Chalugadp 1099 Curved CC Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #31 of 231 Old 08-02-2014, 11:30 PM - Thread Starter
chalugadp's Avatar
Quoted: 1684 Post(s)
Liked: 1574
Yeah I like.the rear ported. Good idea. The cutouts I drew were not to scale . I am going to post a side view so you can see top curve better.
chalugadp is offline
post #32 of 231 Old 08-02-2014, 11:36 PM
LTD02's Avatar
Quoted: 3002 Post(s)
Liked: 3753
the assymetrical look of the front ported is a crime against nature. :-)
Listen. It's All Good.
LTD02 is offline
post #33 of 231 Old 08-02-2014, 11:41 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Here's side view
If I move ports to back I would have to do this
Assuming that is fine .
post #34 of 231 Old 08-03-2014, 08:43 AM
Boxozaxu's Avatar
Quoted: 513 Post(s)
Liked: 352
that's pretty cool donny.
spacing on that top port and the compression driver has been double checked?
couple random concepts.
that black line is simply to highlight the profile. i bet that you would get some takes for kits on the rear ported version.
What's the trade off with rear ports? Placement farther away from wall is probably one. Anything else?
Boxozaxu is offline
post #35 of 231 Old 08-03-2014, 10:25 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2230
Nothing wrong with rear ported. You could stack them on the back, if that makes sense. I don't know how to draw those things you guys do.
You could also do a round port, but you'd have to buy ports. I have some if you want Donny.
tuxedocivic is offline
post #36 of 231 Old 08-03-2014, 12:06 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
I will put them on the rear . Stock ports are fine. Not sure if I will stack them vertical or horizontal .
post #37 of 231 Old 08-03-2014, 01:13 PM
Boxozaxu's Avatar
Quoted: 513 Post(s)
Liked: 352
Thanks tux. I'm going to keep the idea open for my build.
This leaves the problem of blocking the existing ports but I would imagine it wouldn't be that hard to use the existing baffle as a template for making some port plugs. Some wood glue and you have your new modified nonported baffled.
Boxozaxu is offline
post #38 of 231 Old 08-03-2014, 01:17 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Yup,
Will trace out port plugs.
post #39 of 231 Old 08-04-2014, 09:52 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Have some Martycube's to cutout and then can start on this. Still waiting for that glorious email that says 1099 have shipped.
post #40 of 231 Old 08-05-2014, 05:59 AM
DekPM19's Avatar
Quoted: 221 Post(s)
Liked: 70
I have been reading these 1099 build threads with interest trying my hand at building some. I have a question about what do you build are use for surrounds with this speaker.
Allen
DekPM19 is online now
post #41 of 231 Old 08-05-2014, 06:16 AM
BCRSS's Avatar
Quoted: 544 Post(s)
Liked: 527
Allen
I been contemplating this same thing. I have the Ascends 170's now but am finding that they are not performing to my expectations. Now thinking that maybe the Volt 8 or 10 would be a better fit with the 1099's. Problem I see is the mounting of the Volt's, with either a 12x12 or 14x14 size to work with, that will take a pretty hefty mount on the wall in order to angle or swivel the box to listening position.
BCRSS is offline
post #42 of 231 Old 08-05-2014, 06:26 AM
MX48's Avatar
Quoted: 98 Post(s)
Liked: 56
These will hold them if they will work in your room. I am using 2 to hold some surrounds heavier than the volts.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Hope this helps,
Moto
BCRSS likes this.
MX48 is offline
post #43 of 231 Old 08-05-2014, 07:09 AM
Yukichon's Avatar
Quoted: 193 Post(s)
Liked: 100
I'm going for the Volt 10's with the angled box, so will be keen to see how you mount yours
Yukichon is offline
post #44 of 231 Old 08-05-2014, 07:16 AM
BCRSS's Avatar
Quoted: 544 Post(s)
Liked: 527
Hope this helps,
Moto
Thanks, I may look into those. Can you tell me how far off the wall they hold the speaker at?
BCRSS is offline
post #45 of 231 Old 08-05-2014, 07:22 AM
MX48's Avatar
Quoted: 98 Post(s)
Liked: 56
Roughly 5".
However mine are hanging from the ceiling. I never had them on the wall so am not positive those ball and socket pivots would hold a heavy speaker at 90 degrees. They might I just don't use them like that.
I have seen other people link this mount so maybe some of them will see this and comment if they have them on the wall and angled.
Sorry I can't be of more help for the wall.
MX48 is offline
post #46 of 231 Old 08-05-2014, 07:24 AM
DekPM19's Avatar
Quoted: 221 Post(s)
Liked: 70
I was looking at the volt 8 for rear surrounds. I thought cutting a extra back and mounting it to the wall then drilling through the speaker into the wood plate mounted on the wall and screwing it in. It wood just end up with a thick back.
