Awesome WAF/SAF Builds - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 323Likes
post #151 of 233 Old 05-19-2015, 09:04 AM
eng-399's Avatar
Quoted: 2420 Post(s)
Liked: 4971
eng-399 is offline
post #152 of 233 Old 05-19-2015, 09:05 AM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1332
Even the speaker stands are just killer!
PassingInterest likes this.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #153 of 233 Old 05-19-2015, 09:07 AM
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 46
Originally Posted by snapwing View Post
I finally finished my Micro Marty...and it passed inspection! My wife is super happy with how it turned out and how it blends right into the room. This was an adventure for me since I am a woodworking noob (don't look too closely at the stain job...), but I had a total blast doing it. The goal was to match (more or less) some existing furniture which have this antique chest sort of look. My approach was a down-firing cube with a 15" Dayton 390HO running bridged from an iNuke 3000dsp.
Nice panasonic.
snapwing likes this.
Vizio M501d-A2R(Calibrated), LG BD-330, Pioneer VSX-524-K, Custom DIY LCR Mains, DIY Sub ( Kicker 10c124, 2.25 ft3, 19 hz tune, powered by xm-sd46x(using only rear channel in bridge mode, 150watts), powered by 400w atx power supply.) Work in progress.
Gary147852 is offline
post #154 of 233 Old 05-19-2015, 09:14 AM
PassingInterest's Avatar
Quoted: 195 Post(s)
Liked: 532
You are way too kind, @manuetdeo @eng-399 and @NWCgrad ! But, thanks!
PassingInterest is online now
post #155 of 233 Old 05-19-2015, 09:55 AM
LitoGeorge's Avatar
Quoted: 58 Post(s)
Liked: 56
Every time I see one of these show and tell threads, I think PassingInterest's name should be EnduringInterest.
Magnificent work.
LitoGeorge is offline
post #156 of 233 Old 05-19-2015, 10:38 AM
ambesolman's Avatar
Quoted: 1157 Post(s)
Liked: 969
@PassingInterest , do you have a build thread for these? Love the finish and veneer and would like to get more info. Great work🏼
Sent using Tapatalk since the mobile version is still
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is online now
post #157 of 233 Old 05-19-2015, 10:46 AM
Quoted: 195 Post(s)
Liked: 532
@ambesolman - If you mean the small 2-ways, the build thread is here.
@LitoGeorge - Thank you for the kind words!
ambesolman likes this.
post #158 of 233 Old 05-19-2015, 10:21 PM
snapwing's Avatar
Liked: 45
Originally Posted by Augerhandle View Post
Pics, or you bought it.
Ha! Fair enough. I put together a build thread of my little adventure. Maybe someone will find it helpful.
https://www.avsforum.com/forum/155-di...l#post34354402
snapwing is offline
post #159 of 233 Old 05-20-2015, 11:13 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 641
Originally Posted by manuetdeo View Post
PI's builds could be their own thread titled " What we aspire to be"!
Yep.
Truly awesome builds that rival the best $ has to offer in appearance.
PassingInterest and manuetdeo like this.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #160 of 233 Old 05-20-2015, 11:38 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4791
Yes, truly inspirational, something to aim for @PassingInterest .....if this is a passing interest for you I can only wonder when you're absorbed with something
lovinthehd is offline
post #161 of 233 Old 05-20-2015, 11:43 AM
wse
wse's Avatar
Quoted: 2207 Post(s)
Liked: 814
Well, okay. Here are a few shots...........
Lastly, the Bunker Buster subwoofer is a work in progress.
I hope that's not too many pictures.
If they sound as good as they look they must be incredible any of them for sale? I love the speakers and the stands!
PassingInterest and CBdicX like this.
wse is offline
post #162 of 233 Old 05-20-2015, 12:38 PM
Quoted: 195 Post(s)
Liked: 532
I do have some that I don't know what to do with. Shipping would probably suck, though.
manuetdeo likes this.
post #163 of 233 Old 06-02-2015, 03:49 AM
CBdicX's Avatar
Quoted: 1615 Post(s)
Liked: 383
Hi, think i will have my first try for a DIY subwoofer in this cabinet thats a part of a computer desk.
Space is +/- 36W x 34H x 60D (centimeter)
I want to use a Sinuslive SL-W330, a 30cm woofer with a Behringer 500 amp to drive it.
