FI SP4 18" x4 Sonosub Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #31 of 40 Old 08-01-2014, 10:25 AM
atabea's Avatar
Quoted: 749 Post(s)
Liked: 636
Originally Posted by pdxrealtor View Post
Thx ^^
When's your build thread going up?
Got all my circles cut and have even inserted the end pieces----thanks to your suggestion to hammer them in place from the opposite ends. Will take some photos as soon as my son returns my camera. One thing is clear though; sonosubs are way easier to build than regular boxes!!. Far less weight, no internal bracing needed, and way easier to move around by yourself. Couldn't move my Marty without help. If there are no performance related downsides, and provided you have the height to accommodate them (if you are going LLT style), I am surprised we don't see more sonotube builds around these parts.
pdxrealtor likes this.
atabea is online now
post #32 of 40 Old 08-01-2014, 10:47 AM - Thread Starter
pdxrealtor's Avatar
Quoted: 156 Post(s)
Liked: 154
Good deal.
I always felt the same way about them being easy to build and maneuver. The circles are a bit repetitive and time consuming but they're not hard to route out. I also think they are more stealth for corners.
pdxrealtor is offline
post #33 of 40 Old 08-01-2014, 11:45 AM
atabea's Avatar
Quoted: 749 Post(s)
Liked: 636
^^^^So true about the repetitive nature of cutting those circles---having to make 3 or 4 passes for each circle is brutal---and the dust----fugedaboutit!. But once you get past that stage, it's all downhill.
post #34 of 40 Old 09-08-2014, 03:50 PM
Skorzeney's Avatar
Quoted: 14 Post(s)
Liked: 24
If you don't like the multiple passes with a router, try something like a Rotozip. I made my sonotube sub many years ago using a Rotozip and a homemade circle jig, in one pass for each circle. My Adire Audio Tempest sonotube is still running great!
Skorzeney is offline
post #35 of 40 Old 09-08-2014, 07:59 PM
Quoted: 143 Post(s)
Liked: 60
What is the volume in each of those tubes?
Did you end up going sealed?
jake515 is offline
post #36 of 40 Old 09-09-2014, 12:38 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 156 Post(s)
Liked: 154
~ 4 cubic feet after driver and bracing. Yes, mine are sealed.
post #37 of 40 Old 09-09-2014, 07:47 PM
basshead81's Avatar
Quoted: 312 Post(s)
Liked: 8756
So how things going PDX? Been a long journey for you....have you finally satisfied your bass needs? I would think 4 IPR-7500's with those FI 18's should get the job done.
basshead81 is offline
post #38 of 40 Old 09-10-2014, 08:58 AM
MKtheater's Avatar
Quoted: 2326 Post(s)
Liked: 2272
Any IPR 7500's for sale?
MKtheater is online now
post #39 of 40 Old 09-10-2014, 09:31 AM - Thread Starter
pdxrealtor's Avatar
Quoted: 156 Post(s)
Liked: 154
Good - thx for asking. Pretty happy with the setup as a whole. Ended up with more amps than I really wanted to have but it sounds so much better with the extra headroom it was worth it.
MK- no more IPR 7500s. I just sold the last one.
post #40 of 40 Old 09-10-2014, 09:53 AM
jbrown15's Avatar
Quoted: 2524 Post(s)
Liked: 1997
I thank you for that!
I love this amp
jbrown15 is offline
