MartySub FAQ - Page 80 - AVS Forum | Home Theater Discussions And Reviews
 1651Likes
post #2371 of 5032 Old 10-16-2015, 04:15 PM
Shadowed's Avatar
Quoted: 939 Post(s)
Liked: 909
Originally Posted by mal01 View Post
I am putting together a full Marty and have a question about bracing, does it matter how close a brace is to the back of the woofer, is there a minimum distance that a brace should be from the back, below or above the woofer? Thanks!
No, as long as it doesnt interfere with the cone movement or block air vent on back of motor if it has one.
Shadowed is offline
post #2372 of 5032 Old 10-16-2015, 04:52 PM
mal01's Avatar
Quoted: 112 Post(s)
Liked: 29
Great, thanks!
mal01 is offline
post #2373 of 5032 Old 10-20-2015, 05:25 AM
Quoted: 58 Post(s)
I got one of my Marty Cube HT18s done a couple weeks ago and received my UMIK last night, so of course I had to take some measurements. I was quite impressed with how easy all the software was to use. The only thing I can't figure out with REW is how to make adjustments to the correction target to bring up the low end, everything is easy.
Here's a graph of the baseline measurement (I can't figure out how to show it larger).
I'm using the DSP in my iNUKE for equalization. Sadly, I forgot to save the final measurement file, but I wasn't too happy with the outcome, especially below 23Hz. I've got the signal flat to +/-2db between 23Hz and 75Hz, but there's a pretty steep dropoff at both ends. I was able to pull up the 70-85Hz a bit, but it was still a pretty steep dive. There were 3 EQ settings that it had me add between 30 and 48Hz, nothing lower or higher.
Is there anything that can be done below 23Hz? I turned off the 20Hz filter for a couple tests and it didn't change much.
I'll grab a final graph tonight and post it up. Any suggestions in the meantime?
Name:	Baseline REW - 1x MiniMarty HT18.jpg
3D Blurays, Blurays and DVDs for Sale
Digital Movie Codes For Sale
Sony VPL- HW40ES / Sony STR-DN850 / OPPO BDP-103D / 3x DIY Soundgroup 893 / 2x SI HT18 MartyCubes / Behinger iNuke 6000DSP
SageFly is offline
post #2374 of 5032 Old 10-20-2015, 06:18 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
How large is your room? Also, be sure and keep the HPF active especially if you are going to be playing any movie content. The excursion of the sub shoots up like a rocket below tuning so you want to be careful.
One thing you can try, especially if you don't listen at or near reference is add a +3db boost at 20hz. Myself and Chalugadp do this and it helps bring up the sub 23hz area like you were asking about. I wouldn't go much more than 3db's because the excursion and power needed for much more than that rises quickly.
Check out my End-Table Marty Build
squiers007 is offline
post #2375 of 5032 Old 10-20-2015, 09:14 AM
Quoted: 58 Post(s)
The room is L shaped and open to the rest of the house (the leg of the L with the subs against the wall is 11' wide and seating is about 13' away).
The HPF was only off for 2 pink noise sweeps from 10-100Hz at ≈80db. It'll definitely stay on otherwise. The Martycubes that I built are still tuned at 20Hz.
I tried adding a boost at 20Hz, but still no improvement. For the pink noise sweep I went as high as +5db, but still didn't see much change.
I'll definitely compare the two subs once the second is done to make sure I didn't mess something up with the assembly.
SageFly is offline
post #2376 of 5032 Old 10-20-2015, 09:22 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
My guess is it's simply the room. With a large volume to fill you get hardly any room gain. This is the problem I have also, The only solution is to add more subs with lower tuning to get additional output down below 23hz.