Sinuslive is a car audio company and this woofer is also "car based"......
Its at the moment very cheap as its no longer a stock item from Sinuslive and is sold for just 99,00 euro inclouding shipment.
I can mount the woofer in the door, seal it and will use demping material inside.
I can use the Behringer 500 in Bridge Mono mode and get 375 watt RMS, enough to get the best out off the woofer.
I hope to start the "build" soon.........
ID:	751505   Click image for larger version
azz7686 likes this.
CBdicX is offline
post #164 of 233 Old 06-03-2015, 07:05 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Make sure you seal all of the joints inside that cabinet. Any air leaks will will result in greatly reduced performance. Also, you will want to add additional bracing in all directions to help reduce the cabinet panels vibrating and resonating.
Do you have the T/S parameters for that driver? Have you modeled it in that size enclosure to see how it performs?
Check out my End-Table Marty Build
squiers007 is offline
post #165 of 233 Old 06-03-2015, 07:17 AM
CBdicX's Avatar
Liked: 383
Well, its going to be different.
Did a SPL test where the cabinet is, and dB's are way low :-(
As i do not have a sub at the moment i did this.
I placed my Jamo C109 front speaker in the middle of the MLP and let it play some frequency test tones, 50, 45, 40, 35, 30, 25 and 20 Hz.
I get a differents between 10 and 15 dB (lower) on the cabinet spot compared with the best spot, 2.5 meter right behinde the MLP in the middle of the back wall ! (i have a L shaped room)
On some tones differents is bigger, on others smaller, but allways (far) lower.
So think the best option is get a sub i like and put it behinde me on the backwall.......
azz7686 and squiers007 like this.
CBdicX is offline
post #166 of 233 Old 06-04-2015, 10:55 AM
CBdicX's Avatar
Liked: 383
As mentioned i can buy a sub but still like the idea to build one myself.
It will be a sealed box and when i look at sealed subs with a 12 inch woofer, all are about the same size, 38x38x38 cm.
Would it be a big problem if i use a bigger box ?
I can use a wooden table and make the sub between the legs of the table.
Size of the box will go up to +/- 44x44x38
Will this be better or just as good as the most used 38x38x38 ?
CBdicX is offline
post #167 of 233 Old 06-04-2015, 11:01 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
It all depends on the sub's T/S parameters. Some model better in small boxes, other large boxes... You will probably get more advice if you start a new thread about the topic.
post #168 of 233 Old 06-04-2015, 11:07 AM
CBdicX's Avatar
Liked: 383
Problem is i can not find any T/S parameters of the woofer, a Sinuslive SL-W330.
Found them but it makes no sense to me:
http://81.169.156.47/xtcmodified-1.0...49828cb17f720e
CBdicX is offline
post #169 of 233 Old 06-04-2015, 11:11 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
A lot of manufacturers do not advertise them for some reason... the best you can do is pick a reasonable size, measure the response, then decide if you want to try a bigger or smaller box depending on how the response looks. Might be a better idea to buy a proven driver with T/S parameters...
post #170 of 233 Old 06-04-2015, 11:16 AM
lovinthehd's Avatar
Liked: 4791
The T/S parameters plugged into modeling software is what you need to do to make sense of them....this thread isn't the place, start one and ask for modeling help.
Gary147852 likes this.
post #171 of 233 Old 06-04-2015, 11:24 AM
CBdicX's Avatar
Liked: 383
Just did, thanks for the help.
https://www.avsforum.com/forum/155-di...subwoofer.html
lovinthehd likes this.
CBdicX is offline
post #172 of 233 Old 06-04-2015, 01:23 PM
Augerhandle's Avatar
Quoted: 1158 Post(s)
Liked: 1144
lovinthehd and squiers007 like this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #173 of 233 Old 06-05-2015, 08:11 AM
Kelvin1965S's Avatar
Quoted: 339 Post(s)
Liked: 231
I wouldn't say mine is 'awesome' but it certainly gets WAF acceptance (I was even asked to make a similar one to hide a beer fridge in ). The rear 'table' sub goes mostly un-noticed sat next to the matching oak sideboard. The front one (just ahead of the cream sofa to the left of the room) is just a black box with an oak top, though it isn't too prominent in the room. It is turned to face the wall now and the AV gear is in a rack outside of the room too, which helps greatly in black out scenes when using my projector as there are no LEDs to shine on the screen now.
