Dual Sealed SI HS24 Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 233 Old 01-13-2014, 05:02 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Originally Posted by Swolephile View Post
Good luck with your build. You should be very pleased with the performance of these drivers.
WereWolf84 is offline
post #32 of 233 Old 01-13-2014, 07:15 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
What will you be powering your subs with?
Swolephile is offline
post #33 of 233 Old 01-13-2014, 07:18 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
LG clone FP14000 but I will set it around 1,500W
post #34 of 233 Old 01-13-2014, 07:46 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Alrighty. Good stuff. I will join you in the SI 24 double your pleasure club in May.smile.gif
post #35 of 233 Old 01-13-2014, 08:25 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
post #36 of 233 Old 01-13-2014, 08:57 PM
rkinmoval's Avatar
Quoted: 43 Post(s)
Liked: 32
Originally Posted by WereWolf84 View Post
if you were me, how much would you stuffing in the 10 cubic feet box?
It took 8 Wal-Mart pillows to stuff a 12.5 cubic foot box for me. Guessing 6 would get you there but you don't know until you put them in there. It is certainly a lot easier to work with pillows than loose poly. Turns out to be a lot cheaper too. smile.gif
rkinmoval is offline
post #37 of 233 Old 01-13-2014, 09:35 PM
BassThatHz's Avatar
Quoted: 3656 Post(s)
Liked: 4140
The 24's should dig mega low, especially after applying an infrasonic shelf boost. Probably 9-13hz I'd guess, and if your lucky maybe some (reduced) action down to 3hz. biggrin.gif
Will you be taking measurements? (Perhaps previous-sub and after-sub? biggrin.gif)
BassThatHz is offline
post #38 of 233 Old 01-13-2014, 10:52 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
post #39 of 233 Old 01-14-2014, 12:11 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
I don't have any measurement devices at this moment, will getting it together with miniDSP later smile.gif
post #40 of 233 Old 01-14-2014, 12:13 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Thanks for sharing your experience wink.gif Great info
post #41 of 233 Old 01-15-2014, 04:20 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Ok, I have ordered few pieces MDF, it should arriving tomorrow, here are few doubts need advises before start the build:
1) what's the best way to draw a huge circle woofer cutout line? (I'll be using what I have already - a jigsaw, instead of plunge router)
2) if flush mount the driver, would it very difficult to take out the driver later?
Sorry for my noob questions
post #42 of 233 Old 01-15-2014, 06:12 AM
dtsdig's Avatar
Quoted: 1123 Post(s)
Liked: 1384
Find the center point of where the woofer cutout will be and mark it on your panel. Then take a ruler or straightedge or board and attach one end of it with a nail or screw exactly on your center mark. Next, attach a pencil to the opposite end of your ruler (or board or whatever) at the half diameter measurement and carefully turn the whole thing in a circle while drawing your mark.
As far as flush mounting, you'll need a router for that unless you're planning to cut different sized holes on two or more baffle panels and then glue them all up together. With the heavy driver, it won't be easy taking it out again later but if you're careful, you can do it.
When you set it in the first time, put some large zip-ties through a couple of opposing mounting holes to use as "handles". This will help you set the driver down into the baffle without you losing a finger. wink.gif
dtsdig is offline
post #43 of 233 Old 01-15-2014, 06:17 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Thanks! I understand the first half of your guide, but how to attach a pencil to ruler (or board or whatever)?
post #44 of 233 Old 01-15-2014, 06:20 AM
dtsdig's Avatar
Liked: 1384
Whatever way you can that ensures the pencil stays squarely attached to the board. If you used a thin and narrow board or a ruler, you could drill a very small hole at the end where the pencil tip would go through. Just make the hole only big enough for the pencil tip so it can't move around.
dtsdig is offline
post #45 of 233 Old 01-15-2014, 06:23 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
post #46 of 233 Old 01-15-2014, 06:35 AM
TheSeanO's Avatar
Quoted: 34 Post(s)
Liked: 32
This looks like awesome build. I cannot wait to see the final results. What are you using to power both of the subs?
TheSeanO is offline
post #47 of 233 Old 01-15-2014, 06:44 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
A LG clone FP14K amp with VPL set to around 1,500 watts RMS
post #48 of 233 Old 01-15-2014, 07:42 AM
Fatshaft's Avatar
Quoted: 593 Post(s)
Liked: 921
WereWolf,
Why so little power?
I send over 2000w per my 21's and they handle it with ease
I also send 1250w per si18's and they handle that no problem.
I would think the 24's can handle a lot more?
Just saying
Looking forward to see the progress and hearing your impressions!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #49 of 233 Old 01-15-2014, 07:45 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Originally Posted by Fatshaft View Post
WereWolf,
Just saying
Afraid accidentally burn/ fry the coil of the driver, so stick with Nick's claim smile.gif
post #50 of 233 Old 01-15-2014, 07:47 AM
rkinmoval's Avatar
Quoted: 43 Post(s)
Liked: 32
WereWolf,
Just saying
I was worried they'd be power hungry given the size so I reached out to Nick for direction. He only recommends 1,500 watts. Anything more could void the warranty.
post #51 of 233 Old 01-15-2014, 07:58 AM
MD28's Avatar
totally tuned in. cant wait!
MD28 is offline
post #52 of 233 Old 01-15-2014, 09:08 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
post #53 of 233 Old 01-15-2014, 09:12 AM
rkinmoval's Avatar
Quoted: 43 Post(s)
Liked: 32
Heavily leaning towards 2. Need to finish the room they would go in first though. smile.gif
post #54 of 233 Old 01-15-2014, 09:15 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
What speakers will you be using with your SI 24 pair Werewolf?
post #55 of 233 Old 01-15-2014, 12:27 PM
MD28's Avatar
here's his system. over-kill?
termatogazi likes this.
MD28 is offline
post #56 of 233 Old 01-15-2014, 12:36 PM
jpmst3's Avatar
Quoted: 196 Post(s)
Liked: 314
Those are some of the better looking mains I have seen. I like 'em! cool.gif
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #57 of 233 Old 01-15-2014, 12:40 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Nah he's just getting started.biggrin.gif I used to have a 7.4 system consisting of 6 Cerwin Vega CLS 215 speakers. smile.gif
Pics of old setup on page 2 of my this thread. Six Cls 215 speakers along with monster CV dual 10'' center. Very good speakers with clean highs and smooth, low bass.
http://www.chasehometheater.com/forum/showthread.php?t=3489&page=14
post #58 of 233 Old 01-15-2014, 03:21 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
post #59 of 233 Old 01-15-2014, 03:44 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
So who has the CV speakers in the pic above posted by MD 28?
post #60 of 233 Old 01-15-2014, 03:46 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer , Rythmik Audio F12 Direct Servo Subwoofer , Fv15hp Subwoofer
