The Dtsdig Curvy-Cab Tux-1099 build!! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 365Likes
post #61 of 771 Old 07-09-2014, 09:18 AM - Thread Starter
dtsdig's Avatar
Quoted: 1123 Post(s)
Liked: 1386
Originally Posted by aaronlinkous View Post
Hardboard like I used is back by the tile kind of. Not in the big shelves with all the other wood.
I used hardboard like yours for my sub builds and it worked well. Not exactly easy to bend, but I didn't have to worry about it after it was glued either. I'm just not as sure about it for these. Finding something easier to bend would certainly make my life easier.
dtsdig is offline
post #62 of 771 Old 07-12-2014, 05:44 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
Some good news here, Home Depot sells 1/8" hardboard for $9 a sheet. That means I'm back in the game to build the fronts after all.
In the meantime, I picked up one sheet yesterday so I can finish up the center. Pro tip: removing PL Premium really sucks.
I should have some time tomorrow to continue with the top layers.
Noman74656 and chalugadp like this.
dtsdig is offline
post #63 of 771 Old 07-13-2014, 06:36 AM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2225
Insanely nice build. These are gonna be really nice.
Mfusick likes this.
tuxedocivic is offline
post #64 of 771 Old 07-13-2014, 07:07 AM
PassingInterest's Avatar
Quoted: 195 Post(s)
Liked: 532
I keep a spray bottle of DeNatured Alcohol on hand as well as Mineral Spirits. I forget which cleans the adhesive off of hands better. But, spritz on hands and wipe on paper towel. Or spritz paper towel and wipe off of another object. Of course, peeling off and discarding cheap latex gloves is even easier.
Great looking build, so far!
PassingInterest is offline
post #65 of 771 Old 07-13-2014, 07:15 AM
cw5billwade's Avatar
Quoted: 329 Post(s)
Liked: 185
nice really nice I assume this is center and LR will be curved on both sides?
cw5billwade is offline
post #66 of 771 Old 07-13-2014, 03:42 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
Yup, you got it. And thank you!
dtsdig is offline
post #67 of 771 Old 07-13-2014, 04:53 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
I use paint thinner or something like that to remove PL Premium from my hands before I wash them with soap. It's your only chance.
I put a screw driver down in a small drip of that stuff, literally a drip onto ply. I could not remove the screwdriver without using a sledge hammer, and then the ply failed. I sanded off some of it with grinder but the PL will be on the handle forever. I should have just thrown it away, I think I wasted like an hour trying to save a $2 harbor freight screw driver. That stuff is strong.
Mfusick is offline
post #68 of 771 Old 07-13-2014, 08:32 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
To clear up the confusion, the issue I had with the PL was that I had already installed one layer of this terrible underlayment ply and it didn't turn out good so I ripped it off. The plywood delaminated where it was adhered with the PL so I had to spend a couple of hours cleaning all of it off with a chisel and sandpaper.
I wear gloves anytime I work with that stuff.
I did make some progress today and got 4 layers of 1/8" hardboard installed. The process was kind of a train wreck because I wasn't setup properly with boards for the ratchet straps to pull against but hopefully it will turn out ok. It's kind of funny to me that doing one curved top panel has been more difficult than doing two curved panels on opposite sides of the box like on my subs. But, hey!....I'm learning.
On another note, I finished up the third crossover so now all 3 are ready to rock!
dtsdig is offline
post #69 of 771 Old 07-14-2014, 05:51 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Some photos from yesterday's building frenzy....
And three completed crossovers....
Hopefully tonight I will remove the straps and clamps and see how it all held up. If I have time, I'll attach the last layer. Once that is all set, I'll be trimming all 4 edges flush and then all I have to do is join this top/back/sides/braces assembly to the baffle/bottom assembly. My screw holes for the drivers are all set since yesterday too. I really hoped to have this done this past weekend but at least it's looking good for this week!
Fatshaft and mtbdudex like this.
dtsdig is offline
post #70 of 771 Old 07-14-2014, 10:13 AM
Boxozaxu's Avatar
Quoted: 510 Post(s)
Liked: 348
Looking good dtsdig! That's going to look really sweet in your setup. What's your plan to fit that on your existing equipment console? Or are you going to hang that above the TV?
I'm in the same boat here and will probably use tempered hardboard because that's what I can find easily. And it's cheap! One of the local home depots has 3/16” on sale for $9.00. Yesterday I glued up over a dozen test variations of scrap mdf, hdf, tempered, untempered, sanded, unsanded, etc. just to see how they compare. Later this week I'll rip them apart to see what works best. Did you do any prep to your hardboard before glue up? It looks like the tempered 1/8” hdf with one rough side.
Boxozaxu is online now
post #71 of 771 Old 07-14-2014, 10:55 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Yeah, I think hardboard is the way to go after looking into many options over the past week. My sub builds used 3/16" and that worked out fine. For this somewhat smaller build, I was really happy to see that home depot carries 1/8" hardboard; rough on one side, like you said. It is very pliable! No prep. I just used PL Premium to glue the first layer to the frame and braces. After that, I used Titebond II with a 4" foam roller and covered the rough side of each piece thoroughly.
As for where it's going to fit when it's done, it is going to stay on top of the TV stand that is currently in place! The footprint of this center is going to completely cover the top shelf of the stand, LOL. In fact, part of how I chose the curve radius was by measuring to see what will fit under the bottom lip of the TV bezel. The back edge of the speaker will be tucked under the edge of the TV. The TV is mounted on the wall and if I am seated, I have about 1.5" of clearance between the top of the center channel and the bottom edge of the TV screen. This is going to make my 52" TV look comically small, but I'm ok with that!!!
dtsdig is offline
post #72 of 771 Old 07-14-2014, 12:11 PM
Boxozaxu's Avatar
Quoted: 510 Post(s)
Liked: 348
Using PL Premium for the first time this coming weekend. Hopefully I won't have a permanent Vulcan salute on Monday.
