Awesome WAF/SAF Builds - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 374Likes
post #211 of 250 Old 03-15-2016, 11:19 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Originally Posted by neo_2009 View Post
Dual BMS 18N862 in 4,5 cf, in a walnut veneer:
First sub Finished (subs will be placed with driver facing the wall)
In the near future, the purpose is to build a full furniture for placing all the gear, using the same walnut veneer, with the subs at each extreme, as if everything is part of the furniture.
Nice, put some legs on those and they would make some sweet MCM endtables
Sent from my LG-H811 using Tapatalk
manuetdeo is offline
post #212 of 250 Old 03-15-2016, 11:34 AM
neo_2009's Avatar
Quoted: 350 Post(s)
Liked: 255
I want to do something similar to this:
Original thread here: In Cabinet Subs Build
I have to design it yet, and guarantee it would be able to accommodate current gear and future exchanges, as well as a future bigger center speaker.
neo_2009 is online now
post #213 of 250 Old 03-15-2016, 12:02 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4796
What you bolded sunk in only when I saw the speakon connector on the face....first time I've seen that. Nice job!
lovinthehd is offline
post #214 of 250 Old 03-15-2016, 12:13 PM
neo_2009's Avatar
Quoted: 350 Post(s)
Liked: 255
Thanks, i wanted to hide the drivers, and the response is actually a bit better with the driver facing the wall, so it's a win win situation.
lovinthehd likes this.
post #215 of 250 Old 03-18-2016, 08:27 AM
hyperactiveme's Avatar
Quoted: 124 Post(s)
Liked: 84
You guys all suck.... So much envy :-(
Never to return here again
corradizo, azz7686 and mevansmusic like this.
hyperactiveme is offline
post #216 of 250 Old 03-18-2016, 08:55 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
Just photographed this this morning
Dual opposed 10" subs with a down firing port powered by a Dayton SA1000. My wife loves it.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #217 of 250 Old 03-18-2016, 09:13 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
Looks pretty sweet Ryan, I can see why she loves it.
Well done.
muzz is offline
post #218 of 250 Old 03-18-2016, 09:47 AM
squiers007's Avatar
Quoted: 789 Post(s)
Liked: 417
Very cool. You mentioned its DO, so is that acoustic fabric on the door then with the woofer hiding behind it? Also, any details on the woofer frame trim ring?
Check out my End-Table Marty Build
squiers007 is offline
post #219 of 250 Old 03-18-2016, 12:11 PM
Liked: 2229
Yes it's a faux grill.
The photos make the trim ring look like the don't fit well, but they're cnc tight. There's some discussion on trim rings I've been doing here: https://www.avsforum.com/forum/401-di...l#post42317585
I mention there that I could batch a bunch and sell them if there's interst. There's a photo on them on the cinema max at that link as well.
Thanks for the comoliments.
post #220 of 250 Old 03-29-2016, 03:26 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Not speakers, but she loves it and I'm proud of it so there!
3/4 oak ply with 1 inch oak front and espresso stain-
ORIF and ambesolman like this.
post #221 of 250 Old 03-29-2016, 03:31 PM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Don't mind the picture of the crappy coffee table I'm about to restain to match
post #222 of 250 Old 03-29-2016, 04:41 PM
climber07's Avatar
Quoted: 804 Post(s)
Liked: 2594
No worries man. Nobody cares what the crappy coffee table looks like (I have one too) if you have a kickass home theater system. Besides, crappy coffee tables are perfect for kicking your feet up...
manuetdeo, azz7686 and Will P like this.
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #223 of 250 Old 04-27-2016, 09:03 AM
JohnDean's Avatar
Quoted: 544 Post(s)
Liked: 254
Anyone have new builds to add?
JohnDean is online now
post #224 of 250 Old 04-27-2016, 04:04 PM
jshadzi's Avatar
Quoted: 110 Post(s)
Liked: 456
I build these for our living room, they are 44" tall and built using trans lam construction, wife actually loves the way they look and sound, more info at: http://projectgallery.parts-express....tower-speaker/
jshadzi is offline
post #225 of 250 Old 04-27-2016, 04:39 PM
joebuddyguy's Avatar
Quoted: 110 Post(s)
Liked: 153
I made this "soundbar" a little while ago by shoving three volt 6s in a single enclosure, internally separated from each other. It has a zebrawood baffle and sides with a padauk veneer on the rest of the enclosure. I made it specifically for my wife as she loves zebrawood. I'm fond of it too
krholmberg, ORIF, luisev and 5 others like this.
joebuddyguy is offline
post #226 of 250 Old 04-27-2016, 04:41 PM
Quoted: 110 Post(s)
Liked: 153
Looks awesome man....I've always loved the translam builds. I think I'll try my hand on one...smaller cabinets than those though for my first go lol.
krholmberg and jshadzi like this.
post #227 of 250 Old 04-28-2016, 06:08 AM
Brad07z06's Avatar
Quoted: 67 Post(s)
Liked: 74
Update on mine. Built 2 end tables ported rear firing 3.2 cuft tuned 20hz sundown sa12 with inuke 3000 2 ohm per channel.
