TM on top 1099's + V8's - AVS Forum | Home Theater Discussions And Reviews
 21Likes
  • 2 Post By spotts29
  • 1 Post By spotts29
  • 3 Post By spotts29
  • 5 Post By spotts29
  • 2 Post By eng-399
  • 2 Post By tuxedocivic
post #1 of 22 Old 10-08-2014, 07:44 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
This:
is what I've been trying to re-create via Erich's flatpacks over the last few weeks. I've been too chicken to post until now, in case it blew up in my face...
Goals:
#1 - Improve SQ: I like my system now, but I've been wondering What If? lately. Then some of the reviews started rolling in over the summer, and 1099 Fever set in.
#2 - Build something: It's been a long time since 8th grade woodshop, and I sold/gave away all my tools a few years ago when we moved, but I still had the itch. Combine that with a renewed interest in HT, and DIY was a no-brainer (haha - famous last words). Fortunately, Erich makes it almost that easy...
#3 - Go big: At first, I thought the 1099's were too big for my room. A couple of brief emails with Erich were spot on, and nudged me in the right direction - if I was going to do this, do it big. And trade out the TV and stick them below a projector screen. Ugh, this site is really bad for my bank account!
#4 - WAF: This fits with #3 . The only way I was going to get buy-in on the size of the 1099's was to make 'em pretty. So I dropped a bunch of cash (and brain cells) on cherry veneer. Not again any time soon - just say no to contact cement.
#5 - Placement: Somewhere in one of the threads, it was mentioned that the 1099's would minimize boundary effects, and placement is key for me. My room (more info in sig) has potential to be really good, but the #1 drawback is that the front wall is also the hallway from the garage to the upstairs, so all the equipment has to be smack up against the front wall (or it will get run into by loads of groceries). If the 1099's help with this, it will be effort well spent (measurements to come later).
So, I posted this here:
and got this response from Tux - from that point, it was game on...
Oh, and I threw in a couple of V-8 Volts for surrounds for good measure.
Erich H and jaymind like this.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #2 of 22 Old 10-08-2014, 07:45 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Shopping List
I kept pretty close track of what I bought during the course of the project, I hope someone else finds this helpful.
Name:	Speaker Build shopping list.jpg
rikomatik likes this.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #3 of 22 Old 10-08-2014, 07:45 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Crossovers
I used @mtg90's layout here as a template. The tops look similar, but the bottoms - not so much...
Boards cut, dry run
And a few nights later...
Flipside
All tested OK, sounds good so far
ID:	300418   Click image for larger version
ID:	300426   Click image for larger version
ID:	300434   Click image for larger version
ID:	300442   Click image for larger version
Erich H and Philip Frederick like this.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #4 of 22 Old 10-08-2014, 07:45 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Boxes & Baffle Surgery
The obligatory photo showing Erich's mastery of the packing arts:
V8's went together easy
Weight that sucker down with whatever you have on hand (found use for dead UPS) - center channel box
Post baffle surgery dry fit (found out my neighbor has a DeWalt table saw - woohoo!)
Box modification - in hindsight I should have re-done the dado, but I just shelved it in with glue (and yes, mistakes were made )
Rocky to the rescue! Was a little bit worried about it being brittle, but this stuff has worked really well for a variety of things in the past, and doesn't swell, so I went with it.
Sanded up nicely - too bad about that focus thing. Note magnets for grills.
ID:	300458   Click image for larger version
ID:	300474   Click image for larger version
ID:	300482   Click image for larger version
ID:	300498   Click image for larger version
ID:	300522   Click image for larger version
Fatshaft, Boxozaxu and Erich H like this.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #5 of 22 Old 10-08-2014, 07:46 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Veneer and Finishing
V8's are the guinea pigs - never veneered anything before. Many thanks to @chalugadp for the YouTube videos!
Note pieces of grill frame used to help position veneer.
Seems to have turned out OK
Center getting the treatment
Disaster strikes! Trim router bearing slipped off the front edge at the top of the WG opening and scooped out the top/front edge of the cabinet
Flaw hidden - whew!! Ending up cutting a new top piece of veneer, re-veneering the top and *very carefully* setting the router depth and trimming the front edge. When the front piece of veneer went on, it matched up perfectly. Damn lucky
LCR ready for sanding
Finishing Plan:
The finish work is definitely the weakest part of my game, and I got a bit paranoid reading all of the "blotchy cherry" posts on the web, so when the local Woodcraft store had a one-day class advertised, I signed up. The instructor had 40 years of experience making furniture and guitars and really seemed like he knew what he was talking about. I ended up changing my original plan of just using Tung oil to the oil-based General Finishes stuff based on the mini projects we did during the eight hour class.
