Just finished my Home Depot 5 gallon bucket subwoofer (LARGE PICTURES - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 3 Post By AverageJoeAudio
  • 2 Post By LTD02
Old 09-18-2014, 03:09 PM - Thread Starter
AverageJoeAudio's Avatar
Quoted: 52 Post(s)
Liked: 78
Here is my bucket subwoofer. While being bored during some down time at work, I looked for new DIY project and stumbled up this:
http://www.transcendentsound.com/Tra...Subwoofer.html
A small subwoofer using a 5 gallon bucket as an enclosure, awesome right?
So I gave it a shot; made some adjustments along the way and learned a good bit. Overall it was fun, but not without a few frustrations. I might have to try the sump sub next.:
https://www.avsforum.com/forum/155-di...ver-style.html AND https://www.avsforum.com/forum/155-di...subwoofer.html
Full album of step by step creation.
http://imgur.com/a/PJVR1
I started off with just a $3 Home Depot bucket and a dream.
http://i.imgur.com/HQxYxeo.jpg
I then cut the hole for the Peerless SLS 830667 Paper Cone Subwoofer and glued the hell of our the top and hammer it on to the bucket with a rubber mallet.
http://i.imgur.com/i8by0AK.jpg
I decided to try and port this one, but I also wanted to give myself an easy out just in case I totally screwed up. So I integrated a way to close off the port and seal up the enclosure.
http://i.imgur.com/QF7wrEm.jpg
http://i.imgur.com/zfHhRkd.jpg
Porting it seems to have worked well enough. From my fuzzy math it should be tuned to about 30hz. Did that actually happen? Probably not. See the test results at the end.
Concrete is poured in, about 1.5 inches deep and left to dry for a few days
http://i.imgur.com/rkWHaiq.jpg
http://i.imgur.com/uLPeqAo.jpg
Attaching the wood baffle for the driver, this is where I learned that these types of buckets are near impossible to actual glue anything to. Polypropylene and Polyethylene low energy or inert or something else all sciency so 3M made an expensive magic glue to work on them. Thank God for screws then. When the cut out was made for the woofer, a lot of tension was taken off the bottom of the bucket which caused the left over "lip" that I was trying to mount the baffle to, to angle into the bucket. The glue and screws were an attempt to pull that lip back up and get a secure mounting surface.
http://i.imgur.com/KYhlfbr.jpg
Painting time. I used truck bed liner, which also doesn't stick very well. But once it cures its tough enough to not flake off immediately. Never mind the nearly dead grass, this is California and if you have green grass right now then F you.
http://i.imgur.com/TOzXu0R.jpg
http://i.imgur.com/LUXehF1.jpg
Cheap, crappy speaker terminals form Radio Shack. Never again.
http://i.imgur.com/OryVLcH.jpg
Mounting the woofer and putting some stuffing in. A whole bunch more as added just after this picture
http://i.imgur.com/xALGig4.jpg
AND NOW IT'S DONE!!!!!111
http://i.imgur.com/FdS2QvB.jpg
Since the subwoofer enclosure is made of a bucket, I needed some where or someway to mount the BASH 300S plate amp. So since we are working with plastics, I found a handing file box at Staples that suited the amp well enough.
The future amp box
http://i.imgur.com/w5DhJ8D.jpg
Drilling some pretty pretty air vent holes. I used a checker board pattern to make them nice and even-ish
http://i.imgur.com/WqyugAa.jpg
Cut out for the amp done
http://i.imgur.com/O0R5Q2V.jpg
AND NOW THAT'S DONE TOO!!!1
http://i.imgur.com/7pGpjgF.jpg
So how did this thing actually turn out?
From just listening to music and watching a few movies, it definitely provides some kick and sounds pretty alright to me. Much louder than the Dayton Sub-800 that I normally have on all the time; and I think it might be darn close to besting the Dayton Sub-1200. Getting into more technical understanding on how well it blends or transient response and all that, Im not the best judge. I'm a car audio bass head who rolls around with an 18 in the back of my Ford Fusion so you can see where my priorities lie.
But I did take some in room responses so at least we can see a little bit of the technical results. So check these out. As a note, I'm still having trouble with REW, Dayton UMM 6 and my PC getting a consistent overall volume. You'll note that the graphs are centered around the 100 db mark, just prior to these testings, I was getting results centered around 80 db. Graphs look identical, just centered at the wrong point.
**Ported vs Sealed response.** Not a huge difference, but audible for sure. Ported open is louder accross the usable spectrum. My room has clear peak at 100hz and that showed in all subs tested.
**Bucket Sub vs Dayton Sub-1200.** This was most supriseing. The bucket sub is louder than the Dayton from 50hz to 100hz and equal from 50hz to 35hz where the Bucket sub gets louder again.
A few additional images of other sub tests can be seen below
http://imgur.com/a/NqKOr
LTD02, mlah384 and Bob7145 like this.
AverageJoeAudio is offline
Old 09-18-2014, 03:30 PM
LTD02's Avatar
Quoted: 2920 Post(s)
Liked: 3626
what a cool build and thread!!
by using the "Insert Image" button, it will open the dialog box where if you enter the imgur link will show your pic in the post like this:
legacyfarm and Bob7145 like this.
Listen. It's All Good.
LTD02 is offline
Old 09-18-2014, 03:59 PM - Thread Starter
Quoted: 52 Post(s)
Liked: 78
Thanks! I tired that, but some of the pictures are pretty massive and not resized. Makes it look a little ugly.
Old 09-18-2014, 05:19 PM
LTD02's Avatar
Liked: 3626
roger. :-)
LTD02 is offline
Old 01-07-2015, 03:28 PM
kevings's Avatar
Quoted: 326 Post(s)
Liked: 507
Op, Nice job. I love unique builds like this.
ps - the line you wrote above had me seriously lol.
ps-ps one day I really do want to wire up a spare 12 inch driver and place it into a backpack and see if i can convince my wife that she needs to wear it during a movie and that wearing it is now a standard part of our movie watching procedure.
kevings is offline
Old 01-07-2015, 04:19 PM
sickboy013's Avatar
Quoted: 33 Post(s)
Wow! Good job!
sickboy013 is offline
Old 01-07-2015, 04:23 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
The only problem is these buckets are quite flexible :/
notnyt is offline
Old 01-22-2015, 03:40 PM - Thread Starter
Quoted: 52 Post(s)
Liked: 78
Thanks everyone. It was a fun project but sadly isn't getting much used right now. It's been sitting unplugged and has been replaced by a sealed Adire Audio Maelstrom. I do have plans to try a duel opposed sonotube build with some 10 inch Daytons that I have.
