
post #1004 of 1017 Old 01-20-2020, 03:42 PM
Quoted: 77 Post(s)
Are the any plans for a 12” or 10” drivers?
I have a one of the Dayton Audio TS400D-4 15" Titanic Mk 4 Subwoofer 4 Ohm
that i can use as well
So any ideas about any of these drivers working in the type of box
hessc50 is online now
post #1005 of 1017 Old 04-14-2020, 06:14 PM
Liked: 5
So we are in total lockdown in the Bahamas, Trying to prevent a Covid-19 outbreak,
Hope all here are well and safe.
I hosted a driveway party with the 4 Wreckers, and One attendee! (Me)
Wife was around the corner of our house (a null zone) taking requests from 8-10 neighbors!
Was a bunch of fun, I got a txt from a neighbor a little over a 1/4 mile away asking for "Hey Jude"
Anyway, I say all of that to say this: One Lilwrecker got the death rattle! not the driver. So I trimmed it down,
went in the throat the next day and discovered The last brace in the sound path was no longer attached to either inner or outer panel!
AKA opened seams. Serious pressure apparently on that back panel!
Not a hard fix, remove the driver and I can get in there with more PL Premium, spread it for glue insertion and then clamp the box externally.
I decided to look in them all and found the second of the first set built also had one open seam on that brace.
Age/Heat/humidity? No shortage of glue used.
I doubt any internal braces are separated, be kinda hard for the internal "walls" to shift I think.
Was a fun evening tho! RE-Glue tomorrow. Really throws the bass down the driveway. Echoes all through the hood!
Someone called the cops I think, prob expected them to find a party crowd going on, car came past but didn't stop, just me in the driveway, no breach of Marshal law.
Great Subs Mike! 4 more would be phenomenal...........
CZ Eddie and Audiophile75 like this.
Capt Odyssea is offline
post #1006 of 1017 Old 06-11-2020, 01:15 PM
Liked: 0
HEY GUYS, ME AND MY FRIEND ARE BUILDING THIS SUB RIGHT NOW, BUYING EVERYTHING..I WAS GONNA GO WITH THE ROCKFORD P3 SUB...BUT THE SCAR AUDIO EVL15 LOOKS REALLY GOOD. CAN YOU GUYS VERIFY THAT THIS SUB WILL WORK? THANKS! https://www.ebay.com/itm/201983768315
mslstudio22 is offline
post #1007 of 1017 Old 06-11-2020, 03:06 PM
Liked: 0
Anyway, I
HEY GUYS, ME AND MY FRIEND ARE BUILDING THIS SUB RIGHT NOW, BUYING EVERYTHING..I WAS GONNA GO WITH THE ROCKFORD P3 SUB...BUT THE SCAR AUDIO EVL15 LOOKS REALLY GOOD. CAN YOU GUYS VERIFY THAT THIS SUB WILL WORK? THANKS! https://www.ebay.com/itm/201983768315[/QUOTE]
Never mind, this was addressed already...im going with the Rockfordfosgate p3
post #1008 of 1017 Old 06-12-2020, 05:37 PM
Liked: 0
Guys, i will be using a yung 500-6 plate amplifier, will this plate amp work with the lilwrecker?? Or am i wasting my time
post #1009 of 1017 Old 06-12-2020, 05:38 PM
imrf's Avatar
Quoted: 266 Post(s)
Liked: 207
I don’t know if this is allowed here, but I have up for sale a pair of the SI HT15s that this sub was first designed for if anyone has any interest.
imrf is offline
post #1010 of 1017 Old 06-15-2020, 03:36 PM
Liked: 0
yup
well i cant pm you yet, i might be interested..what ohms are they? on that note, Question for you guys.
if i run 2 d4 ohm subwoofers...in series on each to make 8ohms per woofer. how do i wire that up to my amp to make 4 ohms? i have an xls2500 i plan on using
post #1011 of 1017 Old 06-15-2020, 05:58 PM
imrf's Avatar
Quoted: 266 Post(s)
Liked: 207
They’re dual 2ohm.
After getting them wired to 8ohms you would then wire both parallel to drop it back down to 4ohm.
imrf is offline
post #1012 of 1017 Old 06-15-2020, 07:40 PM
CZ Eddie's Avatar
Quoted: 134 Post(s)
Liked: 66
They’re dual 2ohm.
A dual 2 ohm speaker can be wired for 1 ohm or 4 ohm.
Then you can wire the pair of 1 ohm speakers for .5 ohm or 2 ohm.
Or wire the pair of 4 ohm speakers for 2 ohm or 8 ohm.
I can't think of any way to get a pair of D2 speakers wired to present a single 4 ohm load.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #1013 of 1017 Old 06-15-2020, 07:44 PM
imrf's Avatar
Quoted: 266 Post(s)
Liked: 207
I was just answering him on his question. The dual 2 was in regards to his question on what coils my subs have. Sorry about the confusion.
imrf is offline
post #1014 of 1017 Old 06-15-2020, 07:46 PM
CZ Eddie's Avatar
Quoted: 134 Post(s)
Liked: 66
Oh I see, hah yeah that was confusing for me since I read your reply but not his question. Sorry
imrf likes this.
CZ Eddie is offline
post #1015 of 1017 Old 06-16-2020, 03:18 PM
Liked: 0
thanks
Thanks a lot guys, so out of the amp ill just hook up the two 8ohm loads together and make 4 ohm and run the amp bridged... thanks a lot guys.
post #1016 of 1017 Old 06-16-2020, 03:23 PM
Liked: 0
They’re dual 2ohm.
do you think these will work for the microwreckers?? i switched it up lol. can you pm me your contact info??
post #1017 of 1017 Old 06-16-2020, 04:10 PM
imrf's Avatar
Quoted: 266 Post(s)
Liked: 207
Honestly I have no idea. I’ll PM you.
imrf is offline
