Curved SEOs Tempest Build - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 107 Old 04-14-2014, 07:39 PM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Awhile back I had this crazy idea to build an elegant curved SEOs tower starting with a curved skeleton. I chose the Tempest as my guinea pig and I'm happy to show off some of the work I've been doing little by little here in the cold winter months.
Here is the original idea thread: https://www.avsforum.com/t/1505240/future-curved-seos-build-cnc-brace-skeleton-idea#post_24068435
Here are some initial pictures of the skeleton being glued and after they were done being glued. The front baffle is 1" mdf, each curved piece is 3/4" plywood as well as the 3 back strips.
I decided to use 1" mdf for the curved panel and kerf it instead of using multiple layers of 1/8" mdf. I had to use a blade that was 3/16" so the kerfs are a little bit larger then what I would have liked but filling the gaps was much easier this way. Test piece:
I built a curved "bed" for the panels to sit in while I was clamping them. Used a lot of glue to fill the kerfs!
Here is a test fitting after the curved back was dry. I had Erich send me non rounded front baffles with no port holes and created a nice curved front piece out of 1-1/2" mdf to give it a bit more curvy-ness!
As weather permitted finally I was able to make more progress this weekend, cutting holes on the bottoms for ports and terminals as well as glue top and bottom end caps. Sanding down those kerfed ridges is going to be a pain!
steve71 and lpicchiotti like this.
realtight is offline
post #2 of 107 Old 04-14-2014, 08:02 PM
sooly1's Avatar
Liked: 35
sooly1 is offline
post #3 of 107 Old 04-14-2014, 08:07 PM
chalugadp's Avatar
Quoted: 1683 Post(s)
Liked: 1572
Top quality work .
chalugadp is offline
post #4 of 107 Old 04-14-2014, 08:13 PM
dtsdig's Avatar
Quoted: 1123 Post(s)
Liked: 1386
dtsdig is offline
post #5 of 107 Old 04-14-2014, 08:18 PM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Thanks everyone! Honestly I've put more planning into these towers then the time its taken to build thus far. Its almost an obsession.
Dts, your curved sub build is what inspired me to start working on a curved build of some kind so that means a lot!
post #6 of 107 Old 04-14-2014, 09:13 PM
kevings's Avatar
Quoted: 326 Post(s)
Liked: 506
Awesome Awesome awesome work.
I love builds like this ( new. Innovative, risk taking).
With skills like yours...The Marty subs I built, are something you could've tackled in elementary school:)
kevings is offline
post #7 of 107 Old 04-15-2014, 04:28 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 182
These are looking fantastic! Very impressive! I am curious, how do you guys make these elaborate bracing panels? How do you ensure that all of these intricate bracing panels are the exact same size? What do you use to cut them & how do you make sure that they all line up properly?
Martycool007 is offline
post #8 of 107 Old 04-15-2014, 04:34 AM
ChopShop1's Avatar
Quoted: 327 Post(s)
Liked: 326
Very nice looking build realtight! I've been contemplating something similar for the tux1099 for the living room. What method did you use on the front baffles??
ChopShop1 is offline
post #9 of 107 Old 04-15-2014, 04:53 AM
kgveteran's Avatar
Quoted: 729 Post(s)
Liked: 218
Pretty slick build. What will you be powering them with ? Will this be for HT or two channel ? Wts, passive XO or active ?
KG
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is offline
post #10 of 107 Old 04-15-2014, 05:00 AM
mrevo2u's Avatar
Quoted: 60 Post(s)
Liked: 26
Very nice, what 's the finish going to be?
mrevo2u is offline
post #11 of 107 Old 04-15-2014, 05:14 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 173
Freakin' outstanding! Speaker-building art. Love the front baffle/faces!! biggrin.gif
blah450 is offline
post #12 of 107 Old 04-15-2014, 05:28 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Honestly, I found a local cnc guy that cut all of those curved pieces so they are all exact, I started cutting them with a jig and my router and was taking way too long. The red clamps you see in the photos clamp wood at perfect 90 degree angles and the long strips help keep everything in place while they dried.
post #13 of 107 Old 04-15-2014, 05:30 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
The front baffles were going to be large 45 degree angles until I found this thread on another forum:
http://www.hometheatershack.com/forums/diy-speakers/48848-trompie-s-curved-statement-family-building-thread.html#post453651
On the 7th post you can see the jig this guy created, I did the exact same thing. It took a lot of passes with my router but I think they ended up nice smile.gif
After they were done I decided to keep the baffles Erich sent me and just cut a window into the curved front with my router, and shaved the edges until the two pieces fit perfectly.
ChopShop1 likes this.
post #14 of 107 Old 04-15-2014, 05:34 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
It's not set in stone yet, and I'm a little worried about screwing them up but I bought some really nice glossy Madagascar Laminate from cabinetparts.com
The inside flat baffle I'm going to use some leftover zebrawood veneer and stain it gray to give a little contrast to the glossy black laminate.
post #15 of 107 Old 04-15-2014, 05:36 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
KG
Passive crossover. I have a Yamaha z11. I also have an Adcom gfa-555-II that I might connect to them and let the Yamaha push the other 9 speakers.
post #16 of 107 Old 04-15-2014, 06:29 AM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 173
You know, realtight, it's not everyone that can say they have some left-over zebrawood veneer...biggrin.gif
The closest I could come to something exotic like that would be left-over extra garlic brats.wink.gif
blah450 is offline
post #17 of 107 Old 04-15-2014, 08:35 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Haha, it does sound a little ridiculous doesn't it?
