The Dtsdig Curvy-Cab Tux-1099 build!! - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 365Likes
post #211 of 771 Old 01-16-2015, 11:24 AM
Quoted: 105 Post(s)
Liked: 56
Yeah, I think woodglue can reactivate when you put new woodglue on it right? I've noticed with an outdoor project that I did that when it got wet, the glue reactivated.
Michael Rodriguez is offline
post #212 of 771 Old 01-16-2015, 11:25 AM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 69
I used staples at all the braces and then shrink wrapped it while it dried. Then before the next layer, sanded it all diwn and glued and shrink wrapped it.
aaronlinkous is offline
post #213 of 771 Old 01-16-2015, 11:38 AM - Thread Starter
dtsdig's Avatar
Quoted: 1125 Post(s)
Liked: 1387
Yes, I believe you're correct, except here I will be using Titebond II where PL Premium was, so no-go with the reactivation.
dtsdig is online now
post #214 of 771 Old 01-16-2015, 11:48 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
Wood glue dries, cracks, leaks. It's great on a perfect wood on wood bond. Not so good on filling gaps and keeping them air tight. How about a creamier construction adhesive with a faster cure time as an alternative in between the two?
Mfusick is offline
post #215 of 771 Old 01-16-2015, 12:04 PM
Quoted: 105 Post(s)
Liked: 56
That's funny, I've never heard of woodglue cracking.
post #216 of 771 Old 01-16-2015, 12:15 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
Yeah with age it dries out. All my furniture has it. Very common. Not a problem for holding a wood joint, but possibly if you want air tight sealer. It's the wrong stuff.
Mfusick is offline
post #217 of 771 Old 01-16-2015, 08:53 PM - Thread Starter
dtsdig's Avatar
Liked: 1387
I'll be sealing the joints with something else once the gluing is done, no worries there. Hell, I could even use PL for that!
Michael Rodriguez likes this.
post #218 of 771 Old 01-16-2015, 11:44 PM
Quoted: 105 Post(s)
Liked: 56
So what's stopping you from bending it from one end a little at a time and putting a brad nail in it every 1 1/2" or so? You're going to cover it with veneer anyways right?
post #219 of 771 Old 01-17-2015, 06:21 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
I'd use a rubberized sealant. PE sells some specifically for that use, but any weather sealant probably works too (cheap).
Mfusick is offline
post #220 of 771 Old 01-17-2015, 06:22 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
Use a fast grab construction adhesive or a fast cure wood glue. This can work.
Mfusick is offline
post #221 of 771 Old 01-17-2015, 07:35 AM - Thread Starter
dtsdig's Avatar
Liked: 1387
See above. That's basically what I'm doing except with furring strips and screws. Brads won't hold this stuff down under tension.
Hopefully I'll have an update with a picture of the process later today.
post #222 of 771 Old 01-17-2015, 10:42 AM
Boxozaxu's Avatar
Quoted: 512 Post(s)
Liked: 352
The nail won't hold the panel under tension. You end up with the nail sticking out of the mdf and a panel with a hole in it. Happened to me. I had to quickly grab some tin snips and trim the nail head and try and make it work without the nails. Then I spent some fun time cleaning PL off my tin snips.
EDIT: Sorry, I see dtsdig already explained this in a later post.
Boxozaxu is offline
post #223 of 771 Old 01-21-2015, 08:32 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
I am anxious for the next update and how this turns out.
Mfusick is offline
post #224 of 771 Old 01-26-2015, 07:47 AM - Thread Starter
dtsdig's Avatar
Liked: 1387
Ok, got some work done over the weekend. After 4 hours of scraping and sanding, I had the one cabinet back to its original state with the addition of some nicks and bruises. I ended up buying a new scraper blade for my Fein Multimaster and that worked way better than using a chisel like I had been. The big lesson here once again...don't use PL if there's any chance you're going to f-up and have to remove it.
No messing around this time. Almost 100 screws later and Titebond II:
Starting from the baffle and working my way back was great although it was a ton of work driving all the screws simply because the screws I was using are somewhat hard to get started through the hardboard. It's called hardboard for a reason! Lol
I'll pull the furring strips and screws out tonight and see where we ended up. I had excellent squeeze out across the entire lengths of the shelves this time so I'm confident I'll be able to progress normally now.
post #225 of 771 Old 01-26-2015, 10:17 AM
Quoted: 55 Post(s)
Liked: 69
Any issues with the screws cracking the MDF?
post #226 of 771 Old 01-26-2015, 11:09 AM - Thread Starter
dtsdig's Avatar
Liked: 1387
I had no issues with cracking. I used SPAX #6 1" wood screws that are made to use with "no drilling" for all of the furring strips into the edges of the braces. I tested them out on the edges of some scrap 3/4" MDF and had no cracking at all. For screwing the plywood L-bracket to the edge of the baffle, I used SPAX #8 2.5" screws and pre-drilled; had no issues. Even the 1" screws drove in hard and squeezed the materials together nicely with no stripping of the wood. Unless I have a drywall project to do, I've used the SPAX screws exclusively for 3 years now. They rock!
