Another Impractical Build for the Masses: One Sub = 126db @ 16Hz - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 621Likes
post #241 of 1151 Old 11-14-2014, 01:11 AM
diy speaker guy's Avatar
Quoted: 510 Post(s)
Liked: 525
Originally Posted by popalock View Post
I just downloaded the Akabak program a few months back, but in all honesty, I have yet to spend the time figuring out the basics with Hornresp, much less make the time to get into the weeds with Akabak.
This link got me up and running very fast. Within two hours I could draw out a schematic and write a script for fairly complex enclosures. This thread deserves some kind of award, I haven't found any resource better for a quick start guide.
https://www.avsforum.com/forum/155-di...k-dummies.html
So, based on the sims (I understand sims are not the end-all-be-all), I should technically be good to go with the design as it currently stands, correct? That is great!
You can if you like or you can modify it, remember, no matter what you do the room is going to dominate the response, but it is nice to start with a design that doesn't have any massive notches in response. I don't see anything needing fixing the way it is now.
That said, I am willing (if there is a tangible/simulated benefit) to put my track saw to use and hollow out the two most inner panels where it is pretty much just a 2" border. Would be able to knock that out with minimal effort...
Not sure what benefit that would provide, and it would also make the brace much less effective. The velocity through the side chamber holes is already very low, this modification would lower it further but probably make the response a bit worse. (I already ran a quick sim with one large side chamber instead of three separate small ones just to see what would happen and the response was a bit worse.)
Since you've already helped me out and put in all of the information to model in Akabak, would it be quick exercise to change that one parameter?
Man, this is really good stuff... Thanks again to everyone for their assistance.
Think about what change you would like to see (I don't recommend the change you suggested, that's going too far IMO) and let me know. If I can find a few minutes I'll run the sim again tomorrow with the changes. And just to be really sure include a picture. Akabak doesn't have a schematic drawing so if you can't read Akabak and I misunderstand what you want neither of us will know that I didn't accurately sim what you wanted.
Also, you might want to shoot me some proper plans to make sure the dimensions I used are all accurate. Or you might be able to verify those details in tthe script I posted along with the Hornresp drawing and the description of what I added in Hornresp.
To be honest, what I would recommend is leaving the braces alone, finishing it, putting it in place, putting the top on, listening and measuring. If you can't find any obvious problems I don't see any need to change anything. If there is a problem, rip the braces at that point. Do it right where it sits when no one is home. No problem.
If there is a problem I think it will probably be port exit velocity, not an internal issue.
popalock and MemX like this.
diy speaker guy is offline
post #242 of 1151 Old 11-14-2014, 03:27 AM - Thread Starter
popalock's Avatar
Quoted: 1495 Post(s)
Liked: 2097
Ah yes, I do recall visiting that site after reading lilmike mention it awhile back. I had a problem opening it up on my Windows 8 laptop. I still plan on figuring out how to get it up and running soon, but have to pick my battles at this point in time to try to keep the peace with the wifey... Once I start going down the rabbit hole to learn something, I find it consumes me and it always ends up with me sleeping on the couch.
Ok, I will leave it as is for now and seal it up.
Don't even worry about it man. You have already went above and beyond and I appreciate it more than you know. I owe you a beer for sure.
Copy. On it...
Man, I hope not. I've read different information from different sources and my goal was try try to keep it under 26m/s. This is going to be a learning experience for me indeed.
popalock is offline
post #243 of 1151 Old 11-14-2014, 08:35 AM - Thread Starter
popalock's Avatar
Liked: 2097
I hope to attach the top tonight.
Couple more perspective shots...just because.
Port channel:
I took the time to round off the 90 degree angles. I doubt it will make a difference with anything, but I figured it wouldn't hurt to "soften" an edge where I could.
Did the same thing on the edge of the panel leading into the actual port...
Erich H and ambesolman like this.
popalock is offline
post #244 of 1151 Old 11-14-2014, 11:56 AM
asoofi1's Avatar
Quoted: 939 Post(s)
Liked: 444
Gamecock24 likes this.
asoofi1 is offline
post #245 of 1151 Old 11-14-2014, 12:05 PM
beastaudio's Avatar
Quoted: 5644 Post(s)
Liked: 5499
"YOSE......Tote-ally Safe"
beastaudio is offline
post #246 of 1151 Old 11-14-2014, 12:09 PM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1332
^^^ Nice picture, ) looks like Austin changed his style after hangin' with the Sheiks. He will come back to states all blinged out with $750K in gold jewelry.
