Full Vertical MArty 15hz or mini 15hz - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #31 of 45 Old 07-23-2014, 10:52 AM
Sibuna's Avatar
Quoted: 391 Post(s)
Liked: 469
donny, nice work.
how would you suggest that I learn sketchup?
for now, just the basics, like being able to draw a subwoofer enclosure like you posted above.
these tutorials are very helpful
http://sketchupforwoodworkers.com/
LTD02 likes this.
Sibuna is offline
post #32 of 45 Old 07-23-2014, 01:48 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
chalugadp -> Again I'm a noob, I just want to make sure... There are two slot ports? One on the bottom and one on the back? The 2 slot ports connect to make one long large port?
Smittyfit is offline
post #33 of 45 Old 07-23-2014, 02:19 PM
chalugadp's Avatar
Quoted: 1684 Post(s)
Liked: 1573
Watch the video. It all makes sense.
chalugadp is offline
post #34 of 45 Old 07-23-2014, 03:31 PM
kevings's Avatar
Quoted: 341 Post(s)
Liked: 533
smitty,
the dimensions for the mini marty and the full size marty are a bit different. Do you still want the info for the full ( the pm you sent me today ) , because it looks like a few post up your going with the mini marty?
Either design will work and if your building 2 that will be even more awesome.
kevings is offline
post #35 of 45 Old 07-23-2014, 06:20 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
kevings -> I feel bigger is usually better, and my wife does not care.
Please provide me with the cut sheet.
chalugadp -> Could I get a link to the video, I've been trying to find it on youtube with no success.
Thanks!!
post #36 of 45 Old 07-23-2014, 06:38 PM
chalugadp's Avatar
Liked: 1573
Thanks!!
Go to new to diy sticky. I just posted it there.
post #37 of 45 Old 07-24-2014, 02:41 AM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
chalugadp -> AMAZING, we all thank you greatly!
post #38 of 45 Old 07-24-2014, 05:50 PM
kevings's Avatar
Quoted: 341 Post(s)
Liked: 533
Thx chaluga for posting it.. I just left on a trip to Ohio this morning and I didn't want to hold up smitty from getting started.
kevings is offline
post #39 of 45 Old 07-24-2014, 06:05 PM
chalugadp's Avatar
Liked: 1573
Originally Posted by kevings View Post
Thx chaluga for posting it.. I just left on a trip to Ohio this morning and I didn't want to hold up snotty from getting started.
I just got back from two days away. I go to a known hotspot ( usually 100° and dry) but it rained cats and dogs. Grrrrrrr.
post #40 of 45 Old 07-24-2014, 06:09 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
chalugadp -> After watching your video... I think I'm going to make the same one you made, but the full version. I will not make it vertical, yet use these as stands for my speakers.
I then will make a new TV stand so everything fits on my short wall.
Your video and another AVS picture post really helped me understand the slot. I now know it is a port on the bottom and the back, to increase the overall length, and if it does but up 100% I can just use the caulking to make it flush.
One odd questions I have... How do you connect the speaker to the inuke... I didnt watch the entire video yet. I'm guessing it will be in there.
Also if you could tell me ALL the connection and material (minus the tools) I need that would really help.
As well will a staple gun work instead of the nail gun? I have no nail gun... Also will a screw work? I can borrow a drill...
Thanks a lot man!!
post #41 of 45 Old 07-24-2014, 06:16 PM
chalugadp's Avatar
Liked: 1573
Thanks a lot man!!
Staple gun won't work. Glue and clamps work , its just a lot slower. You need speakon cables from monoprice and one of these
https://www.parts-express.com/neutri...mount--092-054
post #42 of 45 Old 07-24-2014, 08:05 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
chalugadp -> Is that everything I need for sure? I want to make my list and order all when the SI woofers are in stock.
Can I use a drill and screws instead of the nail gun?
Thanks a lot for the support dude!!
post #43 of 45 Old 07-25-2014, 12:18 PM
Smittyfit's Avatar
Quoted: 83 Post(s)
Liked: 27
chalugadp -> If I use the same cutsheet as you posted above but just make it 8 inches longer, would I need to change the port lengths or no? I wish to keep the same tuning as you listed above.
post #44 of 45 Old 07-25-2014, 12:47 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
yes, you'd have to change the port length otherwise tuning frequency would be higher. Make the full marty, you have the space, it's worth it. You won't have to change anything from the design.
Bassment is offline
post #45 of 45 Old 09-04-2019, 09:36 AM
Schurter's Avatar
Can someone post the link to the YouTube videos
Very interested in watching
Schurter is online now
