8x 18" LMS 5400 Ultras Sealed to 27 Cube 15hz Ported Build - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 71Likes
post #481 of 614 Old 05-08-2014, 08:25 AM
lukeamdman's Avatar
Quoted: 1385 Post(s)
Liked: 2000
Originally Posted by Trepidati0n View Post
Rules of thumb applied universally will usually result in a result below what you were expecting. However, notnyt understands the rules and thus he knows when to deviate from the rule of thumb.
Yeah, he had a sealed cab (heavily stuffed) side by side with a ported cab and couldn't tell any "SQ" differences.
lukeamdman is offline
post #482 of 614 Old 05-17-2014, 11:29 PM - Thread Starter
notnyt's Avatar
Quoted: 3728 Post(s)
Liked: 3697
Someone from the forum who had heard the previous setup just came by tonight. Gave a fresh demo with some music and then we ended up watching A-TEAM. I'll drop him this link, maybe he can chime in with his observations.
I actually managed to trip one of my PDUs tonight... That means I have to get another one for my inuke. I had an FP14000 and an NU1000DSP on the same 20A PDU. While playing some pendulum with the bass about 24db over reference it popped the breaker. I might just get a standard surge strip, I'm not worried about an NU1000 melting one like I know an FP14000 will...
notnyt is offline
post #483 of 614 Old 05-18-2014, 04:58 AM
blazar's Avatar
Quoted: 1188 Post(s)
Liked: 876
You could safely just change the breaker to 30A as long as you arent playing nonstop sinewaves. The existing wiring should be fine
Blazar!
blazar is offline
post #484 of 614 Old 05-18-2014, 09:23 AM - Thread Starter
notnyt's Avatar
Liked: 3697
I didn't trip the breaker. It's already a 30a circuit.
I use rackmount pdus for surge protection since standard strips will melt/trip if i run the fp14000s off them. The pdu just tripped, so going to get a surge strip for the inuke and move it off the pdu.
Also, what you suggest would be a code violation.
notnyt is offline
post #485 of 614 Old 05-18-2014, 09:32 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 173
not...which rm 30amp pdu do you use?
blah450 is offline
post #486 of 614 Old 05-18-2014, 09:39 AM - Thread Starter
notnyt's Avatar
Liked: 3697
I said I use a 20a pdu =] It's plugged into a 30a circuit.
http://www.amazon.com/gp/product/B00077IS32
notnyt is offline
post #487 of 614 Old 05-18-2014, 09:53 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 173
blah450 is offline
post #488 of 614 Old 05-18-2014, 02:22 PM
blazar's Avatar
Liked: 876
Yep definitely a violation, you dont want to go crazy on amp output. It's just to handle occasional peaks.
At my usual listening volumes I am only pulling 5-10amps so the 20A wire is not being affected. It's not like running a motor (like a washing machine) or an oven.
Blazar!
blazar is offline
post #489 of 614 Old 06-09-2014, 05:35 PM
apilon's Avatar
Quoted: 49 Post(s)
Hi
How can i transpose the dimension to include 2 X 15" instead of 2 X 18"
Alain
Alain Pilon
Montreal, Quebec
apilon is offline
post #490 of 614 Old 06-09-2014, 05:39 PM - Thread Starter
notnyt's Avatar
Liked: 3697
Originally Posted by apilon View Post
Hi
Alain
You don't.
You need to model out the box size required for 2x15 at whatever tune you want, using the specific parameters from whichever 15s you're using, then go from there.
notnyt is offline
post #491 of 614 Old 06-23-2014, 10:45 AM
sabaspeed521's Avatar
Just throwing this out there, Couldn't you just have built 2 horns and gotten the same output with a total of 10 A? Haha, only issue there is the extreme low end you want. ~ 130 dB down to 20 Hz is easily doable with FH designs. Anyways it is extremely impressive, wish I could experience.
sabaspeed521 is offline
post #492 of 614 Old 06-23-2014, 06:22 PM - Thread Starter
notnyt's Avatar
Liked: 3697
I wanted the extensions, horns don't do it for me. A horn built to about the same volume as one of these boxes wouldn't be tuned as low, but using only one driver would get me about the same output as using the two drivers I'm using now. However, with two drivers in a ported box, I get the output, and the extension. win/win, just costs more, but no downsides as opposed to a horns FR.
SpinMonster likes this.
notnyt is offline
post #493 of 614 Old 07-03-2014, 11:22 AM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Really awesome theater. I can't even imagine how good it sounds.
Does having non-stuffed subs not effect "boominess" at all? Is "boominess" only caused by non-flat frequency response / room modes?
Did you notice the extra group delay that ported subs have over sealed?