The company that I ordered the veneer from screwed up and sent me two different types. They sent more to make up for it and let me keep the type that didnt match :-)
post #18 of 107 Old 04-15-2014, 08:43 AM
mjaudio's Avatar
Quoted: 47 Post(s)
Liked: 84
Outstanding build!
With the ports on the bottom how high off the floor do they need to be so they don't affect tuning?
How much bigger is the cabinet volume compared the recommended 2cuft tempest and does it require a different crossover?
mjaudio is offline
post #19 of 107 Old 04-15-2014, 08:56 AM
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 206
Beautiful, can't wait to see the finish product. Definitely something that a nice veneer could benefit from. Subscribed. Bring on the nice weather so you can this one finished up.biggrin.gif
cessna1466u is offline
post #20 of 107 Old 04-15-2014, 09:19 AM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2225
Very very nice. Thanks for sharing.
I've considered a curved build on a much smaller scale. Let me know if I'm on the right track to making the ribs... I'd make a template and trace it onto my sheet goods. Then I'd bandsaw them out within an 1/8" of the line. Then affix the template to the roughly cut out rib. Flush route it out on the router. Repeat for each one.
It seems you were doing something like that, but gave up and went with a CNC. Was that because it was too much work, or you weren't getting a reliable repeatable result??
My youtube channel: Impulse Audio
tuxedocivic is offline
post #21 of 107 Old 04-15-2014, 09:26 AM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 69
Tux that's what I did with all 27 ribs in my build. I just screwed the template to the rough cuts and routed for a few hours. The caps I just didn't screw all the way through so no filling wink.gif
tuxedocivic likes this.
aaronlinkous is offline
post #22 of 107 Old 04-15-2014, 09:27 AM
ChopShop1's Avatar
Quoted: 327 Post(s)
Liked: 326
Wow, very cool...I'm gonna have to hit up my good buddy with a cnc and see what can be done that way too biggrin.gif
realtight likes this.
post #23 of 107 Old 04-15-2014, 10:28 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
The initial shape's outside edge is just half of a diameter which I cut with my router and the straight part has a 1/4" indent to lock onto the mdf board. I used my dads bandsaw for the inside braces but after the first piece was done I received a quote from my cnc guy that I couldn't pass up.
He only charged me a wholesale price for the wood and an hour of time. It was actually cheaper for me to go that route so I couldnt pass it up. While he did those I started on the front boards which took forever because my work and the outside weather.
post #24 of 107 Old 04-15-2014, 10:34 AM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Originally Posted by mjaudio View Post
Outstanding build!
Thanks - I think anyone on here with the right tools and patience could do the same. I dont consider myself a talented wood worker.
The internal volume is exactly the same as the kit. The ports need to have the same vertical clearance as their diameter which is 2.5". I'm going to build a 1" bottom piece that has a hole in the middle and install 1.5" spikes that PE sales.
post #25 of 107 Old 04-15-2014, 12:30 PM
Bud Heavy's Avatar
Quoted: 27 Post(s)
Liked: 24
Very cool!
Epson 8500UB, 130" Seymour XD Screen
Denon X4000/X4200, Outlaw 7075, Behringer 6000dsp, 3000dsp, CrownX1000
DIYSG Tempest LCR, V-10 Surrounds, V-6 Rears, Ed Frias AR.com Wides, Polk RC80i Atmos
Dayton UM18 x 2, Infinity 1262 x 4 (+4 WorkInProgress), NHT Dual 10's
Bud Heavy is offline
post #26 of 107 Old 04-15-2014, 12:34 PM
filtor1's Avatar
Quoted: 261 Post(s)
Liked: 238
WOW! Those look stunning!
filtor1 is offline
post #27 of 107 Old 04-15-2014, 05:31 PM - Thread Starter
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Do any of you have experience with kerfed panels? The more I think about it, sanding those bent ridges down wont leave much left for the mdf. How smooth do the sides have to be for the laminate to hide the ridges?
post #28 of 107 Old 04-15-2014, 09:40 PM
DGF
DGF's Avatar
Liked: 39
This is a great piece of work! The one odd thing that popped out for me was the "chunkiness" of the kerfing - when I've done curved mdf (and other woods) I typically remove a lot more material - If I'm using a 3/32" blade I'll make a cut, move the wood over by twice the width of the blade (3/16") and make the next pass, so I end up with 50% of the material being removed (making a jig to do this is easy and ensures regularity of cuts). I also find it good to experiment with the cut depth - leaving too little material will emphasize each kerf, and leaving too much behind makes the piece brittle, but once you get it dialed in you can make a completely smooth piece where the kerfs are invisible from the face side (i.e. no sanding required). Just be prepared to create a lot of saw dust!
It's definitely worth experimenting on scrap material because the laminate, if properly done, will show every irregularity in the substrate, so you need to make sure that you do due diligence and get a pretty decent surface on which to glue.
Dave
DGF is offline
post #29 of 107 Old 04-15-2014, 09:53 PM
chalugadp's Avatar
Liked: 1572
When I have done curved pieces I always have used thin pieces and curve around a base.
With what you have I would take a belt sander to it.
post #30 of 107 Old 04-16-2014, 03:16 AM
Quoted: 280 Post(s)
Liked: 182
I have a general question that I would like to ask you woodworking guys as I am totally new to this...
When it comes to measuring and marking the cutting lines on various pieces of wood, do you just use a tape measure and trust your freehand marking skills by the line on the tape measure? I am having trouble marking accurate, repeated lines using a tape measure. Is there a better way to ensure that you mark the same lines multiple times?
Also, I am having trouble cutting exact sized panels, which I believe is also a product of not marking exact lines. Do you guys cut with the blade right on the line?
