Bunker Buster build - AVS Forum | Home Theater Discussions And Reviews
 802Likes
post #1 of 822 Old 10-18-2014, 03:23 PM - Thread Starter
PassingInterest's Avatar
Quoted: 195 Post(s)
Liked: 533
Bunker Buster build
Each ordnance will be armed with an HS24, manufactured by Stereo Integrity.
Many thanks to ChopShop1 for selling me a pair of HS24s at a price I could afford.
Many thanks to MJAudio for alerting me to their availability and for conveying his excitement for the sound quality and output of this product. He has heard a lot of subs, so his enthusiasm for these drivers spoke volumes for their quality.
Many thanks also, to mtg90 and LTD02 for guidance regarding the advisability of using grills with this much air movement as well as the effectiveness of pillows for controlling standing waves inside the cabinets, should the dimensional challenges produce them.
Enjoy the show.
Triple 10 Howitzer comparison.
PassingInterest is offline
post #2 of 822 Old 10-18-2014, 04:01 PM
Fatshaft's Avatar
Quoted: 593 Post(s)
Liked: 921
sub'd
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #3 of 822 Old 10-18-2014, 06:13 PM
tuxedocivic's Avatar
Quoted: 2302 Post(s)
Liked: 2232
Oh boy!
Subscribed!
tuxedocivic is offline
post #4 of 822 Old 10-18-2014, 06:21 PM
LTD02's Avatar
Quoted: 3004 Post(s)
Liked: 3770
^^if that is too stupid, I can delete it. :-)~
PassingInterest and Jk7.2 like this.
Listen. It's All Good.
LTD02 is offline
post #5 of 822 Old 10-18-2014, 06:36 PM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
Subscribed this woofer porn
WereWolf84 is online now
post #6 of 822 Old 10-18-2014, 06:56 PM
Samps's Avatar
Quoted: 1304 Post(s)
Liked: 977
The dust cap is bigger than the 10s.
Samps is offline
post #7 of 822 Old 10-18-2014, 07:01 PM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
The HS24 dust cap is actually equivalent to 12" woofer size of my mains
post #8 of 822 Old 10-18-2014, 08:40 PM
chrapladm's Avatar
Quoted: 1113 Post(s)
Liked: 451
YA finally another gorgeous cabinet design build. Sorry but I have to ask what is that dual 6.5 or other next to the triple ten?
I almost thought about buying a single 24" from Chop because of the price but just have too many things on my plate.
chrapladm is offline
post #9 of 822 Old 10-18-2014, 08:53 PM
dtsdig's Avatar
Quoted: 1135 Post(s)
Liked: 1400
Yeah! Can't wait to see what you come up with!
dtsdig is offline
post #10 of 822 Old 10-18-2014, 10:01 PM
chalugadp's Avatar
Quoted: 1685 Post(s)
Liked: 1574
Time to get a notepad out and go to woodworking School
chalugadp is offline
post #11 of 822 Old 10-18-2014, 10:19 PM
maxmercy's Avatar
Quoted: 69 Post(s)
Liked: 170
PI Build!
Sub'd.....it's been too long...
BTW, you may need new mains after this...
JSS
maxmercy is offline
post #12 of 822 Old 10-18-2014, 10:23 PM
mtg90's Avatar
Quoted: 853 Post(s)
Liked: 1694
Sub'd as well.
Klipsch KL-650-THX
mtg90 is online now
post #13 of 822 Old 10-18-2014, 11:40 PM
A-Rone's Avatar
Subscribed!!!! Your builds are always great fun to follow and I learn something too.
A-Rone is offline
post #14 of 822 Old 10-19-2014, 04:30 AM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
Originally Posted by mtg90 View Post
Klipsch KL-650-THX
You got it right, mtg90! Here is my Klipsch Klone build thread.
Originally Posted by maxmercy View Post
you may need new mains after this...JSS
There is definitely a SEOS build of some sort in my future.
Thanks for all the support, guys!
Black adder likes this.
post #15 of 822 Old 10-19-2014, 07:42 PM
maxmercy's Avatar
Quoted: 69 Post(s)
Liked: 170
Now you're talkin'! I have to say, I do enjoy reading your threads immensely. The detail, finishing techniques, like others have said, I learn something every time. What is your current topcoat? I know the target coatings stuff didn't pan out well, are you still using poly?
I really like my SEOS, you will like having that much more clean output on demand, esp after finishing these subs.
I tried my hand at 2-pack Poly for a snowboard I refinished, and while horribly life-threatening (unless proper PPE is worn), it is amazing stuff. The guy who recommended 2-pak said the flexibility and UV stability is second to none for that application, and he sells resins:
www.c3dindustries.com
I wonder if his H2O/UV Clear coat would be any good for speakers? I plan to use Resin-X for some vacuum bagging and surfboard projects in the future.