My OH doesn't mind about having speakers on show, but I prefer the room to look like there is no HT gear at all bar a TV. My aim next year is to hide all the speakers and subs bar the table sub, though there will be three other identical volume (but tall and shallow) subs to go with it.
Name:	Completed rear from front.jpg
ID:	757169   Click image for larger version
Name:	Complete speaker in.jpg
ID:	757177   Click image for larger version
Name:	Back of room table sub.jpg
ID:	757185   Click image for larger version
ID:	757193   Click image for larger version
Name:	Front sub painted no grille.jpg
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
post #174 of 233 Old 06-05-2015, 09:57 AM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
Originally Posted by Kelvin1965S View Post
I wouldn't say mine is 'awesome'...
I would, they look great!
Kelvin1965S likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #175 of 233 Old 06-05-2015, 10:04 AM
CBdicX's Avatar
Liked: 383
Nice.....
Did you make any calculations for box size or just took a size that fit and put the woofer in ?
CBdicX is offline
post #176 of 233 Old 06-06-2015, 02:43 AM
Quoted: 339 Post(s)
Liked: 231
Thanks for the kind comments.
I did various calculations before having the MDF boxes built (there is a guy on eBay in the UK who will make the boxes up for little more than it would cost me to buy the MDF). I used WinISD for the calcs.
I also used REW room sim to work out the best locations for the subs (opposite diagonals front left and rear right) which nicely filled a null that I suffer from at the MLP around 40Hz. I get a great response with room gain (and some EQ in the iNuke 6000DSP) so I can run flat down to 10Hz at 110dB.
Since I tend to listen about -10dB down from reference that gives me enough headroom, though if I add another pair of FiQ 15 and another iNuke 6000DSP then that will give an even better pre eq response in the room and of course extra headroom again. I'm now using a miniDSP DDRC-88A for Dirac live room eq and the way it integrates these subs with my MK MP150 series speakers is making me wonder if I need to bother with the extra subs...but I probably will anyway. Having them all 'invisible' in the room makes the surprise for guests even more fun.
azz7686 likes this.
post #177 of 233 Old 06-08-2015, 10:53 PM
CBdicX's Avatar
Liked: 383
After seeing high prices for subs in the size i want, i will do do a DIY sub and started the build.
When i am done i will post pics.
To get the "best" spot for the sub i moved my fronts around (30Hz -3 dB) and used an SPL meter in the MLP to see what spot gave me the most SPL on subwoofer frequencies test tones.
Its a bit difficult as i did 6 messurement in each spot, 45-40-35-30-24 and 20 Hz.
In one corner the 40 numbers will peak more, in the other corner or spot the 30 numbers will do higher SPL.
So i took the spot that did the best overall, and that is behinde the MPL in the middle of the back wall.
The sub will be a table so the wife is also happy......
CBdicX is offline
post #178 of 233 Old 06-15-2015, 01:09 AM
CBdicX's Avatar
Liked: 383
Ok, here my "solution" to get (keep) the wife happy
This is a Lack table from IKEA (just 4,99 euro !!!!!!) and used the legs as main support for the case.
I have the volume up to 74 liter, exact what the T/S info advices for the woofer.
Sub Amp is a Behringer A500 in mono mode (375 watt RMS) and the woofer is a Sinuslive SL-W330, a 320mm "car audio" woofer that can handle 500 watt RMS on 8 Ohm and 92 dB.
All in cost (amp new, woofer new): 350,00 euro !
Wife happy, i happy........
ID:	776825   Click image for larger version
ID:	776833   Click image for larger version
ID:	776841   Click image for larger version
ID:	776849   Click image for larger version
ID:	776865   Click image for larger version
ID:	776873   Click image for larger version
ID:	776881   Click image for larger version
jlmoon likes this.
CBdicX is offline
post #179 of 233 Old 06-15-2015, 01:22 AM
Quoted: 105 Post(s)
Liked: 56
Wow, that looks great! That is definitely a different way of going about the construction. Did it all work out with the angle brackets? Were you able to use woodglue as well?
I like the design a lot.
Michael Rodriguez is offline
post #180 of 233 Old 06-15-2015, 01:37 AM
CBdicX's Avatar
Liked: 383
I used metal brackets and constuction sealant to fix the wood bracing.
All the sides are screwed and also applied acrylic sealant to get all air thight.
CBdicX is offline
