MartySub FAQ - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 1715Likes
post #5221 of 5277 Old 05-11-2020, 09:49 AM
Quoted: 20 Post(s)
aha! - i agree, if you're the slave tasked with the set-up, good bear is definitely worthwhile!
doug s.
Originally Posted by Heide264 View Post
I wasn't evaluating the audio gear - just seeing if any points line up
dougie s. is offline
post #5222 of 5277 Old 05-11-2020, 09:52 AM
Quoted: 20 Post(s)
oh, and fwiw, my present subs weigh in at 140lbs ea, and no spikes or even feet, on my concrete slab floor.
main speakers are on wood boards, not spiked, but with very small rubber feet to concentrate the load.
doug s.
post #5223 of 5277 Old 05-11-2020, 09:37 PM
Augerhandle's Avatar
Quoted: 1457 Post(s)
Liked: 1425
My speaker spikes are guaranteed to keep African elephants out of the basement (Guarantee valid only in the U.S.A. on Tuesdays of months with an R in their name).
You don't have to believe me, just try it and see!
Heide264 likes this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #5224 of 5277 Old 05-12-2020, 12:49 AM
Quoted: 20 Post(s)
well, you think that's a big deal? MY speakers, spiked or not, will keep african elephants out of the basement in the usa, 24/7/365! so THERE!!!
doug s.
post #5225 of 5277 Old 05-12-2020, 04:19 AM
rec head's Avatar
Quoted: 392 Post(s)
Liked: 389
You guys are going to be so embarrassed when you have elephants in your basements.
mesasone and Augerhandle like this.
rec head is offline
post #5226 of 5277 Old 05-12-2020, 10:12 AM
Quoted: 411 Post(s)
Liked: 577
I think this might be a good place to post this question but of course please feel free to redirect me if I'm wrong.
Twin Devastators are on the way. I have a Behringer NX6000D that will be driving them. I'm looking for a way to rig up a remote trigger for it so it doesn't have to stay on all the time. I'm not good with soldering or building anything electronic. Is there a solution? Thanks as always, guys.
Gary Mertz is offline
post #5227 of 5277 Old 05-12-2020, 10:26 AM
Quoted: 76 Post(s)
I have two different size Dayton drivers
My question is this. Has anyone tried making a box the can use two different size drivers
So basically it’s two boxes in one
I have a large spot in between my couches, so my wife is give me the green light to make one large sub that would go in that spot. The area could be like 4‘ x 4‘ in as high as 3 feet and I was thinking of using the 15 inch Titan driver and a 12 inch Dayton HO driver, and have them both use their own separate sealed compartments inside the one large box, and each one of the drivers being in a slot loaded ported cabinet
hessc50 is online now
post #5228 of 5277 Old 05-12-2020, 11:12 AM
Witchboard's Avatar
Quoted: 224 Post(s)
Liked: 209
I replaced one of my wall outlets with a z-wave controlled outlet and turn my NU6000DSP on and off via Alexa. It does have the infamous pop when I turn it off, but I have my amp behind my TV and I'm not able to reach the power button easily. It's been working fine since I put it in.
Rumble & Frenzy - My Mini-Marty Build
Screaming Eagles - My Fusion-15 Sentinel Build
Witchboard is offline
post #5229 of 5277 Old 05-12-2020, 12:08 PM
Quoted: 411 Post(s)
Liked: 577
Good thought. I'm concerned though about the draw from the amp when its running full out. It will be plugged into its own 20-amp circuit so the available power will be just fine.
post #5230 of 5277 Old 05-12-2020, 05:52 PM
LGERIC's Avatar
Quoted: 132 Post(s)
Liked: 43
I tried a master/slave power supply that gave a loud thump. After that I just turn them off manually. I run both my 6k and 3k through a cheap power supply that has no problem running the 6k and a 3k at the same time.