Anyone honest enough to say "my product won't work for your project, but try this", gets an 'A' in my book.
JSS
maxmercy is offline
post #16 of 822 Old 10-19-2014, 07:46 PM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
@PassingInterest
what box volume & finish you are planning to do?
post #17 of 822 Old 10-19-2014, 08:23 PM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
I intend to do a 15 cubic foot sealed build for these (x 2).
I haven't yet decided on the veneer. The finish will likely be a gloss water based gymnasium floor poly that I ordered recently and haven't tried yet. I'll give more details on it later.
Max--glad to see you're still around! Thank you very much for the kind words.
The Target Coatings product is fine if I either keep the same color on the entire enclosure or use a barrier coat to prevent color bleed between differently tinted areas. I still have some, but I haven't gotten around to using it again yet.
So far, my one attempt at a lacquer finish was disappointing. It flashed quickly, but takes months to fully harden, according to the info I read online--at least with the rattle can stuff I experimented with. I may try again someday, but while I was stripping it off, I swore I'd never use it again.
You are a great source for information, Max. I'll have to try some of the things you have recommended, though I may avoid the Death-Defying finishes until I get a full Bio-Hazard suit.
Which SEOS build did you do, Max? I need photos!
You refinished a Snowboard? I need photos of that, too!
Resin X is fast! I haven't tried it, but I think I will. Not sure when, yet.
post #18 of 822 Old 10-19-2014, 08:43 PM
WereWolf84's Avatar
Quoted: 418 Post(s)
Liked: 177
Sounds great! I'm also in the midst of converting my current 10 cubic feet into 15 cubic feet
post #19 of 822 Old 10-19-2014, 08:49 PM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
It will be interesting to learn how much difference the extra internal space makes in performance.
post #20 of 822 Old 10-19-2014, 08:54 PM
chalugadp's Avatar
Liked: 1574
Two 24", didn't know your a bass monster PI !
PassingInterest likes this.
post #21 of 822 Old 10-19-2014, 09:05 PM
Electrodynamic's Avatar
Quoted: 536 Post(s)
Liked: 808
Nice subwoofer.
Electrodynamic is offline
post #22 of 822 Old 10-19-2014, 11:43 PM
berstuck's Avatar
Quoted: 77 Post(s)
Liked: 54
Sub'd, this has win written all over it!
berstuck is offline
post #23 of 822 Old 10-20-2014, 04:46 AM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
Originally Posted by Electrodynamic View Post
Nice subwoofer.
We all have you to thank for creating such a Powerful and Magnificent Beast!
post #24 of 822 Old 10-20-2014, 04:47 AM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
post #25 of 822 Old 10-20-2014, 06:43 AM
flyng_fool's Avatar
Quoted: 190 Post(s)
Liked: 172
Wow! That thing is a monster. Can't wait to see what you're going to come up with!
Television: Vizio E70iA3
Processor: Emotiva MC700
Surrounds: AT 2200 LR Sub: Danley DTS-10Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #26 of 822 Old 10-20-2014, 01:08 PM
beastaudio's Avatar
Quoted: 5774 Post(s)
Liked: 5628
Certainly subbed here. Looking forward to the progress I finished my most recent build with Lacquer and got a pretty killer finish to it. Applied with foam brushes, sanded out to 12,000 grit, finish waxed Turned out pretty nice The lacquer did take a week of cure time before I began buffing out, but I feel like 5 days would have been long enough.
beastaudio is offline
post #27 of 822 Old 10-20-2014, 03:04 PM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
I know! I could almost feel the testosterone coursing through my veins after wrestling these Massive Beasts out of their shipping crates!
post #28 of 822 Old 10-20-2014, 03:06 PM - Thread Starter
Quoted: 195 Post(s)
Liked: 533
Speaking of Beasts--Thanks for the lacquer feedback, guy. I guess my trouble was limited to the rattle cans I used (sorry folks, but I don't remember the brand).
post #29 of 822 Old 10-20-2014, 03:19 PM
beastaudio's Avatar
Liked: 5628
No prob! My finishing skills are getting there, but I am straight JV compared to what you manage to come up with I used the watco gloss lacquer. Took around 8 coats or so, but once buffed out, I am happy with this effort. Check out my Undertaker build and let me know what you think! I would love the feedback
post #30 of 822 Old 10-20-2014, 07:20 PM
Liked: 2232
PI, I used a commercial lacquer called magna max by ML Campbell and had great success. I needed a convenient finish for something and found a rat can of deft lacquer on sale so picked it up for this simple task. Well, it was like driving a Ferrari and then renting a minivan. Was terrible by comparison. Thankfully it did the little task I needed done, but never for a speaker would I use a rat can after that.
