MartySub FAQ - Page 167 - AVS Forum | Home Theater Discussions And Reviews
 1651Likes
Old 05-10-2019, 05:29 AM
Quoted: 34 Post(s)
Liked: 3
Originally Posted by Red Five View Post
Parallel on a NX6000D - potential death of amp at least fail safe shutdown. Series on a NX6000D - lots of fun bass! A 6000 is good down to a nominal 4 Ohm load. When a UM18 is wired in series it has a 4 Ohm nominal load, which is what you need to be stable on the NX
Whelp, that was an easy choice.. Thanks!
Bnaan is online now
Old 05-10-2019, 07:02 AM
Quoted: 45 Post(s)
Originally Posted by Leon! View Post
Did you end up getting one of these, and if so how has it been?
Ultimately went with the iNuke 6000dsp. I'm sure there's a willing guinea pig out there for the plate amp!
Leon! likes this.
lavakv is offline
Old 05-14-2019, 09:42 AM
Quoted: 34 Post(s)
Liked: 3
How important is lining the walls inside the Marty? Let's say I forgot this and glued everything together already, purely hypothetical of course, how bad would that be? Definitely required to get something in there through the driver hole, or not worth the effort? Again, hypothetically speaking.. I totally did not forget this..
Bnaan is online now
Old 05-14-2019, 09:47 AM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
It depends who you ask. If you are crossing under 100Hz, I would not worry about it.
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
Old 05-14-2019, 10:15 AM
Quoted: 34 Post(s)
Liked: 3
On my AVR you mean? I always set crossover to 80Hz.
Bnaan is online now
Old 05-14-2019, 10:17 AM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
That is correct.
Old 05-14-2019, 10:29 AM
rec head's Avatar
Quoted: 279 Post(s)
Liked: 244
I'm pretty sure that's how I did it on my cubes. Just went through the 18" hole. It was easy. Harder on the big Marty but it shouldn't be too bad if you've gotten this far. I wouldn't get crazy. If I couldn't reach something I would leave it.
rec head is offline
Old 05-15-2019, 01:46 PM
Quoted: 34 Post(s)
Liked: 3
Thanks for the replies!
Bnaan is online now
Old 05-18-2019, 03:11 PM
Quoted: 16 Post(s)
Liked: 0
hello. i have made dual full marty cabinets and drive im using is Um18-22. i have set high pass at 20hz , butterworth at 12db. now please tell me where should i set Threshold, Attack, release and frequency in Dynamic eq
in configuration where should i set Delay and peak limiter .
im asking these question cz when i play some songs the limit light blinks while the first green led stays stable and without moving the -6 and -3 light it just blinks the red limit light even when there was no bass. what this issue could be . hope someone can help me out to solve this issue. thanks
Zeeshantariq is offline
Old 05-18-2019, 04:24 PM
Quoted: 22 Post(s)
Liked: 8
I am building four 10.4 cubic feet Marty boxes with 1 UM-18 in each. I wired each of the coils in series for four 4 Ohm load boxes. Then I made a sereis splitter box to wire 2 boxes per channel on a NX6000D amp. That should make 8 Ohm loads on each channel of the amp.
Pics of the splitter box.
Name:	series speaker splitter wiring.png
ID:	2568432   Click image for larger version
Name:	series speaker splitter 4 out.png
ID:	2568434   Click image for larger version
Name:	series speaker splitter 2 in.png
subbuilds is offline
Old 05-18-2019, 04:27 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Dude, that's legit! I may have to do that at some point.
Sent from my SM-N960U using Tapatalk
subbuilds likes this.
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
Old 05-18-2019, 04:54 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
https://www.avsforum.com/forum/155-d...l#post27746249
-.5dbfs on the limiter is cool. Remember you need to add gain to counter the the high shelf filter.
Old 05-19-2019, 10:30 AM
Liked: 1
looking for advice on micro boxes .. ive just completed a full marty box and realise its way to big... so it has to go ...
i have a few questions regarding the micro cubes i plan on making 2.
1. what subwoofer is best suited for a micro ?
2. how well do the micro perform ?
3. will the inuke3000dsp power 2 ?
im coming from a 12" subwoofer with 500rms amplifier. (BK ELECTRONICS MONOLITH PLUS) UK made...
Gaz5 is offline
Old 05-19-2019, 12:12 PM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
Is the goal getting the absolute most out of that box? If so, I can sim some stuff when I get a chance.
Old 05-19-2019, 12:18 PM
Liked: 1
just looking to get more bass than i had with 2 subs instead of 1 and micro martys fit in my spaces perfect withpout having to move my fronts to close to the TV.....
Gaz5 is offline
Old 05-19-2019, 01:50 PM
Augerhandle's Avatar
Quoted: 1167 Post(s)
Liked: 1147
You really ought to fire up that Full Marty before deciding to throw all that work out the window. You just might make space concessions elsewhere once you've heard it.
asarose247 and Gaz5 like this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
Old 05-19-2019, 03:39 PM
Liked: 1
I actually might do that ...