Bassment is offline
post #494 of 614 Old 07-03-2014, 11:45 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
Stuffing an enclosure helps reduce out-of-band resonance. Rob crosses at 80hz or lower, iirc. So not an issue.
Rob's vented enclosures are tuned ~15hz so group delay is a complete non-issue.
"Boominess" is caused usually by the room itself and various excited modes determined by it's geometry.
notnyt likes this.
Scott Simonian is offline
post #495 of 614 Old 07-03-2014, 12:54 PM - Thread Starter
notnyt's Avatar
Liked: 3697
Scott basically answered. Stuffing reduces overall output, didn't really need it. Subs perform as intended, no bad noises or resonances.
This is the group delay of sealed vs ported:
notnyt is offline
post #496 of 614 Old 07-03-2014, 01:00 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
Cool thanks for the info. So do you recommend that no-one stuff/line ported subs? What scenario would you stuff/line a ported sub?
Bassment is offline
post #497 of 614 Old 07-03-2014, 01:56 PM - Thread Starter
notnyt's Avatar
Liked: 3697
Depends on the tuning and the frequency range its being used. Also box resonances and port resonances need to be considered.
martinq likes this.
notnyt is offline
post #498 of 614 Old 07-03-2014, 04:23 PM
WereWolf84's Avatar
Quoted: 399 Post(s)
Liked: 170
If I build a large sealed box, say 15 cf, should I line & stuffing 15lbs polyfills?
WereWolf84 is offline
post #499 of 614 Old 07-03-2014, 04:25 PM - Thread Starter
notnyt's Avatar
Liked: 3697
Sealed I'd say yes. You don't have to worry about air velocity and such in the box, which affect port output.
notnyt is offline
post #500 of 614 Old 07-03-2014, 09:49 PM
Blazen244's Avatar
Maybe I missed it but what kind of amp is being used?
Mr.Zoom
Blazen244 is offline
post #501 of 614 Old 07-03-2014, 10:06 PM - Thread Starter
notnyt's Avatar
Liked: 3697
4 fp14000 clones
notnyt is offline
post #502 of 614 Old 07-05-2014, 06:44 PM - Thread Starter
notnyt's Avatar
Liked: 3697
notnyt is offline
post #503 of 614 Old 07-05-2014, 08:41 PM
Bass Enabler
Liked: 5114
Like a boss.
post #504 of 614 Old 07-05-2014, 10:53 PM
Reddig's Avatar
Quoted: 495 Post(s)
Liked: 982
Awesome dude!
JBL Pro Cinema/JTR/JVC/Denon/Oppo/Roku Ultra/Elite Screens/Furman/Seatcraft/Acoustimac/AudioQuest
Reddig is offline
post #505 of 614 Old 07-06-2014, 12:41 AM
gpmbc's Avatar
Quoted: 376 Post(s)
Liked: 257
Nice!
gpmbc is online now
post #506 of 614 Old 07-06-2014, 06:12 AM
dominguez1's Avatar
Quoted: 1172 Post(s)
Liked: 1111
Very cool! Did you even know the dts guys or was that totally out of the blue?
dominguez1 is offline
post #507 of 614 Old 07-06-2014, 08:40 AM
MKtheater's Avatar
Quoted: 2348 Post(s)
Liked: 2298
In the spirit of this build and thread I am going to try to low tune my IB and see what happens. I have ridiculous output at 5 hz now so I don't want to lose that. I modeled different tunings and ports which shows me gaining 13 dBs at 10hz(tune), 9 dBs at 12.5hz, and 6 dBs at 16hz. It also shows me having the same output down near 5 hz which is the end of my current signal chain(flat anyways) so I won't be sacrificing anything. We shall see and I could always seal the holes back up! I will have 4 12 inch round ports which keeps air velocity low as well. I could have used one 24 inch round port but I wan to add one beneath each dual woofers.
MKtheater is online now
post #508 of 614 Old 07-06-2014, 09:42 AM - Thread Starter
notnyt's Avatar
Liked: 3697
out of the blue
tune near 15Hz for most fun you can always start lower and then trim the port to raise the tune
notnyt is offline
post #509 of 614 Old 07-06-2014, 09:51 AM
MKtheater's Avatar
Liked: 2298
Yeah, I will tune around 11 hz with 24 inch long ports and cutting them shorter raises tune which I won't do, I feel 6hz on concrete! The sim shows 117 dBs at 10hz for my IB and 130 dBs for the LLT. This is without room gain.
post #510 of 614 Old 07-06-2014, 12:21 PM
Reddig's Avatar
Quoted: 495 Post(s)
Liked: 982
You gunna start a thread MK? Wanna keep up with your progress.
Reddig is offline
Tc Sounds Lms Ultra 5400
