Dual Sealed SI HS24 Build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #61 of 233 Old 01-15-2014, 03:48 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Swolephile is offline
post #62 of 233 Old 01-15-2014, 03:52 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
I think my dream to go quad HS24 will never comes true if Nick really close out his business
WereWolf84 is offline
post #63 of 233 Old 01-15-2014, 04:00 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Originally Posted by Swolephile View Post
Swolephile, maybe you can build a truly 10 cubic feet enclosure in coming near future rolleyes.gif
post #64 of 233 Old 01-15-2014, 04:08 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
I stated ''weird'' meaning it's weird if MD28 is posting a pic of a random setup that did not belong to you. Not sure how you perceived that in a demeaning way towards yourself. No need for your condescending comment. It was not warranted.
post #65 of 233 Old 01-15-2014, 04:31 PM
MD28's Avatar
So who has the CV speakers in the pic above posted by MD 28?
not i lol. i have heard they sound pretty good though. i remember the redline series back in the day. great speakers.
MD28 is offline
post #66 of 233 Old 01-15-2014, 04:40 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Im confused. Why did you post that pic of the Cv speakers when I asked what type of speakers did Werewolf84 have in his system?
post #67 of 233 Old 01-15-2014, 04:52 PM
MD28's Avatar
i was joking... nothing less, nothing more
MD28 is offline
post #68 of 233 Old 01-15-2014, 05:02 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Weird way to joke with no smiley to signify it.
post #69 of 233 Old 01-15-2014, 07:35 PM
Bill Fitzmaurice's Avatar
Liked: 5767
Is this type of window bracing also good?
That puts most of the braciing in the cabinet corners, where it has the least effect, and none connecting the middles of the opposing panels, where it has the greatest effect.
Friends used to do the one on the left. Then they switch to the one on the right but they don't cut it out from a solid piece
I don't cut it from a solid piece either.
I read somewhere there is a general rule of thumb, one pound polyfill per one cubic feet especially for large box that over 3 cubic feet
That's a very vague 'rule', and doesn't take into consideration the purpose of stuffing, which is to get Qtc to a desired figure. The actual answer of how much to use is as much as it takes, or as little as it needs. Measure the finished result, if Qtc/response isn't right add or remove stuffing until you get it right.
Bill Fitzmaurice is offline
post #70 of 233 Old 01-16-2014, 05:26 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Is it the lower the Qtc, the tighter & punchier the bass? correct me if I'm wrong
post #71 of 233 Old 01-16-2014, 08:56 AM
MKtheater's Avatar
Quoted: 2308 Post(s)
Liked: 2242
WereWolf84,
Looking good! I would put more bracing on the middle of the cabinet as Bill mentioned. I know people make pretty bracing and such but it does not take much if put in the correct spots. The enclosure itself is bracing the corners and especially when using double baffles, the weak points are the middle of the cabinets. I would put 3 braces like pictured above, one in the middle, and two equidistant apart from the middle. So basically if you have a 28 inch long cab I would put the braces at 7 inches, 14 inches, and 21 inches.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
post #72 of 233 Old 01-16-2014, 09:10 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Originally Posted by MKtheater View Post
WereWolf84,
@James
that's not my bracing, someone else tongue.gif I have not even start the build, just got the MDFs today, will using triple/quad baffles
post #73 of 233 Old 01-16-2014, 09:31 AM
MKtheater's Avatar
Liked: 2242
@James
Anyways, double baffle front and those three braces and done! It can be pretty or studs LOL!
post #74 of 233 Old 01-16-2014, 10:44 AM
MD28's Avatar
or... 2 long thread bolts through the cab. 4 bolts to really tighten it up. cant get much better than bracing with steel bolts
MD28 is offline
post #75 of 233 Old 01-16-2014, 02:58 PM
kramskoi's Avatar
And if you have an impedance analyzer, you can determine (Fb) almost precisely what the Qtc. of the box is apart from the room. 1 pound per is about right...3.5 lbs into a 3.5 cu. ft box is a pretty snug fit.
"Frequency response is NOT efficiency response."
Klipsch RB-35's main
Klipsch RB-35's surround
Acoustech HT-65 center
Cerwin-Vega CV-2800
Subwoofer
B&C 21SW152-4  [21" critical-Q]
kramskoi is offline
post #76 of 233 Old 01-16-2014, 03:06 PM
Liked: 5767
Since tight and punchy are subjective terms that have a different meaning to everyone you ask I can't say. Generally speaking too high a Qtc can lead to excessive midbass, which most listeners call 'boomy', too low a Qtc can make the midbass sound weak. Modeling the cab in WinISD you can see the changes that box size makes to Qtc and to response.
post #77 of 233 Old 01-16-2014, 05:02 PM
kramskoi's Avatar
Originally Posted by jpmst3 View Post
Stuffing makes subtle differences. So, an extra pound or two is negligible. I am sure you can get quite a few pounds of polyfill in there.
