Soundbar recessed into fireplace mantle? Needs ideas, opinions, etc.. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By LTD02
post #1 of 17 Old 09-26-2013, 01:21 PM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
I want to cut a rectangle in the mantle and have a white fabric or maybe metal speaker grille on it to look flush. Similiar to this:
All I want is a soundbar. I have a ton of room behind that mantle as its hollow and I don't really use the fireplace. I've been looking at "sealed" sound bars with no ports on the back or on-top, since it will be pretty much flush mounted in the mantle, and I would assume I wouldn't want anything being ported while is a recessed type install. Is this correct?
Below is a video I just made showing my setup. I would make the rectangle 46" wide, and maybe 5" high. I have quite a bit of room. This would allow for many different sound bar options, and I have a depth of about 5" or maybe more.
Any advice on the best way to make it look good? What type of grille to use, white fabric or metal? I was thinking a "press on" type grille like a normal house speaker? That way you wouldn't see the cut marks?
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is online now
post #2 of 17 Old 09-26-2013, 06:24 PM
LTD02's Avatar
Quoted: 2909 Post(s)
Liked: 3590
just do what the guy did in the picture.
chop a rectangular hole in your mantle.
glue some white grill cloth over the hole.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-334&utm_source=google&utm_medium=cpc&utm_campaign=pla
then add trim pieces of wood to the front of the mantle in order to hide the rough edges of the glued on grill cloth.
the better of a "fit" to the hole that the soundbar is the better. and no, you don't want a ported soundbar inside the mantle.
if the soundbar doesn't fit the hole perfectly, just pack some foam or whatever around it inside the mantle.
should be an easy project.
Listen. It's All Good.
LTD02 is offline
post #3 of 17 Old 09-26-2013, 06:35 PM
LTD02's Avatar
Liked: 3590
here it is in pictures:
LTD02 is offline
post #4 of 17 Old 09-30-2013, 10:25 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
Very cool!!! Love the diagrams.
Originally I was thinking to have a grill frame made. Using something like this and attaching to the front like a home speaker:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-346
Because I didn't want to take away from the aesthetics of the mantel. I never thought about adding more wood trim, etc to go around the hole.
Hmm. Here are some more pics of my mantel and a close up. It is very plain in the middle as you can see, I just don't want it to look overdone when complete. Thoughts?
Harmony 890 Remote
post #5 of 17 Old 09-30-2013, 11:26 AM
LTD02's Avatar
Liked: 3590
if you don't want to chop your mantle up, you could always just build the same idea on top.
LTD02 is offline
post #6 of 17 Old 09-30-2013, 11:34 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
I have to say you are good, really good smile.gif I don't know if I can go that option though, since the top piece that's there now opens up to get to all the components, and I'm replacing that 60" tv with an 80" that's going to hang lower I think.
I'm not one that can really see stuff in my head first, and you have been a lot of help. Is there anyway to take my pics and show the speaker grill on it? Again, i think I'm going to have it be long enough that there will be about 5" on either side of the grille. It won't go completely end-to-end.
I know it could be as simple as this:
I don't think it can do the 3 panel pic you did in the diagram because of the dental trim at the top? This is about as fancy as I can get with my photo skills
Harmony 890 Remote
post #7 of 17 Old 10-31-2013, 03:40 PM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
This guy did something pretty cool with the new Pioneer speaker bar:
Harmony 890 Remote
post #8 of 17 Old 12-08-2013, 11:13 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
Just an update. Got the bar and was testing where to place and it definitely has to be recessed. Since the mantle is about 3 feet deep, when the bar is placed at the back, the sound is cutoff when you are sitting on the couch since your ears are way below the bar and also due to the 3ft depth of the mantle:
The only way it sounds good is to set it here, and this looks horrible smile.gif
Harmony 890 Remote
post #9 of 17 Old 06-12-2016, 05:08 AM
Liked: 4
Did you ever get this project completed? If so any pictures? Currently doing something similar.
c-wolff is offline
post #10 of 17 Old 11-22-2016, 10:42 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
Might be revisting this again, Just got the new 2016 80" Vizio M series.
ID:	1784177   Click image for larger version
ID:	1784185   Click image for larger version
Harmony 890 Remote
post #11 of 17 Old 11-22-2016, 05:28 PM
augerpro's Avatar
Quoted: 139 Post(s)
Liked: 75
I'm working with someone right now on a soundbar design. Basic design will have each "speaker" in WMW layout using the Tectonic Elements BMR as the mid/tweet, flanked by two Dayton RS100. I'll be doing both an active and passive version. Front baffle will be 5.5"H x 50"W, although the width has some room for modification depending on needs. Depth iirc is 4.5". Having sold my house I can't do wood work atm, so I'm doing all the design work, and the other person is doing the actual build. I'm not sure on a time frame but it will probably push after the holidays.
augerpro is offline
post #12 of 17 Old 11-22-2016, 05:34 PM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
sweet, keep up updated.. What do you think of my idea?
Harmony 890 Remote
post #13 of 17 Old 11-22-2016, 05:39 PM
augerpro's Avatar
Quoted: 139 Post(s)
Liked: 75
Could work. Could get real hot too when the fireplace is on, inside and outside the mantle. If it were me I would look for a TV mount that extended out. My design is actually intended to be snugged against a TV (top or bottom) with the faces of both flush.
augerpro is offline
post #14 of 17 Old 12-03-2018, 11:32 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
Hey again. Reviving this thread. I still haven't had the time to do this but I have some free time soon....
I think a sound bar that IS NOT PORTED on the side or back is probably the smartest, right? Again, I'm recessing a sound bar into the mantle, so if it's recessed flush I don't think one that is ported would be a good idea to use in this situation.
Harmony 890 Remote
post #15 of 17 Old 12-04-2018, 05:45 AM
Quoted: 27 Post(s)
You could look at the Helium on the Parts Express speaker project gallery. That is front ported. A little taller than 5" though.
There us also the Ion 4 on DIY Sound group. Custom build the boxes so they are front ported.
Have you figured out your grill?
Jeffrey16 is offline
post #16 of 17 Old 12-04-2018, 09:52 AM - Thread Starter
Jasonn B's Avatar
Quoted: 480 Post(s)
Liked: 172
Originally Posted by Jeffrey16 View Post
You could look at the Helium on the Parts Express speaker project gallery. That is front ported. A little taller than 5" though. There us also the Ion 4 on DIY Sound group. Custom build the boxes so they are front ported. Have you figured out your grill?
Thanks, but I'd like to try and hear something first maybe locally as then it would be easy to return. I've seen review on thew newer vizio sound bars and they are rated actually very good and I don't think are ported? Think I'll use this for the grille and get white fabric....?
https://www.parts-express.com/parts-...e-kit--260-346
Harmony 890 Remote
post #17 of 17 Old 12-04-2018, 05:40 PM
LTD02's Avatar
Liked: 3590
no?
Heide264 likes this.
LTD02 is offline