Scott Simonian likes this.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #247 of 1151 Old 11-14-2014, 01:28 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
I admit I have not been following 100% the most recent. What did you decide for the braces? open them up?
Mfusick is offline
post #248 of 1151 Old 11-14-2014, 03:49 PM
noah katz's Avatar
Quoted: 2101 Post(s)
Liked: 758
Right, hat won't really make a difference; what will help a lot more is putting 45 deg corner pieces on the outside of the turns.
That will better guide the air around the turn vs. it just slamming straight into the wall.
Dunno if any of the mentioned programs able to handle details like this to determine whether it makes a significant difference.
Noah
noah katz is offline
post #249 of 1151 Old 11-14-2014, 03:58 PM
LTD02's Avatar
Quoted: 2960 Post(s)
Liked: 3694
"Right, hat won't really make a difference; what will help a lot more is putting 45 deg corner pieces on the outside of the turns.
That will better guide the air around the turn vs. it just slamming straight into the wall."
I couldn't find anything to suggest that makes a difference when I researched it a while back.
Listen. It's All Good.
LTD02 is offline
post #250 of 1151 Old 11-14-2014, 04:14 PM
LTD02's Avatar
Liked: 3694
and fwiw after sleeping on it, I'd suggest (even though I hate to suggest it) cutting out the part of the brace above the circle thus turning the braces into U shaped but I don't have any data or even a good working theory for why I would suggest that. :-)
LTD02 is offline
post #251 of 1151 Old 11-14-2014, 04:28 PM
ambesolman's Avatar
Quoted: 1165 Post(s)
Liked: 975
I thought he went over there like that. Pop, just don't go too far with it and OG (over gold)...
Sent using Tapatalk since the mobile version is still
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is offline
post #252 of 1151 Old 11-14-2014, 07:25 PM
Gamecock24's Avatar
Quoted: 379 Post(s)
Liked: 158
Sent from my iPhone using TheChive - KCCO!
ambesolman and asoofi1 like this.
Gamecock24 is offline
post #253 of 1151 Old 11-16-2014, 12:43 PM
CherylJosie's Avatar
Quoted: 798 Post(s)
Liked: 323
Probably couldn't plan this result much better if you were trying, the sim above is a pretty good response.
Quick, patent it!
CherylJosie is offline
post #254 of 1151 Old 11-16-2014, 07:48 PM
Pain Infliction's Avatar
Quoted: 980 Post(s)
Liked: 515
I have been away for a while and I come back to see this amazing build. Thank you for keeping your crazy ambitious builds going and sharing on AVS! Good luck on sorting out the bracing and I will continue to stay tuned to see the progress.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #255 of 1151 Old 11-16-2014, 09:12 PM - Thread Starter
popalock's Avatar
Liked: 2097
Originally Posted by lukeamdman View Post
Dang, I still just can't believe how huge that thing is!
Who has a DIY build bigger than this?
Well, there is always @robertcharles POTENTIA MAXIMUS. Might not be quite as long/tall as mine, one of his cabinets will most likely end up weighing twice as much as mine when I am done and his finishing skills are just awesome.
I'm really struggling with how I want to finish these guys... On one hand, I want to make them nice. On the other, the chances of me being able to bring these back with me stateside are slim... They are going to blow our weight limit out of the water...lol.
popalock is offline
post #256 of 1151 Old 11-16-2014, 09:35 PM
chrapladm's Avatar
Quoted: 1113 Post(s)
Liked: 449
Keep it simple and do a simple satin and poly finish. No need to get crazy and ten have to scrap the whole cabinet down the road.
And didnt Robert have jewels made for his subwoofers?
chrapladm is offline
post #257 of 1151 Old 11-17-2014, 12:21 AM
LTD02's Avatar
Liked: 3694
"I'm really struggling with how I want to finish these guys... "
Name:	popa desert digital.png
Fatshaft, dgage and ORIF like this.
LTD02 is offline
post #258 of 1151 Old 11-17-2014, 12:54 AM - Thread Starter
popalock's Avatar
Liked: 2097
Yeah, the finishing touch on his incredible statement pieces. His jewels alone cost more than my entire sub build(s) and amp...lol.
Haha...if only I had an outdoor desert theater...this would be perfect!
popalock is offline
post #259 of 1151 Old 11-17-2014, 01:06 AM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
At that size and weight I'd do as has been said above. A few coats of poly or if you want to add some colour then a little stain first.