Here is what I ended up with:
1) Clean up all the glue boogers on the faces and edges with small scraper and P100 sandpaper where needed <-- ack, hardest/longest part!
2) Sand 20 strokes with Norton 3X P220 (the instructor was a sanding fanatic and had us count strokes - prep work FTW!!)
3) Sand 20 strokes with Norton 3X P320
4) Apply General Finishes Seal-A-Cell Clear - brush on, wipe off, let dry 24 hours
5) Scuff with 0000 steel wool, apply General Finishes Arm-R-Seal Satin top coat - brush on, wipe off, let dry 12-24 hours
6) Repeat Step 5 twice more for three top coats total
7) Final light scuff with 0000 steel wool for matte/satin finish
Sanding - four down, one to go
Sanding complete, seal applied.
V8's:
L & R:
Really happy with the color so far. Was going for a honey/amber that will show the grain and let the cherry naturally age to a slightly darker pink/red underneath, and this is right on track with that. My sample ended up a bit darker after three top coats, but that also sat in the sun a bit, so picked up some of the natural coloration already. Looking forward to see how the bigger faces compare.
All I need is a bit of steel wool dust to find the grill magnets - they pull the stuff right out of the air...
Finishing done - now on to the fun part!!
ID:	300602   Click image for larger version
ID:	300610   Click image for larger version
ID:	300618   Click image for larger version
ID:	300626   Click image for larger version
ID:	300658   Click image for larger version
ID:	302266   Click image for larger version
ID:	303826   Click image for larger version
ID:	303834   Click image for larger version
Wow, splendid days!
Speaker Build
spotts29 is offline
post #6 of 22 Old 10-08-2014, 08:09 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Wiring, Stuffing & Drivers
Got all the drivers and connector wires wrangled this weekend in between layers of top coat
A helpful little reminder courtesy of my assistant and his silver Sharpie
Foam pieces cut
Stuffing V8's. That's a piece of an old mesh laundry bag that I cut up to keep the poly fill from smothering the crossover. I did the same thing at the port openings on the bottom - not sure if it's really necessary, but it was easy to do so I figured why not.
Done with V8's, time for a little LR duty for testing
I'm really kind of stunned at how good they sound. I have a pretty low bar in terms of my old speakers, but these just crushed my old center channel - especially with the volume getting up there. Going to be a long day at work before I can get at least the center 1099 done tonight!
The 1099's take a lot longer to wire and stuff than the V8's, that's for sure - just a lot more going on... Having said that, the center is done!
In progress, trying to impersonate a Domokun
And made it in time for the Daily Show
Hard to tell much from just a cable TV talk show with it sitting on the floor (wife had dibs on the basement), but it is definitely very clear and voices are distinct. Looking forward to spending more time with it fore sure.
A couple of pics from the stretch run (got a late start so didn't take many)
Left done
Right done
Room is a mess, but they're in
Did some quick 1:00am testing with Pandora - I know I know, but I was too tired to choose anything good... HOLY CRAP I JUST BUILT SOME NEW SPEAKERS AND THEY SOUND REALLY FREAKING GOOD!
ID:	309138   Click image for larger version
ID:	309146   Click image for larger version
ID:	312514   Click image for larger version
ID:	312522   Click image for larger version
ID:	312538   Click image for larger version
ID:	314682   Click image for larger version
ID:	314690   Click image for larger version
ID:	316426   Click image for larger version
ID:	316442   Click image for larger version
ID:	316450   Click image for larger version
Wow, splendid days!
Speaker Build
spotts29 is offline
post #7 of 22 Old 10-08-2014, 01:31 PM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Grills
Under construction
Wow, splendid days!
Speaker Build
spotts29 is offline
post #8 of 22 Old 10-08-2014, 01:44 PM
mbyrnes's Avatar
Quoted: 138 Post(s)
Liked: 249
Coming along nicely! This is the first build I've seen putting the woofers on top of each other. Can't wait to see them finished!
mbyrnes is offline
post #9 of 22 Old 10-09-2014, 07:04 AM
Boxozaxu's Avatar
Quoted: 513 Post(s)
Liked: 352
Subscribed! You're doing a great job and nice save on the veneer. I always get a little tense myself when I finally get to those last few steps.