post #227 of 771 Old 01-26-2015, 02:44 PM
Quoted: 55 Post(s)
Liked: 69
Yeah thats all I use for anything that needs holding power. Used them to mount my sub, projector, and screen. Just at the same stage as you are and after the finger accident, Im paranoid something else is going to go wrong
post #228 of 771 Old 01-26-2015, 07:49 PM - Thread Starter
dtsdig's Avatar
Liked: 1387
Yow! Man! I didn't see the pic of your finger until I checked on my phone tonight (my stupid work computer pretty much blocks everything now). That looks pretty brutal. I hope it heals well for you.
I took out the screws tonight and the first layer looks great this time. Nice and even, totally solid. Maybe Thursday I'll get to do the other side.
post #229 of 771 Old 01-28-2015, 02:16 PM - Thread Starter
dtsdig's Avatar
Liked: 1387
From talking with @aaronlinkous , I am going to pick up this stapler tonight and see if it will work in place of 90 screws.
http://www.homedepot.com/p/RIDGID-1-...stomer_reviews
We'll see what happens! Worst case scenario, I will have added another nice tool to my collection.
post #230 of 771 Old 01-28-2015, 04:33 PM
Quoted: 105 Post(s)
Liked: 56
I wonder if you staple/nail at an angle with the staples opposing each other, will they be less likely to pull out?
The nice thing about screws is that you can screw the panel on with glue and when the glue dries you can pull the screws back out so you can use them again.
post #231 of 771 Old 01-28-2015, 08:22 PM - Thread Starter
dtsdig's Avatar
Liked: 1387
I bought the stapler and experimented a bit. I think it's gonna work great for the outer layers but I decided I would just use the screws again tonight. I was a little better prepared this time around too. Like I said before, 100 screws is brutal to put into hardboard in such a short amount of time, but it turned out great. First layers on one box are done!
post #232 of 771 Old 01-28-2015, 08:24 PM - Thread Starter
dtsdig's Avatar
Liked: 1387
post #233 of 771 Old 01-28-2015, 08:56 PM
likelinus's Avatar
Quoted: 144 Post(s)
Liked: 58
Are you certain this isn't due to the use of solid wood in furniture and its tendency to expand and contract with the change in weather and humidity?
Additionally, most of the DIY speakers are being made with MDF or plywood with is a manufactured product and doesn't exhibit these issues. Id love to see more info on this subject. Honestly, Ive never used PL or known anyone who has. I see it here occasionally, but I assumed it was due to inexperienced woodworkers with cuts not very precise. That happens a lot with new woodworkers.
likelinus is offline
post #234 of 771 Old 01-28-2015, 11:55 PM
Quoted: 105 Post(s)
Liked: 56
DTS, your system does seem to be working really well. Nails are extremely strong though. I tear apart pallets for miscellaneous woodworking projects around the house and the boards will often start to split before the nails will start to pull out. I've broken 2x4 lumber trying to pry pallets apart.
I'll be curious to see how the staple gun compares. Make sure you tune the hammer depth correctly otherwise you'll end up with a staple/nail head slightly higher than the surface of your woodwork. Slightly lower may be good in your case.
post #235 of 771 Old 02-27-2015, 05:44 AM
Quoted: 34 Post(s)
Liked: 4
Just read through this whole thread and what a build. Very impressive.
Any updates? I know its been ridiculously cold lately around here, good to find more local guys.
I've got a two part epoxy at home that has a pretty long working time, I think more than 30 min if I recall. I'll have to look when I get home.
tuxedocivic likes this.
EricBurns is offline
post #236 of 771 Old 02-27-2015, 08:35 PM
Boxozaxu's Avatar
Quoted: 512 Post(s)
Liked: 352
Who has time for speaker builds? We're all busy shovelling snow up here in the north east.
Boxozaxu is offline
post #237 of 771 Old 02-27-2015, 11:08 PM
Quoted: 105 Post(s)
Liked: 56
I feel like I'm pretty much the only person on this forum who lives where it doesn't snow on their house.
post #238 of 771 Old 02-28-2015, 04:14 AM
Black adder's Avatar
Quoted: 16 Post(s)
Liked: 8
Has not snowed at my house all winter and I live in northern Utah.
Black adder is offline
post #239 of 771 Old 02-28-2015, 05:13 AM - Thread Starter
dtsdig's Avatar
Liked: 1387
Thank you! I do have some updates but I've got to snap some pics first. So are you in Rochester?
I gave up shoveling years ago! Snowblower all the way!
Lol, I'm guessing Popalock is not getting any snow either!
post #240 of 771 Old 02-28-2015, 10:39 AM
Quoted: 34 Post(s)
Liked: 4
Yepp, I'm over by the Garden Factory in Gates.
How do you plan on veneering everything? Using clamps or a vacuum system?
