Awesome WAF/SAF Builds - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 323Likes
post #181 of 233 Old 06-15-2015, 01:58 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4791
@CBdicX , nice job! What did you use for connectors? Those look just like some open screw banana plugs....
lovinthehd is offline
post #182 of 233 Old 06-15-2015, 02:39 AM
CBdicX's Avatar
Quoted: 1606 Post(s)
Liked: 382
Originally Posted by lovinthehd View Post
@CBdicX, nice job! What did you use for connectors? Those look just like some open screw banana plugs....
I used gold plated screw connectors that can take up to 7mm wire.
ID:	777025   Click image for larger version
CBdicX is offline
post #183 of 233 Old 06-18-2015, 10:40 AM
CBdicX's Avatar
Liked: 382
Going to build a second sub soon, ordered the (same) woofer but is going to be used "upside down".
The SL W330 is designed to be used with the front facing in.
Also a second Behringer A500 will drive the 2nd sub.
How and what i will soon post here.......
CBdicX is offline
post #184 of 233 Old 06-18-2015, 10:51 AM
CBdicX's Avatar
Liked: 382
PS. just thinking would having one sub "out of phase", so one is pushing and one is pulling, give a "better" bas respond then both in the same phase ?
One is located on the back wall in the middle 2 meter behinde the MLP, the other will be located on the front wall, right corner, also about 2 meters from the MLP.
Both locations give the best possible bass SPL in the MLP, i checked this with a SPL meter.
Your thoughts please about out of phase or not.........
CBdicX is offline
post #185 of 233 Old 06-18-2015, 12:01 PM
climber07's Avatar
Quoted: 795 Post(s)
Liked: 2569
Not really. Phase ensures that the peaks from the subs are not cancelling each other out at a specific point in the room. It also helps to align the subs with the mains. This is also dependent on distance settings. If you have Audyssey, set both subs to 0 phase and run cal. During the cal, you can adjust the phase of the subs (one at a time) to get the best freq response at your MLP. Keep in mind that the phase adjustment may only improve FR at certain frequencies. You may boost a 40Hz tone and have a null at 80Hz. Bass is fickle and highly dependent on your room dimensions and sub placement with respect to the room modes (corners, walls, ceilings, etc.).
If you have two subs on opposite walls and adjust the phase on one to zero and the other to 180, and are standing exactly in the middle, you should get cancellation. With one sub near-field, you may need to adjust phase if you don't have a calibration program like Audyssey with SubEQ.
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #186 of 233 Old 06-18-2015, 12:35 PM
CBdicX's Avatar
Liked: 382
Ok, thank you for your reply.
I will use the Behringer A500 for both subs so i can only revers + / - , think that will be the same as 0 vs 180 degree.
I will try if it will ad or remove bass from the MLP when i reverse one sub.
Thanks......
CBdicX is offline
post #187 of 233 Old 06-18-2015, 08:24 PM
climber07's Avatar
Quoted: 795 Post(s)
Liked: 2569
Thanks......
Your situation will definitely benefit from phase adjustment. Make sure you run slow sweeps with voiceover stating the freq so you can determine where your peaks and nulls are.
Here's a link to the test tones:
http://www.audiocheck.net/audiotests_frequencychecklow.php
post #188 of 233 Old 06-19-2015, 12:26 AM
CBdicX's Avatar
Liked: 382
http://www.audiocheck.net/audiotests...cychecklow.php
Thank you for the help.
I will sure give this a try
First i need to determen the design of the sub to keep myself and the wife happy
PS 2 questions:
1)
i use now 1 Behringer A500 to dirve 1 sub in mono mode (375 watt RMS).
The A500 can do also stereo at 125 watt RMS, would this also be "enough" to drive 2 subs or will a second A500 be better/usefull ?
2)
And must the woofer always be centered symmetric, or can it be also placed in a wide box and have the woofer more to the left of the (sealed) box, asymmetric ?
CBdicX is offline
post #189 of 233 Old 06-19-2015, 11:21 AM
climber07's Avatar
Quoted: 795 Post(s)
Liked: 2569
PS 2 questions:
1)
2)
Can you post links to the specific drivers you are looking at? For subwoofers, especially sealed, you are going to want to be very close to their recommended RMS rating when selecting an amplifier. Too little wattage will cause the subwoofer not have adequate SPL.