If you go the cheap Wal-Mart pillow route, I would see how many you can get in there without having to severely jam them in. It is also easy having the fill in neat and easy to handle packages, ala pillows.
You obviously don't want the driver's pole vent blocked or anything touching the cone.
10 lbs. my friend...10 lbs. because the QTC is bloody high enough [~.975] for that driver in that size box. Wal-mart should have bags of polyfill and not require any pillows per se, or just take the poly out of the pillow, assuming of course they are not filled with feathers instead!
Cerwin-Vega CV-2800
Subwoofer
kramskoi is offline
post #78 of 233 Old 01-16-2014, 05:15 PM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
10 lb should be equivalent to 6 poly pillows, right?
post #79 of 233 Old 01-16-2014, 05:25 PM
kramskoi's Avatar
Not sure about pillows. I just buy the fill by the bag. Have bought at Wal-Mart before.
http://www.walmart.com/ip/Morning-Glory-Premium-Polyester-Fiberfill-5-lb.-Box/19397504
Cerwin-Vega CV-2800
Subwoofer
kramskoi is offline
post #80 of 233 Old 01-17-2014, 12:00 AM
MD28's Avatar
this sub application is somewhat on the ridiculous side. on paper the motor is weak. if your not going to use this sub in an ib application, waste of space and cash. they do look cool though. reminds me of the back to the future scene of the giant speaker lol
MD28 is offline
post #81 of 233 Old 01-17-2014, 04:22 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Your post is very rude. And you have not heard the sub in question yet you are passing judgement. Everyone of your posts in this thread is either a random joke or a negative comment.
post #82 of 233 Old 01-17-2014, 04:42 AM
MD28's Avatar
rude or not... i'm looking at the specs. bottom line, the motor is weak. not worth price and a big waste of space. again, they do look cool
MD28 is offline
post #83 of 233 Old 01-17-2014, 04:47 AM
MD28's Avatar
and... i dont need to listen to the sub to pass judgement. reading the specs is all you need to know to not buy it. i guarantee i can burn the voice coils in that sub using the recommended 1500 watts. i'll pay for shipping if you send me yours and... if i burn up the sub, i'll give you 2 image dynamics idmax subs. want to?
GreySkies likes this.
MD28 is offline
post #84 of 233 Old 01-17-2014, 04:54 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
Guys like you are the reason SI is leaving the HT market. You theorize based on specs, dont buy anything, dont listen to anything, yet immediately pass judgement.
If you dont like the design of the driver that is fine. You are entitled to your opinion. But you dont have to come to another member's build thread to spread negativity.
post #85 of 233 Old 01-17-2014, 04:57 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
Swolephile has been feed the driver with 3,500+ watts and it's still survive and going strong rolleyes.gif Nick said put it in 10 cubic feet sealed enclosure is as great as IB application and I trust him, don't tell us you know the driver better the one who design & build it? rolleyes.gif Nick's 18 inch drivers has been sold like hot cakes and well received by many HT enthusiasts/ bass lunatics, even in some AVS members' 4-5 stars ULF score setup
post #86 of 233 Old 01-17-2014, 04:59 AM
chrapladm's Avatar
Quoted: 1099 Post(s)
Liked: 443
WOW.....seriously.rolleyes.gif Sometimes I wonder:cool:
Werewolf84 are you going to be using a MiniDSP or WM8 Bassis for an L/T?
chrapladm is offline
post #87 of 233 Old 01-17-2014, 04:59 AM
MD28's Avatar
if their doing so well... why are they ditching ht? thats what i thought
MD28 is offline
post #88 of 233 Old 01-17-2014, 05:02 AM
MD28's Avatar
there's a reason why specs are published buddy. my offer still stands
MD28 is offline
post #89 of 233 Old 01-17-2014, 05:04 AM - Thread Starter
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
I'll adding a miniDSP for sure, but not now, perhaps in couple of weeks tongue.gif
post #90 of 233 Old 01-17-2014, 05:05 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 360
None of the IDmax subs have the output to keep up with my speakers so I will pass on your offer. Thanks.
Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer , Rythmik Audio F12 Direct Servo Subwoofer , Fv15hp Subwoofer
