MartySub FAQ - Page 170 - AVS Forum | Home Theater Discussions And Reviews
 1677Likes
post #5071 of 5135 Old 09-27-2019, 09:27 AM
Red Five's Avatar
Quoted: 958 Post(s)
Liked: 773
Originally Posted by [email protected] View Post
I reloaded winsid but cant a port to the design.
Are you looking for a specific ported box design? I can come up with something in a few minutes.
Stormbreaker | WI HT Meet Thread | The Devastator Index | Mini Devastator Build
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.2.4 | A3070 | XLS 1502 | 3000DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Epson 5010e | 120" DIY AT Screen | 2x Mini Devastators
Red Five is online now
post #5072 of 5135 Old 09-27-2019, 09:49 AM
Liked: 0
Its in th post above. I loaded my driver but cant add a port to the box design
[email protected] is offline
post #5073 of 5135 Old 10-03-2019, 04:51 PM
Michael Mitten's Avatar
Quoted: 206 Post(s)
Liked: 215
I want to verify this is right. This is a mini marty with the port out the back. Is the port length correct? The same port cutlist length was used. 43"
Michael Mitten is offline
post #5074 of 5135 Old 10-03-2019, 09:33 PM
Augerhandle's Avatar
Quoted: 1394 Post(s)
Liked: 1355
looks good
Michael Mitten likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #5075 of 5135 Old 10-08-2019, 06:20 AM
Quoted: 394 Post(s)
Liked: 113
Please need some help. For lining the sub walls, can i use plain 2 inch foam instead off eggcrate foam?
Theater:JVC RS440, Elite 120". 7.1.4:RTi8, CSi5, FXiA4, RTiA3, 620-RT(4) & SVS PB12-NSD. Denon X4300H, UPA-700, Crown XLS1502 & XLS1000(2). Sony UBP-X800, Panasonic DP-UB424, Shield & ATV 4K. Lounge:Vizio M70-D3, Benq HT1075, & Elite 106". 7.1.4:RTi12, CSi5, RTiA1, TSx110, MC60(4), & RBH I-12. Marantz AV7702, Crown XLS1500, XLS1000(2) & Amp 100v2(2). Samsung UBD-K8500, LG BP440, Shield & ATV
shyyour is offline
post #5076 of 5135 Old 10-08-2019, 09:46 AM
Liked: 1355
Yes, as long as it's open cell foam (you can blow through it).
post #5077 of 5135 Old 10-08-2019, 12:38 PM
Quoted: 394 Post(s)
Liked: 113
Thanks a lot much appreciated
shyyour is offline
post #5078 of 5135 Old 10-16-2019, 11:19 PM
Quoted: 72 Post(s)
Liked: 4
Hi team - i am running two micro martys off a 3000dsp. Would swapping it out for a 6000dsp with double the power give me an upgrade?
SeargentPeppers is offline
post #5079 of 5135 Old 10-17-2019, 08:39 AM
Liked: 1355
What drivers? What impedance? What's the power required to get the drivers to xMax in those boxes?
post #5080 of 5135 Old 10-18-2019, 12:44 AM
Quoted: 72 Post(s)
Liked: 4
Dayton rss390ho-4, 4ohms, and no idea.
post #5081 of 5135 Old 11-12-2019, 10:24 AM
Colticus's Avatar
Quoted: 30 Post(s)
Liked: 41
Originally Posted by aron7awol View Post
Did you see my reply in the other thread?
Remove the limiter, you don't need it, and it's just going to make you hit the limit light before you're at full capability.
Then set your sub trim nice and low (around -10dB is good) and then increase the amp knobs until your subs are back at the level you want them to be. Then keep doing what you're doing with the RP1 race scene and see what happens with your limit lights. The low sub trim will protect you against AVR clipping and amp input clipping.
It's perfectly fine to hit the limit lights on the loudest hits. Even with the limiter "disabled" it still kicks in right at the point where the amp starts to clip. They designed it to always be a safeguard against hard clipping.
I searched your other post and found where you said to remove the limiter for the ST HST. But it has a rms rating of 2k where the Dayton he is using has a rms rating of 1k. So you still recommend removing the limiter even with the Ultimax 18s?
*Representing Team AVS*
- KillerPoptart -
Halo 2 Stats
Colticus is offline
post #5082 of 5135 Old 11-12-2019, 10:30 PM
nexus99's Avatar
Quoted: 183 Post(s)
Liked: 85
I did a few measurements of my dual Full Marty setup. My mic started clipping though so the attached file is where I maxxed out mic wise.... 16hz HPF in place. The blue line is the clipping measurement.
JDM World: https://www.youtube.com/jdmworld
GSG Devastator Build Eminence 21" https://youtu.be/DgtVxjg06to
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
post #5083 of 5135 Old 11-12-2019, 10:31 PM
nexus99's Avatar
Quoted: 183 Post(s)
Liked: 85
More details in here:
kevings likes this.
nexus99 is offline
post #5084 of 5135 Old 11-13-2019, 06:42 AM
Colticus's Avatar
Quoted: 30 Post(s)
Liked: 41
are you running a limiter on yours?
- KillerPoptart -
Halo 2 Stats
Colticus is offline
post #5085 of 5135 Old 11-13-2019, 07:42 PM
nexus99's Avatar
Quoted: 183 Post(s)
Liked: 85
I run a 16hz HPF under normal operation. Everything is done via miniDSP.
nexus99 is offline
post #5086 of 5135 Old 11-13-2019, 08:03 PM
Colticus's Avatar
Quoted: 30 Post(s)
Liked: 41
makes me feel a little better about increasing the nx6000d wattage limiter. If you aren’t running one and the subs are performing well, no reason to have such a low limited set on mine.