As far as box design, sealed is much more forgiving than ported with regard to box size. When ported, the internal dimensions and port size/location play a critical part in tuning the box to the driver and the amplifier.
Here are some recommended links for designing boxes: http://www.diysubwoofers.org/faq.htm
post #190 of 233 Old 06-19-2015, 11:41 AM
CBdicX's Avatar
Liked: 382
Hi, here the info of the woofers i used on pag 6.
http://www.conrad.com/ce/en/product/...live-SL-W330-4-
And the T/S, it "wants" 74 liter, thats no problem ;-)
CBdicX is offline
post #191 of 233 Old 06-19-2015, 02:01 PM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
This doesn't list the power handling which would help to determine a compatible amp.
Also, so as not to get this thread any farther off track, could you please start your own thread so we can help you there and allow others to post there WAF/SAF builds in here. Thanks.
BacHolz likes this.
Check out my End-Table Marty Build
squiers007 is offline
post #192 of 233 Old 06-19-2015, 02:27 PM
CBdicX's Avatar
Liked: 382
Maybe my questions are not interesting for you but are related to "WAF/SAF builds" as i am in the process of building a 2nd sub and just finished one.
I see no differents in asking about wood, size, used woofer, ect, and my questions.
I am very happy that i get answers and/or corections to my ideas to help me build a better sub !
Thank you.........
CBdicX is offline
post #193 of 233 Old 06-19-2015, 02:35 PM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Thank you.........
I have no problem with your questions and I'm more than happy to provide my opinions and help you out, as I have been doing...
However, my thinking was that this thread was a place for people to post the builds they have already completed that are WAF/SAF type builds so others could view them in one place and use them as inspiration for there own builds...
Maybe I'm wrong and that was not the original intent of this thread since I was not the one to start it, I am no moderator so do as you please. I was simply trying to keep the thread on the topic I thought it was about.
post #194 of 233 Old 06-19-2015, 10:34 PM
CBdicX's Avatar
Liked: 382
Clear, so just pics and no, or less, questions/anwers.
Hope that who ever can answer my questions will do this with a PM then, and thank you and climber07 for the info you did get me !
I placed my first DIY sub in this thread, received some questions and answered them, will not do this in this thread with the second sub to keep the thread like it was started as you and the "likes" want.
To bad, there goes fallible information source.
Side tracking a topic can be good or bad and is difficult to stop, but you try, hope you can keep this thread "clean" to the level you want or think it needs to be.......
I for sure will stay here and enjoi all the nice pics of the DIY subs
And PLEASE PM me if anyone can help !
azz7686 likes this.
CBdicX is offline
post #195 of 233 Old 06-19-2015, 10:49 PM
ambesolman's Avatar
Quoted: 1156 Post(s)
Liked: 969
Easiest thing to do would be to start a build thread in the DIY sub section. You'll get tons of help
Sent using Tapatalk since the mobile version is still
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is online now
post #196 of 233 Old 06-29-2015, 09:32 AM
CBdicX's Avatar
Liked: 382
Made a second Subwoofer in a "Piet Mondriaan / Rietveld" style.
Very different from the first one, the Ikea Lack table Subwoofer, technical the same, same woofer, same amplifier, near the same size (+/- 74 liter).
(https://www.avsforum.com/forum/155-di...l#post35031689)
Here the build pics and the final sub, not everyones "cup of tea", i like it but i am a long time fan of Mondriaan and Rietveld.
Both styles are used in this subwoofer..........
ID:	802322   Click image for larger version
ID:	802330   Click image for larger version
ID:	802338   Click image for larger version
ID:	802346   Click image for larger version
ID:	802362   Click image for larger version
ID:	802370   Click image for larger version
ID:	802378   Click image for larger version
ID:	802386   Click image for larger version
ID:	802410   Click image for larger version
ID:	802418   Click image for larger version
ID:	802426   Click image for larger version
ID:	802434   Click image for larger version
ID:	802450   Click image for larger version
jlmoon, lovinthehd and squiers007 like this.
CBdicX is offline
post #197 of 233 Old 06-29-2015, 09:38 AM
CBdicX's Avatar
Liked: 382
Made a small change to the 2nd 4 Ohm wire that runs on the front of the woofer.
Now it runs to the back and around, a much cleaner setup this way.......
