Adjustable feet for subwoofers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-27-2013, 01:52 PM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
Hey guys, I built 4 15" subs with the diysoundgroup kits. I need adjustable feet for each as they are in my basement on concrete and the floor is not even. What are my options for adjustable feet? I would prefer rubber feet, but if they only come in spikes, is there some sort of thing I can out under the spikes?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One X, Apple TV 4K, HTPC, JVC NX-5, 106" screen
04rex is offline
post #2 of 7 Old 12-27-2013, 02:15 PM
steve nn's Avatar
Liked: 433
I’m sure there are/is rubber screw on feet. I would ditch the spikes myself.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #3 of 7 Old 12-27-2013, 02:24 PM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 216
Face2 is offline
post #4 of 7 Old 12-27-2013, 06:31 PM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
I don't like something about those. Thanks for the link though.
Any other suggestions??
04rex is offline
post #5 of 7 Old 12-27-2013, 06:47 PM
Bill Fitzmaurice's Avatar
Liked: 5777
Cut some of this to size to fit under your subs, with no feet. It should flex enough to conform to the shape of the floor.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=202015909&R=202015909#.UP66YGeYUYc
Bill Fitzmaurice is offline
post #6 of 7 Old 12-27-2013, 07:13 PM - Thread Starter
04rex's Avatar
Quoted: 331 Post(s)
Liked: 64
How would that work?
04rex is offline
post #7 of 7 Old 12-27-2013, 08:20 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
Why not make your own out of wood and a t-nut?
You could glue rubber on the bottom
BassThatHz is offline
