Behringer Inuke 6000 dsp speaker wiring question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-08-2014, 05:16 PM - Thread Starter
rr14's Avatar
Quoted: 122 Post(s)
Liked: 32
Hi guys. I have an inuke 6000 that I just got and 2 elemental designs 18" 19vo.2 subs. I'm running them in an infinite baffle setup. I was trying to wire them both up to 1 channel today so that I could channel 2 for a second setup if necessary.
When running the setup, without the gain too high, I was getting the red protection light at the top of the 4 orange led indicator lights. I was getting it with only 1 orange power light lighting up. So, I have a question about how I wired the subs.
I ran a multi meter to verify that my subs were dual 4 ohm last week. It read either 4.0 or 4.1 (I don't recall of hand).
So I wired each of the subs voice coils in parallel and I crossed the speaker wire between the two. I thought that if each speaker was 2 ohm and I ran them in series, then I'd be back at 4 ohm. Am I correct here?
This is a newbie question, but can I run only one of the voice coils on each speaker so that they run at 8ohms, assuming I run 1 coil on each speaker in series? I'd still be getting more than enough power since I don't need much more than 500 watts a speaker and the amp will do 1600 at 8 ohms and 2200 at 4.
rr14 is offline
post #2 of 3 Old 02-08-2014, 08:14 PM
LTD02's Avatar
Quoted: 2950 Post(s)
Liked: 3678
"So I wired each of the subs voice coils in parallel and I crossed the speaker wire between the two. I thought that if each speaker was 2 ohm and I ran them in series, then I'd be back at 4 ohm. Am I correct here?"
that sounds right.
maybe you got one of the wires backwards. a simple test is a 9v battery on the terminals to make sure the cones move how you are hoping.
"This is a newbie question, but can I run only one of the voice coils on each speaker so that they run at 8ohms, assuming I run 1 coil on each speaker in series?"
yeah, but not recommended. the t/s parameters will be different (?) and power handling is half, of course.
Listen. It's All Good.
LTD02 is offline
post #3 of 3 Old 02-09-2014, 04:09 PM - Thread Starter
rr14's Avatar
Quoted: 122 Post(s)
Liked: 32
I just rechecked the wiring.... strange. The wiring appears correct.
I can run one speaker on each channel with the voice coils in series, but it seems like a bit of a waste of a killer amp since my speakers only need about 500 watts to reach max excursion.
In time, I'd really like to get 4 fi infinite baffle speakers. I'll just get 4 ohm and run them in series with 2 on each channel. I guess this will do for now though.
I may try the amp on a triple 12" sealed box I have that is 4 ohms and see if it acts up on that box as well. Maybe it's my ED drivers.
rr14 is offline