ID:	802498   Click image for larger version
ID:	802506   Click image for larger version
ambesolman likes this.
CBdicX is offline
post #198 of 233 Old 06-29-2015, 09:46 AM
wasser's Avatar
Quoted: 119 Post(s)
Liked: 83
Definitely not my cup of tea...but I'm compelled to drink it! That's a work of art: unique, beautiful, awesome. Is that angled aluminum on the corners?
wasser is offline
post #199 of 233 Old 06-29-2015, 09:49 AM
CBdicX's Avatar
Liked: 382
Yes it is.......
CBdicX is offline
post #200 of 233 Old 06-29-2015, 09:51 AM
lovinthehd's Avatar
Liked: 4791
Lol. I used to ride my bike by a Mondrian house in San Francisco all the time, always got a kick out of it, never saw the insides until I googled just now, your sub would be a welcome addition no doubt...https://www.google.com/search?q=mond...A&ved=0CB0QsAQ
azz7686 likes this.
post #201 of 233 Old 06-30-2015, 09:17 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Very nice @CBdicX I have seen several modern rooms that would fit perfectly in!
manuetdeo is offline
post #202 of 233 Old 08-18-2015, 02:30 PM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Been a while so I thought I'd bump this thread... what's everyone been up to? Lets see those builds!
post #203 of 233 Old 08-18-2015, 07:01 PM
DustinF's Avatar
Quoted: 47 Post(s)
Liked: 65
Because I couldn't have any subs showing- gluing real wood over mdf was my solution. Old builds but they get the job done. 3 in living room helps.
ID:	895018   Click image for larger version
ID:	895026   Click image for larger version
DustinF is offline
post #204 of 233 Old 08-18-2015, 07:05 PM
lovinthehd's Avatar
Liked: 4791
Nice looking work! Like the insert idea on the top.... By gluing real wood you mean veneering? Or another way? Build thread?
post #205 of 233 Old 08-18-2015, 07:21 PM
lovinthehd's Avatar
Liked: 4791
Does my addition of brass corners earn me any props/qualify? 3rd one and they're all similar. Next one is going to get more creative and put some of the inspiration here to work.
Name:	and final touch brass corners.jpg
post #206 of 233 Old 08-19-2015, 05:39 AM
DustinF's Avatar
Quoted: 47 Post(s)
Liked: 65
No veneer, although that would work just as well.
I used 1/4" and 3/4" wood.
All the doors are just 1/4" pieces with another 1/4" glued on top of that for the rails and stiles to make it look like a frame and panel door, even though it isn't.
None of the doors open as it's just glued to the mdf.
Legs and top are 3/4".
It's actually fairly easy to do as you aren't dealing with joints or structural integrity.
lovinthehd likes this.
DustinF is offline
post #207 of 233 Old 08-20-2015, 04:57 PM
kevings's Avatar
Quoted: 326 Post(s)
Liked: 507
Dustin,
Beautiful work. The craftsmanship and quality are obvious.
kevings is offline
post #208 of 233 Old 03-15-2016, 08:21 AM
sigma722's Avatar
Quoted: 606 Post(s)
Liked: 369
Anyone else made any stealth subs? This thread is super awesome.
sigma722 is offline
post #209 of 233 Old 03-15-2016, 09:15 AM
Al Toid's Avatar
Quoted: 222 Post(s)
Liked: 217
This is what I love about DIY! If it wasn't for you guys, none of us would have awesome setups. But due to your ingenuity and forward thinking, we can have a nice looking room and sound that matches
Now I have one for those who want sound in that last room. You know the kitchen or downstairs on the bar. The wife has said no a thousand times, until you come home with this It looks nice, is small and compact and gives you the ability to have sound in that last room that otherwise wouldn't. Best of all, it's bluetooth.
Al Toid is offline
post #210 of 233 Old 03-15-2016, 09:25 AM
neo_2009's Avatar
Quoted: 314 Post(s)
Liked: 229
Dual BMS 18N862 in 4,5 cf, in a walnut veneer:
First sub Finished (subs will be placed with driver facing the wall)
In the near future, the purpose is to build a full furniture for placing all the gear, using the same walnut veneer, with the subs at each extreme, as if everything is part of the furniture.
Maklar, ORIF and lovinthehd like this.
neo_2009 is online now