Allen
post #47 of 231 Old 08-05-2014, 07:30 AM
DekPM19's Avatar
Quoted: 221 Post(s)
Liked: 70
I guess some volt 10 for the sides would work but I was wandering if their was a smaller speaker like the 1099 that has a horn type of set up that would match the sound of the 1099 better. Now the rear surround the 8 or the 10 would work but jbl has a speaker the 8340 I think that has a horn set up that would maybe work also. But A DIY version would be better that was designed to match the 1099 would be better because they would look like the same speaker from the same group.
Allen
post #48 of 231 Old 08-05-2014, 07:35 AM - Thread Starter
chalugadp's Avatar
Liked: 1574
Unless your listening to 5 channel music matching 1099's not a big concern. There isn't a matching surround. For movies the volts seem to be a very good choice due to the fact there isn't a waveguide. Surround speakers are supposedly better when they don't have pin point location. Want that diffuse sound.
post #49 of 231 Old 08-05-2014, 08:52 AM
DekPM19's Avatar
Quoted: 221 Post(s)
Liked: 70
Volt 10 for side surrounds and Angled volt 8 for rear surrounds. In fact I think I will get the volt 8 first.
Allen
post #50 of 231 Old 08-06-2014, 06:46 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
My 1099 shipped today. Will start on cab Friday. Excited.
ambesolman likes this.
post #51 of 231 Old 08-06-2014, 06:52 PM
Robert Jones II's Avatar
Quoted: 113 Post(s)
Liked: 64
Originally Posted by chalugadp View Post
my 1099 shipped today. Will start on cab friday. Excited.
yes!
Robert Jones II is offline
post #52 of 231 Old 08-06-2014, 07:02 PM
jbrown15's Avatar
Quoted: 2524 Post(s)
Liked: 1997
So do you think you'll be able to get that across the border without having to pay any taxes on it?
jbrown15 is offline
post #53 of 231 Old 08-06-2014, 07:07 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
No problem. My system is rock solid.
post #54 of 231 Old 08-06-2014, 08:38 PM
jbrown15's Avatar
Liked: 1997
What's your licences plate number again? I think I'll call in a little tip off to the border guards......lol
jbrown15 is offline
post #55 of 231 Old 08-06-2014, 08:46 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Notice I didn't say what my system is .... dont want others using it
post #56 of 231 Old 08-07-2014, 05:59 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Well my car is in the shop so I can't cut out my two Martycube's I was going to do today. The left me able to start with the 1099 since I had just a little mdf left.
Cut the bottom, back and 4 sides to measurement. Nothing magical there. Then did layout for side profile.
The circles on the vertical lines are measurements from sketchup drawing. I measure a distance across and down on the curve. Then get several points I can free hand draw the curve. Next I cut curve with jigsaw in one cut
Next I put second piece on top of my template for router flush.
Flush trim all pieces to same template.
Then assemble bottom to back, and sides to back/bottom.
My son is holding in center supports. I can't put them in until I get my 1099 baffle (Tuesday)
All total about 90 minutes. Next I have to buy 1/8" mdf and rough cut a little big. Once I have baffle then glue in supports and glue down the top. Then line with foam and attach baffle. Finally do veneer.
post #57 of 231 Old 08-07-2014, 07:56 PM
sooly1's Avatar
Liked: 35
Drool, subbed, jealous, in that order. Nice work so far!
sooly1 is offline
post #58 of 231 Old 08-07-2014, 08:11 PM - Thread Starter
chalugadp's Avatar
Liked: 1574
Only using skillsaw, laminate router, and jigsaw. All you need for this. I used brad nails but it's a luxury. I hope people see its not difficult. Toughest thing so far is single cut for pattern. The 10 000 cuts I've made with bandsaw/jigsaw make it easier for me. For a rookie you may need to do some practice cuts to get the feel of the curve.. I would love to see more people try curved builds if they like the look.
post #59 of 231 Old 08-07-2014, 08:32 PM
Quoted: 113 Post(s)
Liked: 64
The work you've done so far does seem completely accessible. I plan on doing a straight box on mine because I like that look, but I really enjoy watching curved builds. I especially like learning the techniques involved to accomplish this. Before watching dts's build, and now yours, the curve seemed like such an advanced class topic. Now I actually feel like I could do it!
chalugadp likes this.
post #60 of 231 Old 08-07-2014, 09:43 PM
RickD1225's Avatar
Quoted: 317 Post(s)
Liked: 1688
Donny, you make this stuff look so easy. I know it isn't easy, but seeing someone do it and give tips almost makes me think I should give it a whirl. First I want to get veneering figured out.
Have you figured out where the ports are going, on the back?
Spoiler!
RickD1225 is offline
