MartySub FAQ - Page 173 - AVS Forum | Home Theater Discussions And Reviews
 1685Likes
post #5161 of 5179 Old 03-23-2020, 09:38 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Originally Posted by johnson636 View Post
The carbon cone of the Ultimax subs is very attractive. I hate that I sold mine.
Stereo Integrity is working on something even cooler:
Will start as an option on the 18’s, may go to other sizes.
Chris
a77cj7 is offline
post #5162 of 5179 Old 03-23-2020, 09:40 AM
johnson636's Avatar
Quoted: 1533 Post(s)
Liked: 1027
Chris
I can't quite make out what the cone is made of
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5163 of 5179 Old 03-23-2020, 09:47 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Better?
Its a solid carbon fiber cone and dustcap.
Chris
johnson636 likes this.
a77cj7 is offline
post #5164 of 5179 Old 03-23-2020, 09:48 AM
N8DOGG's Avatar
Quoted: 1432 Post(s)
Liked: 1693
Chris
The dust cap lines are soooo close to lining up with the cone lines.... My God why!!!!
brian6751 likes this.
N8DOGG is offline
post #5165 of 5179 Old 03-23-2020, 09:52 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Lol, its not glued together. Dust cap is just sitting on the sample cone for pic.
The sample come had too stiff of a surround, but additional surround samples sent with the dustcaps were good. Last I heard from Nick he was planning on ordering the 18” cones, no idea on ETA in current situation though.
Chris
a77cj7 is offline
post #5166 of 5179 Old 03-23-2020, 11:24 AM
Augerhandle's Avatar
Quoted: 1445 Post(s)
Liked: 1421
Would look better as a carbon fiber cone with black dust cap. IMHO, to each his/her own.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #5167 of 5179 Old 03-23-2020, 11:29 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
MartySub FAQ
I’m sure that can be done once the cones arrive.
As can a carbon dustcap on a black cone. I believe Nick already has the dustcaps as well.
I like the all-carbon.
Chris
a77cj7 is offline
post #5168 of 5179 Old 03-23-2020, 06:27 PM
Quoted: 531 Post(s)
Liked: 453
Yup the cone on the UM18 is my favorite.
Trimlock is offline
post #5169 of 5179 Old 03-29-2020, 03:49 AM
Dbuns's Avatar
Quoted: 16 Post(s)
Liked: 0
Hey just wondering if anyone could provide plans and cut list for a Full Marty with a UM18-22.
I was considering 4 x VBSS, but figured I would go with 2 Full Marty’s and go the full 4 down the track.
Powering these two with a iNuke 3000.
Dbuns is offline
post #5170 of 5179 Old 03-29-2020, 05:49 AM
smcmillan2's Avatar
Quoted: 1067 Post(s)
Liked: 906
smcmillan2 is offline
post #5171 of 5179 Old 03-29-2020, 11:21 AM
jbrody's Avatar
Liked: 0
Ready to build
So Im going to build a Mini Marty this week with an ultimax 18. I have been playing with the Box volume excel spreadsheet. and the more I read the more I'm not confident in the port length.. I plan on a pretty standard dimension of the box. Just wanted to see if someone would look at he cut list and tell me I'm good or stupid haha thanks is advance.
Ok so I have never posted to AVS before and have a 5 post limit to get pictures included... My settings are just the standard minimarty from "avsforum.com/forum/155-diy-speakers-subs/1648673-martysub-faq-154.html#post57121996"
and the port length as of right not is 45 inches and I'm just not sure about that length
if that is best
Jason
Name:	Screen Shot 2020-03-29 at 10.48.16 AM.png
jbrody is offline
post #5172 of 5179 Old 03-29-2020, 11:35 AM
DavidinGA's Avatar
Quoted: 560 Post(s)
Liked: 239
The PA460 has much stronger midbass, but not nearly the low end. Notice its 9db down in the table on the low end.
The cube is a bit small for the um, so the 460HO is slightly cheaper and works very well.
Chris
Right and the larger the um18 cab becomes the more drastic you can see how much better it is than the Pa460 on the low end.
Sent from my Pixel 2 XL using Tapatalk
Epson 5040, 150" 16:9 1.1gain, Source: HTPC w/madVR, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 4 diy Slim VBSS 18" Subs w/NX3000D.
DavidinGA is offline
post #5173 of 5179 Old 03-29-2020, 11:59 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
if that is best
Jason
Modeled it in HR. Looks good.
UM18 on 1000w
18hz 2nd order HPF
Tune: 18.9hz
Cone excursion: 19mm
Port velocity: 17m/s
On 1000w, you can take the hpf down to 15hz without excursion or velocity going excessive.
Chris
a77cj7 is offline
post #5174 of 5179 Old 03-29-2020, 12:20 PM
jbrody's Avatar
Liked: 0
UM18 on 1000w
18hz 2nd order HPF
Tune: 18.9hz
Chris
Awesome thanks so much.. is it best to set the HPF in the amp (nx6000d) or at the receiver? Im assuming at the nx but I won't have that in hand until Tuesday or Wednesday. Just not sure how the port length should be changed. Im a blank canvas right now so if anyone would build it a bit different let me know.
Jason
jbrody is offline
post #5175 of 5179 Old 03-29-2020, 12:24 PM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Jason
Receiver will not have a hpf, just the lpf. You’ll need to set the hpf in the inuke. Use your receiver’s lpf normally, 80hz or so depending on your speakers.
I’d say your port length is good. You can bump it up to 48” to lower tune slightly, longer causes issues with port resonance. It would be a minimal change though.
Chris
a77cj7 is offline
post #5176 of 5179 Old 03-29-2020, 12:30 PM
jbrody's Avatar
Liked: 0
Chris
Sweet.. Plan to keep it simple... when I inevitably get more bass hungry I plan to just add a second and a near field but this is just to cut my teeth.
J
jbrody is offline
post #5177 of 5179 Old 03-30-2020, 07:45 AM
jbrody's Avatar
Liked: 0
Screen Measurement
So I was all set in my mind with my build then I remeasured some things in the theater.... my screen is 25 inches from the wall. My ports should be below the screen but the sub may have some area covered by the screen. Is it more important for the port to be away or am I going to also have problem with the speaker itself?
I have a silver ticket 120" with aluminum frame and acoustic material. It hangs. down from the ceiling so only mounted from the top rail..
Considering if I have to come up with a more shallow build thoughts?
Jason
jbrody is offline
post #5178 of 5179 Old 03-30-2020, 08:22 AM
a77cj7's Avatar
Quoted: 815 Post(s)
Liked: 858
Jason
As long as there’s no physical contact, blocking a small portion of the cone won’t cause any issues. More of a cosmetic concern.
Chris
a77cj7 is offline
post #5179 of 5179 Old 03-30-2020, 08:35 AM
jbrody's Avatar
Liked: 0
Chris
Thanks Chris for your help and advice... an inch or two between the box and the screen made me worry... I started a build thread for this is I will post my questions there from here on out thanks again
jbrody is offline
