Using the Behringer MIC2200 as strictly an HPF AKA Subsonic Filter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-23-2014, 07:12 AM - Thread Starter
yadfgp's Avatar
Quoted: 131 Post(s)
Liked: 78
Hello
I started a thread over in the other Subs forum, and it's gotten no responses so far so I was hoping maybe someone over here might be able to help me out.
Just looking for some help on the MIC2200 and setting it up.
Thanks in advance.
https://www.avsforum.com/forum/113-su...ic-filter.html
yadfgp is offline
post #2 of 3 Old 10-23-2014, 02:35 PM
BrickTop's Avatar
Quoted: 48 Post(s)
Liked: 33
There is a thread here that has the settings as well as the measured output of the MIC2200 that is very useful...I will amend this post when I find it...I believe it is quite old.
I can tell you is variable from 12 Hz up and uses a 12db/octave slope...but you can daisy chain to the other channel to get it to 48 db/octave.
Here it is from NEO Dan https://www.avsforum.com/forum/155-di...l#post18079448
BrickTop is offline
post #3 of 3 Old 10-24-2014, 08:36 AM - Thread Starter
yadfgp's Avatar
Quoted: 131 Post(s)
Liked: 78
Wow!
Thanks BrickTop for taking the time to dig that up for me.
I'll check it out and see what happens.
I messed with the MIC2200 last night for a bit and got unexpected results. I didn't do much settings wise on the MIC2200, as I didn't think there'd be much to do. But it didn't work out quite like I had expected.
I had hoped for some more input on this topic, as I've seen quite a few recommendations over the years for the MIC2200. Kind of baffling to say the least.
yadfgp is offline