So I have 2 um 18's and 2 sa12's in living room. The 12's helped by smoothing the response across all sitting areas.
ID:	1410730   Click image for larger version
Digity8, popalock, jshadzi and 1 others like this.
Brad07z06 is offline
post #228 of 250 Old 04-28-2016, 07:25 AM
EndersShadow's Avatar
Quoted: 1250 Post(s)
Liked: 1525
I'd love to see some more detailed pictures of those if you dont mind...
tuxedocivic likes this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #229 of 250 Old 04-28-2016, 01:57 PM
gleite311's Avatar
I really like this. Did you happen to post a build thread? I've been considering building my own center channel and would definitely consider this design. How do you like the way it sounds?
gleite311 is offline
post #230 of 250 Old 04-28-2016, 03:15 PM
corradizo's Avatar
Quoted: 1536 Post(s)
Liked: 1596
Easily the most stealth setup I've ever seen. More pics please!!
corradizo is online now
post #231 of 250 Old 04-28-2016, 04:59 PM
Quoted: 110 Post(s)
Liked: 153
Thanks man! Here's the build thread:
https://www.avsforum.com/showthread.php?t=1714226
I really like the way it sounds... Never sounds strained, dialog is very clear despite having it so close to the mantle and I don't feel like it's much of a compromise compared to a properly separated lcr. I definitely recommend this approach if the form factor appeals to you or your significant other. It was fun working with the more exotic hardwoods too...although they weren't particularly easy to work with, especially the zebrawood.
post #232 of 250 Old 04-28-2016, 07:49 PM
Augerhandle's Avatar
Quoted: 1247 Post(s)
Liked: 1248
..and if you don't have a mantle, you can use this for inspiration
pjp, azz7686, onkal and 1 others like this.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #233 of 250 Old 04-29-2016, 03:35 AM
Liked: 1525
Here is the link
https://www.avsforum.com/forum/155-di...-isolated.html
joebuddyguy likes this.
post #234 of 250 Old 07-23-2019, 03:37 PM
mevansmusic's Avatar
Quoted: 60 Post(s)
Originally Posted by chalugadp View Post
Downfiring martycube
Got a cut sheet for this? I suck.
Sent from my Pixel XL using Tapatalk
mevansmusic is offline
post #235 of 250 Old 07-23-2019, 04:17 PM
pjp
pjp's Avatar
Quoted: 588 Post(s)
Liked: 383
My first build and the first audio component my wife likes (18" side table sub). It was actually this WAF thread that inspired me to build it. When I saw the thread, I said to myself "one day I'm going to build one of those". It took me a few years to find the time to actually do it, but very happy with the results and I'm thankful to everyone who provided the inspiration and examples to build upon.
pjp is offline
post #236 of 250 Old 07-23-2019, 07:23 PM
Liked: 1525
“Organ Donor”. Repurposed Hammond PR40 cabinet...
4 JBL 1214 in a sealed ~5.0 CF cabinet.
Driven by one of my Crown XLS2000s
post #237 of 250 Old 07-23-2019, 07:55 PM
Quoted: 60 Post(s)
Originally Posted by pjp View Post
My first build and the first audio component my wife likes (18" side table sub):
Do you have a build threat or a cut sheet?
post #238 of 250 Old 07-24-2019, 06:00 AM
Quoted: 158 Post(s)
Liked: 163
Don't think I ever posted my VBSS end tables in here. No build thread, but I have some Youtube videos of the build.
Build videos in signature.
Epson 2030 - Denon X1300W - Eosone RSF 1000 - Eosone RSC 300 - Volt-10 - Micca M-8C for ATMOS
2 @ VBSS End Tables - 2 More VBSS on the Way
DIY 110" AT Screen
jevchance is online now
post #239 of 250 Old 07-24-2019, 07:39 AM
trilkb's Avatar
Quoted: 655 Post(s)
Liked: 333
Damn, theres some people on here who do some good work!
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #240 of 250 Old 07-24-2019, 09:02 AM
pjp
pjp's Avatar
Quoted: 588 Post(s)
Liked: 383
I used the Parts Express sealed 18" box as a foundation, finished the MDF with cherry veneer, and then built the legs/top/framing around it. I did create a thread for it, but as a newbie, it was much more of a "desperate plea for help" than a "build" thread -> https://www.avsforum.com/forum/155-d...table-sub.html
pjp is offline