LGERIC is offline
post #5231 of 5277 Old 05-13-2020, 08:40 AM
Witchboard's Avatar
Quoted: 224 Post(s)
Liked: 209
Mine is just plugged into a regular 15 Amp circuit and hasn't tripped the breaker in the 3 years I've been running it (knock on wood). I supposed I may not listen as loud as others do though.
post #5232 of 5277 Old 05-13-2020, 04:17 PM
Quoted: 411 Post(s)
Liked: 577
There must be a solution that doesn't cause that thump when it switches off, yes?
post #5233 of 5277 Old 05-14-2020, 07:58 AM
Heide264's Avatar
Quoted: 69 Post(s)
Liked: 39
I believe any relay type device that toggles on a zero crossing of the input voltage will remove the thump on power on or off. Most decent solid state relays will have that functionality baked, from what I've found. I remember seeing a thread that used a beefy SSR inside of a small wiring enclosure. The enclosure was built to accept a 3.5mm trigger wire from an AVR to toggle the power. On one side of the enclosure was a 3 prong plug for wall power and on the other side was a 3 prong female plug for the amp.
Gary Mertz likes this.
Heide264 is offline
post #5234 of 5277 Old 05-21-2020, 02:55 PM
lyle2321's Avatar
Liked: 0
Originally Posted by a77cj7 View Post
Modeled it in HR. Looks good.
UM18 on 1000w
18hz 2nd order HPF
Tune: 18.9hz
Cone excursion: 19mm
Port velocity: 17m/s
On 1000w, you can take the hpf down to 15hz without excursion or velocity going excessive.
Chris
Wondering if I could get some help - I found the Marty Subwoofer excel spread sheet - I'm looking to build a "mini-marty" sub using the Dayton UM18-22 driver -
Not sure what to use for box size and more specifically the Port Length?
I was thinking of using a box size of 40 H x 25 W x 23.3 D.
Is there a program used to calculate the optimal port length for a specific driver?
lyle2321 is offline
post #5235 of 5277 Old 05-21-2020, 04:06 PM
a77cj7's Avatar
Quoted: 1006 Post(s)
Liked: 1064
Winisd is what most people use for modeling.
Port length depends on box volume and port area for a specific tune.
Port area needs to be large enough to control port velocity for a given driver and input power.
Chris
a77cj7 is online now
post #5236 of 5277 Old 05-23-2020, 06:41 AM
spooble's Avatar
If you've been waiting on a sale on the Ulitmax UM18-22, today is your day! $275 through Monday (and don't forget the 25 off 250 coupon). Just ordered mine!
4fit? and dRwOOD73 like this.
spooble is offline
post #5237 of 5277 Old 05-23-2020, 11:39 AM
CZ Eddie's Avatar
Quoted: 134 Post(s)
Liked: 66
Where do you get the $25-off coupon from?
"The boom is dead, long live the bass"
CZ Eddie is offline
post #5238 of 5277 Old 05-23-2020, 12:02 PM
smcmillan2's Avatar
Quoted: 1142 Post(s)
Liked: 964
These have worked for me in the past https://www.offers.com/parts-express/
CZ Eddie likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5239 of 5277 Old 05-24-2020, 06:03 AM
Quoted: 411 Post(s)
Liked: 577
Quick question. When I predrill the holes to mount the driver I use a 1/8" bit, yes?
post #5240 of 5277 Old 05-26-2020, 04:59 AM
Heide264's Avatar
Quoted: 69 Post(s)
Liked: 39
Unless I missed it somewhere up in the thread, the pilot holes for the drivers would depend on the hardware you are using to secure the driver.
Heide264 is offline
post #5241 of 5277 Old 05-26-2020, 05:30 AM
rec head's Avatar
Quoted: 392 Post(s)
Liked: 389
rec head is offline
post #5242 of 5277 Old 05-26-2020, 12:24 PM
lyle2321's Avatar
Liked: 0
ok - Hoping someone can help out ----
I have purchased the Dayton Audio UM18-22 subwoofer, and plan on using a Behringer NX6000D to power the system.
I have determined that I would like cabinet dimensions of - 41.5 H x 24 W x 23.5 D ---- and have input this into the Box Volume calculator and it produces a volume of approximately 8.7 cu ft. (depending on port length).