Gaz5 is offline
Old 05-20-2019, 07:43 AM
Quoted: 39 Post(s)
Liked: 47
As I said on your FB post, might as well give that full Marty a listen before you move on! Hook it up and take a few measurements so you can compare the full with the cubes should you go that route. Personally I'd stick with the full.
ksmchristy is offline
Old 05-20-2019, 11:33 AM
Liked: 1
Thanks mate. i have decided to stick with the FULL and make some more movements around in the room....
im getting use to it being so big in the room now. i suppose in a few weeks ill be thinking "it could be bigger"
ksmchristy likes this.
Gaz5 is offline
Old 05-20-2019, 11:37 AM
Quoted: 90 Post(s)
Liked: 94
This is the way of things...
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Eosone RSF 600 - Micca M-8C for ATMOS - 2 @ VBSS End Tables
DIY 110" AT Screen
jevchance is online now
Old 05-21-2019, 02:28 AM
Quoted: 16 Post(s)
Liked: 0
thanks for the guide . btw whats high shelf filter ?
Old 05-21-2019, 05:31 AM
Red Five's Avatar
Quoted: 401 Post(s)
Liked: 450
In this case it will push the high pass filter below 20Hz. If your tune is 17Hz for instance, you would use HS12 20hz -4.0db setting to push the high pass down to 16Hz. For each -1.0db it roughly pushes the high pass down 1Hz. That reclaims a lot of low end response and gets the most out of the sub woofer.
Old 05-21-2019, 06:02 AM
rec head's Avatar
Quoted: 279 Post(s)
Liked: 244
You mean "I need 2"
rec head is offline
Old 05-21-2019, 12:21 PM
Liked: 1147
Where a High Pass filter rolls off to zero, a shelf filter rolls to a point and the continues at that level.
Look at the first graph Post 68 in the linked thread.
The yellow line is the signal shape from the High shelf filter, and the slope is what we use to influence the roll off of the High pass filter. The red line is the signal shape from the 20 Hz High Pass filter. Combining that with the shelf filter creates the target curve (green line).
A side effect of the negative high shelf setting is that while reshaping the high pass to go lower in frequency, it actually lowers the dB level of everything above it, so you need to counter that with the virtual gain control.
Looking at the graph again, the original signal level was 118 dB. While the shelf re-shaped the High Pass curve, in doing so it lowered the levels to 106 dB. Setting the virtual gain knob (in the Filter/Crossover tab) to plus 12 dB puts the levels back to normal. The graph is an extreme example. Your box is tuned to around 17 Hz, so you would set the high shelf at about -4 and the virtual gain at +4.
Zeeshantariq likes this.
Old 05-27-2019, 04:40 AM
Quoted: 16 Post(s)
Liked: 0
8) What are the flashing lights on the inuke amp for ?
Their are four lights for each channel. First three are orange (power lights) and top one is red (clipping light). During heavy bass scenes its common for three power lights to flash or stay on. The red clipping light should only flash maybe a couple times a movie for a brief time. If the clipping light is coming on for two seconds straight the amp is in serious distortion. Here is a simple guide to setting the amps gains to avoid clipping your amp.
[url]http[/QUOTE]
hello can u please re share or URL its no mention im interested doin the setting .thanks
Old 05-27-2019, 05:15 AM
Quoted: 16 Post(s)
Liked: 0
thanks for the detailed msg . sorry i was bit busy in work thats y took so many days to be back here hope u dont mind.
okay ill do it as u said but no offense the diagram and the details u have told these really hard for me to understand. im really feelig embarrass to asking stupidly but i hope someone can hold my hand to take me to my target . im sharning all the pics the check them out and of possible let me where should i set the setting . thanks
ID:	2572256   Click image for larger version
Name:	filters and crssovers.jpg
ID:	2572258   Click image for larger version
ID:	2572260   Click image for larger version
Old 05-27-2019, 05:37 AM
4fit?'s Avatar
Quoted: 75 Post(s)
Liked: 47
If you are referring to where to set the High Shelf filter.....in the PEQ tab, in your -4 filter, change your Type drop-down to HS12.
If you are referring to what to set all of your PEQ filters to, that isn't something that can be done without measuring your in-room response first.
Sent from my SM-G935V using Tapatalk
4fit? is offline
Old 05-27-2019, 03:00 PM
Quoted: 16 Post(s)
Liked: 0
thanks for the reply.. i have ordered UMIK-1 hopefully it will b delivered to me in 15days for rest of the filter v ccan set one ill share my response. till then as u have said i did it and pic attached plz confirm ive done it correctly or not . thanks
Old 05-27-2019, 03:19 PM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 721
As 4fit? mentioned, you want to set Filter 1 to HS12 (the one that is already set to -4dB).
https://www.avsforum.com/forum/155-d...z-dcx2496.html
4fit? likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
Old 05-28-2019, 12:27 AM
Quoted: 16 Post(s)
Liked: 0
I have few more things to understand .
what would be the figures to put . plz see the attachment
Name:	delay seting.jpg