That dead UPS might just need a new battery. I've replaced several in my APC UPSs. They're just generic lead batteries you can order directly from Amazon or some other battery selling website. Just get the same voltage and around the same amount of amps. (more amps if you want longer run time during a power outage)
Keep up the good work!
Boxozaxu is offline
post #10 of 22 Old 10-09-2014, 08:37 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Thanks for stopping by, and thanks for the tip on the UPS. I just grabbed it out of the dumpster at work a couple of weeks ago and haven't really had a chance to play with it much yet. I don't even know it if it's dead for sure, just that IT chucked it when they were moving some stuff. Knowing our IT crew, it's probably fine
Wow, splendid days!
Speaker Build
spotts29 is offline
post #11 of 22 Old 10-10-2014, 10:52 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Bumped for updates above, mostly to Finishing section.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #12 of 22 Old 10-10-2014, 11:15 AM
dtsdig's Avatar
Quoted: 1140 Post(s)
Liked: 1406
Looking sweet! I'm going with cherry too and I'm very jealous of your progress!
dtsdig is offline
post #13 of 22 Old 10-15-2014, 06:34 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Bump for updates - all finishing done; V8's wired, stuffed and rocking!
Wow, splendid days!
Speaker Build
spotts29 is offline
post #14 of 22 Old 10-15-2014, 06:49 AM
tuxedocivic's Avatar
Quoted: 2303 Post(s)
Liked: 2235
Hey awesome. Someone did it! I like how it looks. You're moving very fast. They look great
tuxedocivic is offline
post #15 of 22 Old 10-15-2014, 10:28 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Thanks Tux! I was moving really slow for a long time, now I just want to get it done - and the wife does too - so she's been OK with me spending a few hours a night in the garage...
Thanks very much for laying out your thought process on the 1099 thread - it was the one thing that pushed me over the edge and got going on building these. As this is my first attempt at DIY, reading your insight on what you (and Erich) did and why, measurements, etc. was really cool and something that sets DIY *way* apart from buying commercial. Great stuff, I learned a ton, and will never listen to speakers the same way again - in a good way
Wow, splendid days!
Speaker Build
spotts29 is offline
post #16 of 22 Old 10-17-2014, 06:35 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Bump for done. Let the testing & tweaking begin...
Wow, splendid days!
Speaker Build
spotts29 is offline
post #17 of 22 Old 11-03-2014, 08:25 AM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Yet another crappy photo - and still have some little things to sort out, but it all looks a bit more in scale now that the screen is up.
Randybw1 likes this.
Wow, splendid days!
Speaker Build
spotts29 is offline
post #18 of 22 Old 06-24-2015, 08:09 PM - Thread Starter
spotts29's Avatar
Quoted: 38 Post(s)
Liked: 82
Cross-posting a couple of pics from the recent Chicagoland GTG, thanks @eng-399 for the awesome venue and @holyindian for the terrific photos!
(Im)patiently waiting their turn
Action photo
Wow, splendid days!
Speaker Build
spotts29 is offline
post #19 of 22 Old 06-24-2015, 09:15 PM
eng-399's Avatar
Quoted: 2476 Post(s)
Liked: 5152
I figured I would post this since I heard and seen these 1099's in person at the GTG. The finish is top notch I would give it a 10 a lot of people who seen these that day were all very impressed!!! The sound is amazing to I wish I had these in my room maybe down the road... Great job on the build and finish spotts!!! I'm sure your going to be happy for years to come with these I sure would.
spotts29 and EarlK like this.
eng-399 is offline
post #20 of 22 Old 06-24-2015, 09:34 PM
Liked: 2235
Now I remember this! Fantastic looking. Wish I had these myself! That's always a neat feeling when someone makes a set that I envy
Hope you enjoy them for a long time.
post #21 of 22 Old 05-22-2020, 02:35 PM
jeremiahsyoung's Avatar
Liked: 42
Beautiful job on the finish. It's quality jobs like this that make it easier to convince the wifey.
jeremiahsyoung is offline
post #22 of 22 Old 05-23-2020, 08:50 AM
Quoted: 153 Post(s)
Liked: 134
I love it when someone revives a zombie thread.
dorri732 is offline