If you haven't already you might try messing around with placement to see if that helps at all.
post #2377 of 5032 Old 10-20-2015, 09:56 AM
splotten's Avatar
Quoted: 292 Post(s)
Liked: 140
Try and take a closeup measurement 1" from the cone to see where the tuning frequency ended up. The tuning frequency is where the cone has minimum excursion and it will look like a steep dip in the sweep.
splotten is offline
post #2378 of 5032 Old 10-20-2015, 01:16 PM
mal01's Avatar
Quoted: 112 Post(s)
Liked: 29
Ok, I have got my marty up and running in my theater but I have just simply plugged it in to where the sealed sub that it replaced was at, I guess in order to know if I want to do more of these I need to unhook the other subs and run a calibration on the Marty only?
mal01 is offline
post #2379 of 5032 Old 10-22-2015, 08:51 PM
Quoted: 130 Post(s)
Liked: 9
Need some help, setup: inuke 3000DSP and a pair of SI HT18-D4.
Problem: I followed the instructions on the first page and went into the DSP setting to do initial setup, for some reason on the "Filter" tab whenever I set the "High Pass 1" to 20hz it automatically goes up to 30hz.
Can any one assist ?
triplejs15 is offline
post #2380 of 5032 Old 10-22-2015, 09:16 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
I would redo the calibration using your AVR.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #2381 of 5032 Old 10-22-2015, 10:02 PM
Augerhandle's Avatar
Quoted: 1158 Post(s)
Liked: 1143
You can click and drag on the virtual dial, or just enter 20 in the text box and hit enter.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #2382 of 5032 Old 10-23-2015, 09:18 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Punch 20 in the box and hit enter. Are you using stereo or, the dual mono setting ? Is the amp in bridge mode?
derrickdj1 is offline
post #2383 of 5032 Old 10-24-2015, 01:42 PM
jjgear's Avatar
Quoted: 16 Post(s)
So i have 2 johnny subs running off a dsp1000 and am not getting sound from 1 sub. Both drivers are d4. Which way should the wire be hooked up 1+ and 1- of 1+ and 2+
jjgear is offline
post #2384 of 5032 Old 10-24-2015, 07:24 PM
rhodesj's Avatar
Quoted: 1009 Post(s)
Liked: 600
If using both the A and B jacks, both use +-1.
rhodesj is offline
post #2385 of 5032 Old 11-03-2015, 07:54 AM
bigkev4123's Avatar
Quoted: 18 Post(s)
Liked: 24
I planned on buying the Stonehenge subwoofer boxes from DIYSG, but it looks like it might be a while before they are back in stock. As a result, I am looking at just building the cabinets myself. I am particularly interested in the Minimarty style but wondering if it would be possible to modify the design to make it thinner. I am using an acoustic screen and the subwoofers will be behind the screen, so I am depth limited to about 18" - 20". Would it be detrimental to the minimarty design if I simply modify the depth measurements to get it to around 18" deep? I would keep the other dimensions the same (height and width).
I will be using 2 of SI HT 18 D4 hooked up to a INUKE 3000dsp. Plan on running the subs at 2 ohms. Please let me know what you think, just looking for solid output around 18 - 20hz, thanks.
bigkev4123 is offline
post #2386 of 5032 Old 11-03-2015, 08:20 AM
brian6751's Avatar
Quoted: 1686 Post(s)
Liked: 1676
this might be what your looking for.
https://www.avsforum.com/forum/155-di...e-ps-18-a.html
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #2387 of 5032 Old 11-03-2015, 09:41 AM
fajita123's Avatar
Alright, currently building two marty cubes and have ordered two SI-18-HT D2's as the D4's are out of stock. Also ordered an inuke 6000 DSP off of ebay as I read it's the best option for getting the max out of D2's. The question I have is on wiring - from what I gather each sub will be wired to its own channel of the 6000DSP. Does this look right?
If this is the case, I need two speakon terminals per box and two runs back to the amp for each sub?
derrickdj1 likes this.
fajita123 is offline
post #2388 of 5032 Old 11-04-2015, 12:04 AM
More is Better's Avatar
Quoted: 620 Post(s)
Liked: 354
Attachment 1036321
That picture is right.
