Help with first DIY: DO SI 18 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 142Likes
post #31 of 603 Old 06-24-2014, 02:23 PM
Mike Garrett's Avatar
Quoted: 13987 Post(s)
Liked: 11668
Originally Posted by chalugadp View Post
How much bass you need to be happy. I had one 10" puny sub 18 months ago and now I am putting four 15 inch sub's in my living room. Probably good to start with one box. It may be all you need.
Famous last words around here. He will be back for more.
GizzeGutten likes this.
Mike Garrett is online now
post #32 of 603 Old 06-24-2014, 02:26 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5986 Post(s)
Liked: 5123
Yup.
Dare I throw out one of my 'famous' predictions?
Who wants to put in their over/under?
Scott Simonian is offline
post #33 of 603 Old 06-24-2014, 03:46 PM - Thread Starter
ambesolman's Avatar
Quoted: 1173 Post(s)
Liked: 986
Yup.
I definitely wouldn't rule out the possibility of coming back for seconds. I've enjoyed my hsu so much that it just makes the craving for more bass even stronger. Hearing beast's setup really put into perspective how much I'm missing out on below the hsu's admirable low end capabilities. I want to go lower and louder and DIY seems to be the best direction for the money, which will continue to be in short supply for the next year til I finish school.
Thanks for the help this far and don't be afraid to throw out more tips and suggestions as I can use all the help I can get!
Btw, I'm not understanding winisd enough to figure out what kind of output and extension I can expect to get once this thing is done. Can anyone help me with this?
Sent using Tapatalk since the mobile version is still 👎
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is offline
post #34 of 603 Old 06-24-2014, 04:10 PM
Bass Enabler
Liked: 5123
I can't upload my sims as fast but a quick run through in Unibox shows (with 1kw per driver) roughly [email protected], [email protected], [email protected], [email protected] and up. All estimated 1m distance.
That's just .... one ...of these subs you want to build.
ambesolman likes this.
post #35 of 603 Old 06-24-2014, 04:14 PM - Thread Starter
ambesolman's Avatar
Liked: 986
Thanks Scott
That's not too bad! How low?
post #36 of 603 Old 06-24-2014, 04:19 PM
Bass Enabler
Liked: 5123
Originally Posted by ambesolman View Post
Thanks Scott
"How low" what? Extension? It's sealed so it will extend as far down as your electronics allow. So pretty much single digits, bro. With sealed you shape the response with EQ DSP.
Add +6dB to all those numbers when you make a second. And also down low extension will be boosted because you will be in your house and not in a field on top of 100ft pole.
post #37 of 603 Old 06-24-2014, 06:34 PM - Thread Starter
ambesolman's Avatar
Liked: 986
REALLY?!?! Fook me! This was the part of DIY I didn't really understand...the "how" you get the super low extension without having a papalock number of drivers and tens of thousands of watts or if that was a requirement. And you're telling me I can get there (to an extent) with one box, 2 18s and a <$300 amp? That's the !
post #38 of 603 Old 06-24-2014, 10:06 PM
Bass Enabler
Liked: 5123
Yup.
Welcome to DIY audio, my friend. It's good to have you.
I must warn you though.... this is a new kind of addiction. Good news is that we are in this together. You are not alone.
post #39 of 603 Old 06-24-2014, 11:24 PM - Thread Starter
ambesolman's Avatar
Liked: 986
Thanks...you're not gonna try and hug me now are you?
post #40 of 603 Old 06-24-2014, 11:39 PM
Bass Enabler
Liked: 5123
post #41 of 603 Old 06-25-2014, 08:06 AM
beastaudio's Avatar
Quoted: 5810 Post(s)
Liked: 5668
You got a little taste for what is out there, 4 18's in your space will rock
beastaudio is offline
post #42 of 603 Old 06-25-2014, 08:53 AM - Thread Starter
ambesolman's Avatar
Liked: 986
I'm hoping TWO will rock...
post #43 of 603 Old 06-25-2014, 09:00 AM - Thread Starter
ambesolman's Avatar
Liked: 986
Goal for the day...Redesign the box to get accurate dimensions to create a cut sheet
post #44 of 603 Old 06-25-2014, 09:20 AM
Bass Enabler
Liked: 5123
Oh fo sho..... two enclosures with four 18's total would totally rock!
post #45 of 603 Old 06-25-2014, 11:42 AM
popalock's Avatar
Quoted: 1508 Post(s)
Liked: 2105
Gorilla has a nice cutsheet for his DO boxes in his thread. Would work perfectly for your situation... I think?