Coming from someone who has made something so large before they are extremely hard to move around without dinging them.
kingpin111 is offline
post #260 of 1151 Old 11-17-2014, 03:35 PM
Quoted: 798 Post(s)
Liked: 323
Is that the Desert Storm finish option? Where's the turret? Or is this the device they lower down to the Continental Shelf for full-ocean sonar?
post #261 of 1151 Old 11-18-2014, 08:36 PM - Thread Starter
popalock's Avatar
Liked: 2097
Thanks again everyone for helping me sort out the bracing issue. Have yet to put the top on and seal this guy up because I'm trying to prove to the wife that this build isn't consuming me like my other builds have in the past. Been coming home, popping in either Orange is the New Black or Modern Family then engaging in some deep deep conversation to keep the ol' relationship strong... <---Always seems more important as soon as the wife sees that I'm really into a project or something else is taking more of my time than her...lol.
Anyway, back on topic...Shout out to @R Swerdlow for his post on hex drive inserts for soft wood here.
I'll be mounting the 24's with these inserts:
And these screws:
Any objections or input on using these?
I figure I might as well make this box nice and pay attention to the finishing details if not only for the additional experience of it...
popalock is offline
post #262 of 1151 Old 11-18-2014, 09:03 PM
baniels's Avatar
Quoted: 219 Post(s)
Liked: 363
Go for it. I used the same method for a couple sealed 18's (link in sig). I used different bolts but the same or very similar her driver inserts.
I've never felt more sure that a driver was secure, and you don't have the worries of stripping out the material.
Just follow the spec on the pilot hole. Add a dab of glue to the outside teeth of the insert if you are paranoid.
And these screws:
baniels is offline
post #263 of 1151 Old 11-19-2014, 06:34 AM
jpmst3's Avatar
Quoted: 200 Post(s)
Liked: 316
And these screws:
They should work nicely.
I have used these on a couple of builds and they are work amazingly well, cheap, fool proof, no stripping, no misalignment issues, etc. etc.
Joe = LFE Addict
Past Builds: 24" LMS-5400 cube, Anarchy 25Hz Tapped Horn, Danley DTS-10 kit, BFM AutoTuba, BFM THT, BFM THT-LP
Joe's LOWARHORN build, Dual LMS-5400 Ultra Endtables build
jpmst3 is offline
post #264 of 1151 Old 11-19-2014, 07:19 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2727
I just use threaded screws and dip them in glue before I screw em in... I'm simple like that. Never had one tear out. A drywall screw into ply or MDF has holding power of 200 pounds or so per screw, I doubt you need more than 1000 pounds of pressure holding that sub in place.
Mfusick is offline
post #265 of 1151 Old 11-19-2014, 02:05 PM
Augerhandle's Avatar
Quoted: 1280 Post(s)
Liked: 1263
And these screws:
I have basically the same screws http://www.amazon.com/gp/product/B005DS8E5W and inserts http://www.amazon.com/gp/product/B002WC8TUC in a size 10-32 being delivered tomorrow for my 15" build.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #266 of 1151 Old 11-20-2014, 12:39 AM - Thread Starter
popalock's Avatar
Liked: 2097
I hear you and I agree that it isn't really necessary. Spax screws have served me well over the years. Just looking to do something a bit different to refine my finishing skillz. Might serve me well when it comes time to "attempt" to sell the box in a few years.
Mountstanding. Thanks for the feedback.
Peer validation received. Insecurities gone...
popalock is offline
post #267 of 1151 Old 11-20-2014, 09:21 AM - Thread Starter
popalock's Avatar
Liked: 2097
Progress.
Sometimes you gotta dominate.
popalock is offline
post #268 of 1151 Old 11-20-2014, 09:28 AM
HFGuy's Avatar
Quoted: 237 Post(s)
Liked: 255
Jeeze, those photos really put the size into perspective.
kingpin111 likes this.
HFGuy is offline
post #269 of 1151 Old 11-20-2014, 09:30 AM
beastaudio's Avatar
Liked: 5499
Dude, no shave forever? I am only 3 weeks in on my bada%$ beard. Or is that 3 weeks? I am embarrassed.....
post #270 of 1151 Old 11-20-2014, 09:35 AM
klipsch's Avatar
Quoted: 192 Post(s)
Liked: 100
haha ... at least you are having fun!
klipsch is online now