- KillerPoptart -
Halo 2 Stats
Colticus is offline
post #5087 of 5135 Old 11-27-2019, 10:35 AM
Fazzz's Avatar
Quoted: 145 Post(s)
Liked: 108
I'm adding two Marty Cubes with a UM18-22 drivers and am looking for some help to make sure I don't screw up the wiring. A couple questions:
- Do I need two RCA to XLR cables from the AVR to the iNuke? My AVR (Denon4300) has two outputs just wondering if I can run one and them use bi-amp mode on the iNuke.
- I get confused with all the series vs parallel stuff so wondering if someone can take a look at the picture below and let me know if I've laid things out correctly. I'm a visual person so this helped me visualize things.
Thanks in advance!
Name:	2 Marty Cube Wiring.jpg
rec head likes this.
Fazzz is offline
post #5088 of 5135 Old 11-27-2019, 11:09 AM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 866
You can do either. The Audyssey XT32 on your AVR-X4300 will set distance/delay separately for each sub, or you can handle that in the nu6k.
Your diagram is correct for a 4 ohm load to each channel.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5089 of 5135 Old 11-27-2019, 11:22 AM
Fazzz's Avatar
Quoted: 145 Post(s)
Liked: 108
Awesome. Thanks for the confirmation. You can never be too sure especially for a newb like myself.
Fazzz is offline
post #5090 of 5135 Old 12-02-2019, 07:42 AM
Red Five's Avatar
Quoted: 958 Post(s)
Liked: 773
The UM18 is a Cyber Monday deal
post #5091 of 5135 Old 12-02-2019, 01:33 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 545 Post(s)
Liked: 658
Anybody see the graph mentioned in FAQ post #1 that compares sealed and vented with the same driver and power?
Cam Man is online now
post #5092 of 5135 Old 12-02-2019, 02:07 PM
Liked: 1355
Yeah, but they're long gone. They all look pretty much the same though, with ported (blue) showing more SPL until tuning, and sealed (red) showing more very low, but at such low SPL, it doesn't matter anyway. Something like this:
Name:	Capture sealed vs ported.PNG
post #5093 of 5135 Old 12-02-2019, 02:44 PM
Cam Man's Avatar
Quoted: 545 Post(s)
Liked: 658
Thank you, sir!
Here's another question a colleague has about these: Any idea what the 2.83 V sensitivity of a finished (vented) "Mid" Marty (8.3 cubic feet) with a UM-18 would be?
post #5094 of 5135 Old 12-02-2019, 03:25 PM
Liked: 1355
Thank you, sir!
https://www.parts-express.com/pedocs...spec-sheet.pdf
post #5095 of 5135 Old 12-02-2019, 03:29 PM
Cam Man's Avatar
Quoted: 545 Post(s)
Liked: 658
Thank you. I am familiar with the sensitivity spec of the UM-18, but the cabinet has an impact on sensitivity...and I've just not seen anyone provide a "finished product" spec.
post #5096 of 5135 Old 12-02-2019, 03:38 PM
Liked: 1355
You can model it with those specs, but it should still be within 1 dB or so of the figure listed. That is a negligible difference. I used a different driver in a 10+ cu. ft. box, and it modeled within .34 dB of spec.
Cam Man likes this.
post #5097 of 5135 Old 12-12-2019, 08:30 AM
Liked: 1
is this the latest cut list for the fullsize marty?
Need someone to verify that this is the most recent cutlist fullsize marty
post #4599 from the Marty Sub FAQ
sorry can't post url or images since this is my 1st post
Joe
bikeboyjoe is offline
post #5098 of 5135 Old 12-14-2019, 07:03 AM
Liked: 2
I just want to say many thanks for this forum and all the people who have contributed. I just completed a full marty build with the UM18-22 driver for my system and all I can say is WOW! I'm not much of a wood-worker, but with a skillsaw and borrowed router, things came out pretty nice. I ended up painting it to match the wall colors, and my wife fully approves -- that's really all that matters!). I had a couple of issues with setting up the Behringer NX3000D (me being stupid!), but once things were dialed in, my wife came in to inform me I had knocked some pictures off the family room wall. I am mostly a 2-channel guy, and already had a sealed Craigsub from several years ago that I was using. But we recently moved to a new house where I was able to finally have my own dedicated listening room so I thought adding a little 'punch' for movies would be nice. It turns out that after spending the better part of a day setting things up, I am using the full Marty for 2 channel listening as well (I was very surprised to discover that I could use both subs for 2-channel music -- I ended up with them at 1/4 spacing along the front wall).
Again, thanks so much to all the folks who have contributed to this thread. I couldn't be happier, and last night, my wife insisted we watch the movie in 'my room' as opposed to the family room system -- that never happens!
Name:	IMG_2285_bracing and port.jpg
ID:	2653798   Click image for larger version
ID:	2653800   Click image for larger version
Name:	Full bracing.jpg
ID:	2653802   Click image for larger version
Name:	IMG-2359_front primed.jpg
ID:	2653804   Click image for larger version
Name:	Marty sub painted woofer on top.jpg
Name:	Marty sub painted.jpg
ID:	2653808   Click image for larger version
Name:	Marty sub installed.jpg
Steve Hanna and BCRSS like this.
bret Holley is offline
post #5099 of 5135 Old 12-14-2019, 08:10 AM
BCRSS's Avatar
Quoted: 536 Post(s)
Liked: 525
It certainly turned out looking great. Congrats on a project well done and welcome to DIY.
BCRSS is online now
post #5100 of 5135 Old 12-14-2019, 11:22 AM
rec head's Avatar
Quoted: 326 Post(s)
Liked: 307
Looks great but you must listen softly if you can keep stuff on top of the subs!
rec head is offline