I have input the data into WinISD application in an attempt to determine proper port length (I have started with 3 inch port height) and the application says to use a 47 inch port length (which seems very long) ....
What I am unclear about - is what is the optimal tuning frequency for the UM18 driver (or is this just personal preference) --- I would like to get some decent low frequency extension - below 20 Hz (I was thinking of 18 Hz tuning frequency??) .... I also know that you need to watch port velocity --- presumably the velocity increases as the port size is reduced.
Based on my external cabinet size, I was really hoping someone could help me determine the best port height, and length ?
Thank you in advance.
lyle2321 is offline
post #5243 of 5277 Old 05-27-2020, 04:23 AM
Heide264's Avatar
Quoted: 69 Post(s)
Liked: 39
So the cabinet size you picked is only a hair larger than the standard mini-marty build noted on page 1 of this thread. I don't mean to offend you at all, but based off your questions, I'd recommend just going with the mini marty rather than trying to customize it too much at this point. You'll have some great performance just as the sub was designed. Ported boxes aren't overly complicated, but considering your cabinet size is so close to an already solid design, I'd just go with the mini-marty. The four build sizes on the first page were designed to work well between acoustic parameters, material efficiency, and amplifier 'friendliness'.
For what it's worth, your port length does seem long to me from my memory, but I didn't model anything. If you really need the cabinet to be that exact size for some reason, we can help you out more with the details of it though.
Heide264 is offline
post #5244 of 5277 Old 05-27-2020, 08:30 AM
lyle2321's Avatar
Liked: 0
No offense taken ---- I'm really just looking for assistance with design --- I was hoping to use the exact cabinet size (41.5 H x 24 W x 23.5 D) - just so it fits better into my room. Perhaps I am wrong, however I would have thought that the port height and port length should be customized based on the type, size, and specification of the driver (subwoofer driver) - to ensure optimal functionality??
Anyone else available to help ..... please ....
lyle2321 is offline
post #5245 of 5277 Old 05-28-2020, 12:13 PM
Liked: 1425
From the first post in this thread:
Minimarty - blue
volume = 9.0 c.f. , tuning = 18hz ultimax 18 2000w**
I've replied to your PM. You should be good to go.
post #5246 of 5277 Old 05-28-2020, 04:27 PM
Quoted: 411 Post(s)
Liked: 577
Thank you for the help so far, guys. Almost done with the first of the twin Devastators.
Question: I don't understand how to wire the speakon panel mount connector. A 3/8" female tab will work for the -1 but the +1 won't accept the female tab as its bordered on the sides by plastic. I'm hoping this is a stupid question with an easy answer. FWIW, these are the connectors I have:
https://www.glsaudio.com/GLS-Audio-N...ck_p_1931.html
Thanks a lot, guys, this is the last hurdle!
post #5247 of 5277 Old 05-28-2020, 04:45 PM
smcmillan2's Avatar
Liked: 964
Either snip the plastic away (you have to be careful to not let the two connections touch) or get 3/16" spades, often found in automotive parts stores.
post #5248 of 5277 Old 05-28-2020, 05:26 PM
Quoted: 411 Post(s)
Liked: 577
3/16", yes I'm sorry, that's what I meant. I do have some and they will fit on the -1. The spade won't fit in the +1. Without snipping the plastic would it otherwise have to be soldered? I wonder if there are connectors that are designed such that you don't have to solder. The Neutrik speakon plugs just secured the wire with a screw, they were easy.
post #5249 of 5277 Old 05-28-2020, 05:38 PM
smcmillan2's Avatar
Liked: 964
If you're already using 3/16" just snip the plastic away. I've been using 1/4" spades (because I had them), snipped the plastic and have had no issues. Should only have to remove one tab of the "H" shaped extrusion.
post #5250 of 5277 Old 05-28-2020, 06:30 PM
Quoted: 411 Post(s)
Liked: 577
Okay, sold. I'll work on that tomorrow. Would I just wrap the tabs in electrical tape so as to avoid them touching? Seems like they'll be very close to each other.
