Does tite bond lose its sticky? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-14-2014, 06:44 AM - Thread Starter
04rex's Avatar
Quoted: 295 Post(s)
Liked: 63
I have had a big bottle of tite bond laying around for about 2 years. I used it to build my sub boxes. It is closed. Does it lose its power after a while or is it safe to still use it to build a few sub boxes again?
04rex is offline
post #2 of 8 Old 08-14-2014, 07:28 AM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 214
It depends. How was it stored(basement, outside, etc...) and which Titebond is it? http://www.titebond.com/woodworking_glues.aspx
Face2 is offline
post #3 of 8 Old 08-14-2014, 08:35 AM - Thread Starter
04rex's Avatar
Quoted: 295 Post(s)
Liked: 63
Tite bond II. Stored in a garage on a shelf. I live in Canada.
04rex is offline
post #4 of 8 Old 08-14-2014, 09:42 AM
Face2's Avatar
Quoted: 355 Post(s)
Liked: 214
Throw it away.
Face2 is offline
post #5 of 8 Old 08-14-2014, 09:58 AM
mtg90's Avatar
Quoted: 735 Post(s)
Liked: 1509
Storage life is 24 months at 75 degrees F, your garage probably is not so consistent but the glue is freeze/thaw stable. Before you throw it out try gluing a couple scraps together, if the consistency is good and it dries and holds well it should still be ok.
mtg90 is offline
post #6 of 8 Old 08-14-2014, 03:47 PM
Boxozaxu's Avatar
Quoted: 500 Post(s)
Liked: 345
The 24 months is not a hard fast rule. If it's thicker and a darker yellow it's time to toss and get new. If it stills looks new it's ok to use.
Boxozaxu is offline
post #7 of 8 Old 08-14-2014, 05:47 PM - Thread Starter
04rex's Avatar
Quoted: 295 Post(s)
Liked: 63
Dang. Aight. It is too expensive so I will just get a new one. Thanks guys.
04rex is offline
post #8 of 8 Old 08-18-2014, 05:13 PM
t6902wf's Avatar
Quoted: 16 Post(s)
12 months max
I buy 55 gallons drums stored under ideal conditions. After 12 months it becomes questionable and not worth risking.
T6
Clearwave 4TSE and 4CC build thread
https://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
