Coaxials: Another DIY Group Project. - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 688Likes
post #1621 of 1759 Old 05-09-2019, 12:47 AM
GrandPixel's Avatar
Quoted: 302 Post(s)
Liked: 64
In-wall / IB
GrandPixel is offline
post #1622 of 1759 Old 05-09-2019, 01:15 AM
Quoted: 487 Post(s)
Liked: 405
What type of cabinets do you guys think the 12" coaxial should start with? Cube shape? Large bookshelf? Monkey coffin? Towers?
Towers
With a much simpler square option for those looking for high end surrounds.
Trimlock is online now
post #1623 of 1759 Old 05-09-2019, 11:00 AM
bimmaguy's Avatar
Quoted: 142 Post(s)
Liked: 165
Also voting for towers, but...
Assuming a vertical tower with the driver near the top, and a horizontal center channel with the driver near the center, how much would the sound change between the two?
Subs are like pizzas: you get way more good stuff with the big ones.
https://www.avsforum.com/forum/155-di...uxl-build.html
https://www.avsforum.com/forum/155-di...-overture.html
bimmaguy is offline
post #1624 of 1759 Old 05-10-2019, 02:00 PM
John Booty's Avatar
Liked: 30
I'm sure I'm in the minority, but I'm a fan of the monkey coffin form factor. It's also the only one that would work in my room. But I'm a fan of it in general too.
(The commercial audio world would be in such a better place if it could go back to simple monkey coffin designs, rather than trying to heroically wring decent bass and output from tiny enclosures with 4" or 5" woofers)
openbaffled likes this.
John Booty is offline
post #1625 of 1759 Old 05-10-2019, 03:24 PM
brian6751's Avatar
Quoted: 1714 Post(s)
Liked: 1727
I vote monkey coffin but what would the bookshelf be tuned to?
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #1626 of 1759 Old 05-11-2019, 09:13 AM - Thread Starter
Erich H's Avatar
Quoted: 1917 Post(s)
Liked: 2764
A tower will be done, and I guess the second flat pack could be the monkey coffin size. Do you guys think either should be angled back a bit? I'm guessing they will be made from Baltic birch.
The coaxial tower size is very close to the size of a 1299. I might see if there's anyway possible for those two designs to share the same cabinet so we can finally have a 1299 flat pack. The good news is that the custom shipping box could be used for both of those cabinets even if they were different. Custom packaging stuff really stinks because minimum orders are 250 boxes......so I have pallets of cardboard boxes taking up lots of space. My garage has like 12 pallets of cardboard boxes in it!
I'm not sure what the smaller bookshelf size would be tuned to, probably around 60hz. That one will need to be drawn out a few different ways to see what people like. I don't know if it should be rear ported or two ports on the front with one above and one below the woofer. Keeping it symmetrical makes a horizontal center channel easier. But to be honest, I don't think these will get built very often in the DIY world as a home theater speaker unless someone needs a lot of output in a shorter cabinet than the HTM-12. My guess is they'll be used more for high sensitivity full range 2 channel.....with an optional center.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #1627 of 1759 Old 05-11-2019, 12:54 PM
sandydankness's Avatar
Quoted: 135 Post(s)
Liked: 109
I will buy a pair of towers for 2 channel.
Not sure on 12 or 15" until they are released.
It would be pretty easy to turn a tower into a monkey coffin as well. Cut your custom size box and use the baffle as a router guide. I doubt there will be many people tossing this amount of money into surrounds, but someone here will probably do it.
Front port would be nice for easy placement. Given their size I'm assuming they will be next to a wall.
JonfromCB likes this.
sandydankness is offline
post #1628 of 1759 Old 05-11-2019, 03:17 PM
brian6751's Avatar
Liked: 1727
I would want a rear ported “bookshelf” tuned to ~48Hz
That’s more like a two channel speaker. 60Hz isn’t full range
FOR SALE:
post #1629 of 1759 Old 05-11-2019, 09:57 PM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
You not going to get full range out of the 12" or 15" in a bookshelf style cabinet, f3 on both of those would likely be in the 60-65hz range. Tune lower and f3 actually goes up.
Large tower cabinets are the only way to get a rough full range extension from either of those, just the way the specs on those drivers are.
brian6751 likes this.
mtg90 is offline
post #1630 of 1759 Old 05-12-2019, 07:59 AM
brian6751's Avatar
Liked: 1727
Ah ok. 60Hz makes sense then.
I think something like the old school Tannoy’s would also be cool as far as box design
filtor1 and ronny31 like this.
FOR SALE:
post #1631 of 1759 Old 05-12-2019, 12:03 PM
asarose247's Avatar
Quoted: 1286 Post(s)
Liked: 1125
the 12's as LR , yeah maybe . .
I saw this , and didn't finish watching ti yet
but
and my untrained eye
what's left of my mind thought -
if not needing a bookshelf size
what could a co-ax really do in a TL design like this . .
could it get to be full range?
i'd build that.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #1632 of 1759 Old 05-12-2019, 01:22 PM
Quoted: 138 Post(s)
Liked: 42
So are these 12 and 15s going to have a flat pack that will yield semi reasonable sizes for use as surround speakers? If the flat packs are going to be built for use as mains rather than surrounds I may just pick up the volts soon. Just rather match my titan 615lx mains with larger coaxial surrounds if possible.