Give his thread a look. It's buried in there somewhere.
popalock is offline
post #46 of 603 Old 06-25-2014, 11:52 AM
beastaudio's Avatar
Liked: 5668
that cutlist program with delphi linked above is pretty easy, but I have honestly gotten better results using its manual placement option. Took more cuts, but I was able to save almost 2 sheets of wood between all 4 boxes.
post #47 of 603 Old 06-25-2014, 11:54 AM - Thread Starter
ambesolman's Avatar
Liked: 986
Will check it out, thanks.
How much extra room is optimal around the driver when it's recessed? 1/8"? 1/4"?
post #48 of 603 Old 06-25-2014, 11:57 AM
chalugadp's Avatar
Quoted: 1686 Post(s)
Liked: 1578
I like it pretty close , no more then 1/8"
chalugadp is offline
post #49 of 603 Old 06-25-2014, 12:35 PM - Thread Starter
ambesolman's Avatar
Liked: 986
Ok. So Yeah without the gasket it's 18.25", so if I make it 18.5" that should put an extra 1/8" all the way around it. States the cutout is 16.7", that'll be the cutout for the innermost diameter correct?
Popalock, found your GUM thread
post #50 of 603 Old 06-25-2014, 01:13 PM
beastaudio's Avatar
Liked: 5668
post #51 of 603 Old 06-25-2014, 01:26 PM
popalock's Avatar
Liked: 2105
Me likes it tight too. Just make sure to measure measure measure. It's not a huge deal if you do your outer baffles a touch larger. OTOH, if you go a bit too small it's a real b!tch if you have to sand the cutout to get the driver to fit.
Scott Simonian and Maklar like this.
popalock is offline
post #52 of 603 Old 06-25-2014, 01:37 PM
beastaudio's Avatar
Liked: 5668
^^^^ +11ty billion
post #53 of 603 Old 06-25-2014, 02:38 PM - Thread Starter
ambesolman's Avatar
Liked: 986
Good point. May go 18 5/8" for the outer baffles then since I'm planning some sweet GUMs
So after sketchup was giving me a headache I just decided to draw it (thanks beast). Here's the drawing with associate measurements. The four sides will be sandwiched btw the top and bottom panels. Will also do a round over on all edges.
Y'all mind dbl checking my measurements?
post #54 of 603 Old 06-25-2014, 03:14 PM
beastaudio's Avatar
Liked: 5668
Looks good to me. I typically like to have all 4 edges like you have on the sides do that on the front where the inner baffle mounts inside all 4 sides, and then the outer baffle mounts outside all 4 sides. It provides a great seal when done right but you have to make sure and flush trim on the inner baffles before you install the outerbaffle to ensure an airtight seal between the two.
post #55 of 603 Old 06-25-2014, 03:48 PM - Thread Starter
ambesolman's Avatar
Liked: 986
So you're saying sandwich everything (front/back and inner baffles) btw the top and bottom except for the just the outer speaker baffles?
Or simply sandwich everything btw the sides with the speakers?
post #56 of 603 Old 06-25-2014, 04:18 PM
beastaudio's Avatar
Liked: 5668
Ok, so how you have it right now, the side panels fit where the top/bottom, front and back all come out to the edge of the box and the side panels fit inside all four. What I was saying is I typically have the front (and rear for dual opposed) inner baffles mounted this way. So the inner baffle fits inside the top/bottom and sides, and then the outer baffle is mounted adding 1 1/2" inches on each dimensions so it lays completely over top the inner baffle and sides/top-bottom. Capiche?
post #57 of 603 Old 06-25-2014, 04:29 PM - Thread Starter
ambesolman's Avatar
Liked: 986
I think I edited my post while you were writing yours.
So sandwich everything btw the outer baffles, correct?
post #58 of 603 Old 06-25-2014, 04:40 PM
chalugadp's Avatar
Liked: 1578
Going to make a dedicated sketchup video tutorial for speaker cabinets soon
post #59 of 603 Old 06-25-2014, 04:54 PM - Thread Starter
ambesolman's Avatar
Liked: 986
That'd be nice. I watched a video by Car Audio Fabrication on YouTube that was a lot of help. It's the cutout that kept kept giving me issues because he breezed through the deletion after using the push/pull. It kept leaving me with a circle on the baffle instead of the cutout. No idea how I did it the first time.
So when you make your video, go SLOW on that part
post #60 of 603 Old 06-25-2014, 04:57 PM
chalugadp's Avatar
Liked: 1578
I already have some tutorials on my YouTube channel. Its video sub build channel.