We're not upgrading our sony 40" tv for a few more years so, yeah, a little bit silly looking here too.
post #73 of 771 Old 07-14-2014, 12:13 PM
chalugadp's Avatar
Quoted: 1683 Post(s)
Liked: 1572
Titebond III gives you 30 minutes of working time.
chalugadp is offline
post #74 of 771 Old 07-14-2014, 12:15 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
Dude, make SURE you use gloves with that stuff! And let the squeeze out just sit there and dry on it's own. It is much easier to remove it with a putty knife or razor after it's dry than to try and remove the smear marks from trying to clean up as you go. Other than that, it's great stuff. It's not necessary if your cuts are nice, but I use it for the extra hold power on the first curved panel.
dtsdig is offline
post #75 of 771 Old 07-14-2014, 01:04 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
Yep, and I sure could have used that extra time yesterday! I'm just finishing up the gallon of Titebond II I had from my sub builds last year. Almost gone!
dtsdig is offline
post #76 of 771 Old 07-15-2014, 04:22 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2725
Put it on extra heavy gets you a couple more working minutes, or you can rebrush with a little more if you start running out of time.
Mfusick is offline
post #77 of 771 Old 07-15-2014, 04:42 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
The fifth layer went on this morning. Tomorrow afternoon I'll pull the straps off and see if this is going to work out! 😁
I am super excited to hear this thing! I've been staring at the baffles for the fronts sitting in my living room for 2 or 3 months now along with a pile of Delta 10B woofers. It's maddening!
dtsdig is offline
post #78 of 771 Old 07-15-2014, 05:36 PM
Boxozaxu's Avatar
Quoted: 510 Post(s)
Liked: 348
Diluting Titebond glue with 5% water doubles the working time and does not reduce its strength.
Mfusick, mtbdudex and ygrene321 like this.
post #79 of 771 Old 07-15-2014, 06:35 PM - Thread Starter
dtsdig's Avatar
Liked: 1386
Diluting Titebond glue with 5% water doubles the working time and does not reduce it's strength.
That's a great tip, man! Thanks!
dtsdig is offline
post #80 of 771 Old 07-16-2014, 08:58 PM
Jon S's Avatar
Quoted: 1113 Post(s)
Liked: 393
I can't see any pictures... All I get is this...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #81 of 771 Old 07-17-2014, 04:12 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Yep, I'm waiting to hear back from photobucket support.
dtsdig is offline
post #82 of 771 Old 07-17-2014, 09:24 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Photos are fixed. I hate photobucket so I'm done with them! Switched to Minus, no limitations!
dtsdig is offline
post #83 of 771 Old 07-17-2014, 09:30 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Got the 5th layer on and it turned out alright. Admittedly, it did not go as smoothly as my subs did. I think building the fronts will go easier because they'll have curves on both sides. After trimming, these will be fine though.
I think trimming will get done tomorrow and then the whole thing can get put together.
dtsdig is offline
post #84 of 771 Old 07-18-2014, 05:16 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
I got some trimming done last night. I was glad to see that once the nasty overhanging edges were out of the way, the laminated layers looked nice and tight. I took a jig saw to the side overhangs and the back and for the front used my track saw. The front edge where the box meets the back of the baffle is critical so I took a fair amount of time setting up for that cut.
Using the track saw here was the way to go! The cut turned out nicely and all I needed to do was sand for a while to bring the edge in just a bit further. This pic was just after the cut and you can see there is a small gap left between the side and the baffle.
I didn't think I would have time for it last night, but once I got that front edge perfect, I proceeded to THE GLUE-UP!
Tonight I'll get all edges flush trimmed and get this sucker loaded!!!!!
dtsdig is offline
post #85 of 771 Old 07-18-2014, 05:29 AM
in3rtia's Avatar
Quoted: 87 Post(s)
Liked: 26
Looking great!
I'm sure that track saw makes speaker cabs a breeze... So I looked up what one might cost.... I'll have to stick with a circular saw against a straightedge.
in3rtia is offline
post #86 of 771 Old 07-18-2014, 05:41 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
Originally Posted by in3rtia View Post
Looking great!
Thank you!
Yeah, the track saw is fantastic! This was my first real project with it and between that and the cutting table setup I made, all the cuts were so easy. Huge time saver! $400 gets you the Makita with a 55" track. Around the time I bought it, a guy on my local craigslist had another 55" track new in the box that I got for $45 (compared to $80-90 new) so I can rip a full sheet length wise when I need to. I highly recommend it!
mtbdudex likes this.
dtsdig is offline
post #87 of 771 Old 07-18-2014, 05:43 AM
in3rtia's Avatar
Quoted: 87 Post(s)
Liked: 26
Yeah I just checked CL after posting. Nadda
in3rtia is offline
post #88 of 771 Old 07-18-2014, 06:14 AM - Thread Starter
dtsdig's Avatar
Liked: 1386
I keep forgetting that you are local. I'll have to add you to the list of potential participants if we ever put together our own little get together!
dtsdig is offline
post #89 of 771 Old 07-18-2014, 06:29 AM
in3rtia's Avatar
Quoted: 87 Post(s)
Liked: 26
Yes most definitely
in3rtia is offline
post #90 of 771 Old 07-18-2014, 06:42 AM
JohnDean's Avatar
Quoted: 542 Post(s)
Liked: 254
I guess Minus is blocked from work for me.
JohnDean is offline