The wire on the right is just a foot long piece of wire to connect the + and - terminals.
The 2 unconnected wires on the left of the pic are a single pair from the amp.
1 speakon per sub box.
fajita123 likes this.
More is Better is offline
post #2389 of 5032 Old 11-04-2015, 06:48 AM
fajita123's Avatar
Ok, thanks! Speakon is new to me so wasn't sure.
post #2390 of 5032 Old 11-07-2015, 03:34 PM
artyusmce's Avatar
Quoted: 29 Post(s)
Originally Posted by lemonslush View Post
Has any one added a dual post to there subs with DVC? I was debating on hooking each voice coil up to its own terminal on the back so If I wanted to swap it from 2-8 ohms I could do it quickly without removing the sub from its box?
http://www.amazon.com/Bi-Amp-Speaker...r+terminal+cup
did you do this and has it worked as expected
artyusmce is offline
post #2391 of 5032 Old 11-07-2015, 04:54 PM
lemonslush's Avatar
Quoted: 835 Post(s)
Liked: 424
Ha. No and I have 8 boxes built at this point and it would be nice to have added that. Pulling the sub out is a PIA.
lemonslush is offline
post #2392 of 5032 Old 11-08-2015, 04:26 PM
dchabby's Avatar
Quoted: 147 Post(s)
Liked: 95
this may have been asked or may be a 'duh' question but when connecting the rca sub pre-out from your avr to the inuke 3000dsp amp and going to run 2 subs, can you use an rca splitter rather than an xlr splitter ?
dchabby is offline
post #2393 of 5032 Old 11-08-2015, 07:28 PM
derrickdj1's Avatar
Liked: 767
I use RCA splitters.
dchabby likes this.
post #2394 of 5032 Old 11-08-2015, 09:05 PM
Liked: 1143
It doesn't matter, BUT you don't need to split it at all, and can save a few bucks.. You can go direct to input A and use Bi-Amp mode. Just don't engage the crossover.
Name:	Capture Bi-Amp.JPG
dchabby likes this.
post #2395 of 5032 Old 11-09-2015, 06:19 PM
azz7686's Avatar
Quoted: 279 Post(s)
Liked: 125
Whats the difference with xover on? Guess this is a duh question but I'm a little off when it comes this amp its a little over my head just need some more experience with it i guess but like learning here!
Spoiler!
azz7686 is offline
post #2396 of 5032 Old 11-09-2015, 06:51 PM
derrickdj1's Avatar
Liked: 767
The crossover tab is for setting a HPF or LPF. The HPF keeps a speaker from getting to low of a frequency and the LPF is the opposite. Most of us for sub duty don't use a LPF since this is done by the avr. Vented subs use hpf to protect the drive/speaker.
post #2397 of 5032 Old 11-09-2015, 06:56 PM
azz7686's Avatar
Quoted: 279 Post(s)
Liked: 125
Ok, sorry I do understand that but does it effect the single channel running both outputs? Sorry I wasn't more clear on what I do understand lol its been a long day!!!
Spoiler!
azz7686 is offline
post #2398 of 5032 Old 11-09-2015, 07:51 PM
Liked: 1143
It affects the Channel B output (as it should, in "normal" Bi-amp mode).
Turn it on, and it automatically sets Channel B crossed over as a tweeter (High Pass 3 gets linked to Low Pass 2), so it can't feed the 2nd sub the low frequencies. Clicking it off allows individual control of the HPF and LPF for each channel.
Name:	Capture Bi-Amp Locked.JPG
azz7686 likes this.
post #2399 of 5032 Old 11-09-2015, 09:59 PM
dexterblack's Avatar
Quoted: 24 Post(s)
I am building a minimarty. What is the best liner I can get from Walmart or Home Depot? Thanks.
dexterblack is offline
post #2400 of 5032 Old 11-10-2015, 07:38 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Any cheap foam mattress topper will work. Just make sure it's not memory foam.