[email protected] is offline
post #1633 of 1759 Old 05-12-2019, 03:03 PM - Thread Starter
Erich H's Avatar
Liked: 2764
There will be smaller flat packs made up that could be used for surrounds. But due to the components, they might be kind of expensive for that.
filtor1 likes this.
Erich H is offline
post #1634 of 1759 Old 05-12-2019, 04:43 PM
Quoted: 151 Post(s)
Liked: 68
They would however make an outstanding floor monitor wedges— for those members who have stages in their homes or are really into high end Karaoke!
Sent from my iPhone using Tapatalk Pro
FOHTech is offline
post #1635 of 1759 Old 05-14-2019, 01:47 PM
Wright's Avatar
I don't know if the volume would be adequate, but a format like this would be pretty cool for a coax cabinet.
filtor1 and openbaffled like this.
Wright is offline
post #1636 of 1759 Old 05-14-2019, 02:23 PM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
That isn't too far off what I've built as the prototype cabinets.
mtg90 is offline
post #1637 of 1759 Old 05-14-2019, 02:33 PM
EndersShadow's Avatar
Quoted: 1282 Post(s)
Liked: 1546
I see they are “cat bed” approved
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #1638 of 1759 Old 05-14-2019, 04:33 PM
McLuvin's Avatar
Quoted: 366 Post(s)
Liked: 161
reading my mind.... I was thinking more along the lines of the DC12i and VX12 though. These are more suited for home theater and would be my vote for the new coax's. I think 60hz would be great since most HT use a sub.
DS-21, brian6751 and openbaffled like this.
McLuvin is offline
post #1639 of 1759 Old 05-14-2019, 06:20 PM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
That VX12 is really close to the design of one of the bookshelf enclosure ideas I had for these:
filtor1, rhapsodee and openbaffled like this.
mtg90 is offline
post #1640 of 1759 Old 05-14-2019, 08:14 PM
Wright's Avatar
very cool, looks good!
Wright is offline
post #1641 of 1759 Old 05-15-2019, 07:01 AM
McLuvin's Avatar
Quoted: 366 Post(s)
Liked: 161
Yes, I noticed that earlier. Great ideas IMO. Is the 15" cube ported in the rear or sealed?
McLuvin is offline
post #1642 of 1759 Old 05-25-2019, 01:12 PM
Liked: 3
bump for an interesting thread.
lucasf714 is offline
post #1643 of 1759 Old 05-27-2019, 08:43 AM
Quoted: 31 Post(s)
While these might be something of a horizontal shift for me, so I probably won't be getting them, these are still quite interesting. My LCR speakers are a trio of floorstanding Fusion 12s that make use of the Celestion CDX1730, designed and built by someone much more competent than myself.
I'd love to hear how these compare to the SEOS waveguide in speakers like the Fusions, HTs and HTMs.
Reviews of Tannoys, especially the ones with 15" drivers, usually cite a large sense of scale as one of the positives of it along with the benefits of high efficiency.
Correct me if I'm wrong but doesn't a recording have to have a large sense of scale for it to be perceived as such versus every recording sounding that way just because of the speaker used? The former has been my experience with my speakers.
RobertChicken is online now
post #1644 of 1759 Old 05-27-2019, 09:34 AM
Quoted: 1330 Post(s)
Liked: 766
IMO Tannoy hasn’t made a good 15. I've yet to hear any 15" concentric that works well, so that's not a knock on Tannoy.
Their 8”, 10”, and 12” models have always been better. In 10" and 12" they're best of breed so far though. (KEF's 8" Q-series unit is probably better than Tannoy's 8's.)
RobertChicken likes this.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #1645 of 1759 Old 05-28-2019, 10:18 AM
rhapsodee's Avatar
Quoted: 39 Post(s)
Here is the off axis on the 12" (indoor gated - ignore below 300-400hz).
Might have missed it, what compression driver is being used in this design?
Also, holy crap batman those polars!!
rhapsodee is offline
post #1646 of 1759 Old 05-28-2019, 11:22 AM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
CDX1-1731 is being used in these, I liked it in the Titan design as it is one of the more transparent compression drivers that I have used and it works well in these designs too.
I recently finished the 15" coax design and really like how this one turned out. Didn't I say the 15" might measure better then the 12"!
Well here is the on/off axis response (gated) of that one.
Name:	15in coax 0-90 degrees.png
mtg90 is offline
post #1647 of 1759 Old 05-28-2019, 01:54 PM
Iccy's Avatar
Quoted: 45 Post(s)
Liked: 34
Do you have the Titan LX on/off graph on hand to compare the two?
Iccy is offline
post #1648 of 1759 Old 05-28-2019, 02:51 PM
mtg90's Avatar
Quoted: 827 Post(s)
Liked: 1664
Here is the off axis from the waveguide portion of the normal Titan-615 (CDX1-1446).
Name:	Titan off axis response 10 degree increments.png
bear123 and Pradeep2 like this.
mtg90 is offline
post #1649 of 1759 Old 05-29-2019, 12:54 AM
Quoted: 13 Post(s)
Liked: 2
Any ETA on these kits?
haavardnk is offline
post #1650 of 1759 Old 05-29-2019, 01:23 AM
asarose247's Avatar
Liked: 1125
^ wtr
