Measuring Amplifiers - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 969Likes
post #1351 of 1783 Old 08-26-2017, 11:30 AM - Thread Starter
notnyt's Avatar
Quoted: 3816 Post(s)
Liked: 3771
ipr2-7500 idle draw 102w.
When plugged in, the amp always has blue light on (ew). When turning it on it gets brighter. Killawatt reported 0w in that state.
notnyt is offline
post #1352 of 1783 Old 08-26-2017, 01:14 PM
zeus33's Avatar
Quoted: 1827 Post(s)
Liked: 1877
Originally Posted by notnyt View Post
IPR2-7500 2 ohm numbers.......
Thanks not. I've been waiting for these numbers.
Nice touch with the post with all of the pics as well. Thanks again for doing all of this. Great info.
notnyt and biga6761 like this.
zeus33 is offline
post #1353 of 1783 Old 08-26-2017, 01:16 PM
MKtheater's Avatar
Quoted: 2522 Post(s)
Liked: 2617
Awesome!
MKtheater is offline
post #1354 of 1783 Old 08-26-2017, 08:24 PM - Thread Starter
notnyt's Avatar
Liked: 3771
added 4 and 8 ohm numbers for the ipr2-7500, as well as noise, frequency response, and distortion
MKtheater likes this.
notnyt is offline
post #1355 of 1783 Old 08-26-2017, 11:13 PM
N8DOGG's Avatar
Quoted: 1328 Post(s)
Liked: 1560
I wonder what improvements if any the crest 7.5 adds. Since it's supposed to be an improved design.
I used one on my JTR os pros for a while and it was great.
biga6761 likes this.
N8DOGG is offline
post #1356 of 1783 Old 08-26-2017, 11:40 PM - Thread Starter
notnyt's Avatar
Liked: 3771
I didn't see any difference between them on the pics I saw.
notnyt is offline
post #1357 of 1783 Old 08-27-2017, 05:57 AM
evoryder's Avatar
Quoted: 98 Post(s)
Liked: 109
This is all great information, thank you for taking the time to perform these tests! I noticed you said this amp is noisy as well. Is there any way you could include a fan noise level scale of 1-10 or db reading as well to include with your testing notes?
evoryder is offline
post #1358 of 1783 Old 08-27-2017, 08:40 AM
N8DOGG's Avatar
Liked: 1560
That's pretty interesting. The crest are supposed to have a better power supply. I know Danley uses them for a bunch of different purposes (or at least used to when they came out, since they touted the crap out of them on the prosound forum)
It would be funny if they were indeed identical.
Either way, I was happy with mine when I used it. Its in a box in my garage now waiting for future use.
N8DOGG is offline
post #1359 of 1783 Old 08-27-2017, 11:10 AM
zeus33's Avatar
Liked: 1877
When you say "better power supply," I assume you mean more capacitance. Yes, that has been mentioned multiple times and you can see it in the pics if you look closely. The caps in the Crest are taller.
zeus33 is offline
post #1360 of 1783 Old 08-27-2017, 11:12 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1795 Post(s)
Liked: 1713
My understanding too. It would not be cool if they were really the same due to price and the many comments stated regarding better power supply. Though at this point I don't remember where the "better power supply" came from.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #1361 of 1783 Old 08-27-2017, 12:26 PM - Thread Starter
notnyt's Avatar
Liked: 3771
I wrote that off to perspective, but yeah, you're right. Looking closer the 4 caps in the center are taller on the crest. That's an extra 7200uF (2200 vs 4000). While not a huge difference, it will provide a little more burst capabilities.
If anyone wanted to modify the peavey for that, should be trivial, but the pricing on the pl7.5 seems to be lower than the peavey when I check B&H. Also interesting is an unused spot for a capacitor. I'd toss one in there too for another 4000uf of capacitance.
https://www.bhphotovideo.com/bnh/con...EG&sku=1071535
$1049 for the pl7.5
notnyt is offline
post #1362 of 1783 Old 08-28-2017, 01:03 PM
chrisfam's Avatar
Lukeamdman did a 2 ohm test of the Crest 7.5 a couple of years back on data-bass forums and got lower ratings than your test on the Peavey. I believe it was around 1600 watts a channel, both channels driven into 2 ohms. That is a huge difference. Did he measure for a longer term or lower amount of distortion? Also would it be ok to run a couple of HT-18 v2 or UM-18's on this amplifier (one per channel). I got the Peavey from the group buy a while back but it's been sitting in my closet until my house is built.
chrisfam is offline
post #1363 of 1783 Old 08-28-2017, 01:17 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Do you have a link to those test results? The prolite 7.5 should outperform this amp.
notnyt is offline
post #1364 of 1783 Old 08-28-2017, 01:52 PM
chrisfam's Avatar
It was on the data-bass forum but looks like the numbers were taken down by photobucket. http://data-bass.ipbhost.com/topic/4...plifier-tests/
I believe he is on this forum also so maybe he will reply.
chrisfam is offline
post #1365 of 1783 Old 08-28-2017, 03:23 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
My guess is that the numbers are different because their test beds are different. Like a lot of tests, you can compare results done by the same person but not necessarily tests done by different people. This is one of the reasons Josh Ricci is so revered, one place where many subs are tested so you don't have to worry about inconsistent data. But you can't take a test done by Josh Ricci and compare it to one done by Audioholics although both are good testers with consistent methodologies.
David Gage
Deep Sea Sound
dgage is offline
post #1366 of 1783 Old 08-28-2017, 03:55 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
The height of a capacitor can be misleading, but one would assume bigger is better...
Depends on the number of plates, size of the plates, plate spacing, as well as rated voltage (or at least applied-voltage).
Those internals remind me of the Crown K's, looks can be deceiving though...
BassThatHz is offline
post #1367 of 1783 Old 08-28-2017, 04:11 PM - Thread Starter
notnyt's Avatar
Liked: 3771
The ipr2 use 2200uf, the 7.5 use 4000uf.
notnyt is offline
post #1368 of 1783 Old 08-28-2017, 04:26 PM
Quoted: 182 Post(s)
Liked: 159
Examine the caps to see who the manufacturer is. Maybe a part number or series is on the sleeve. Could be that not only are they larger in value, they may have a lower ESR and higher ripple current capability.
sam_adams is offline
post #1369 of 1783 Old 08-28-2017, 06:57 PM
lukeamdman's Avatar
Quoted: 1385 Post(s)
Liked: 2000
That early on in my testing I was using digital multi-meters to capture Vrms while driving my 21" subs as the load. Since the meters are a lot slower than scopes those numbers weren't burst/peak and more in the 1-2 second duration range.
lukeamdman is offline
post #1370 of 1783 Old 08-28-2017, 09:32 PM - Thread Starter
notnyt's Avatar
Liked: 3771
My sine wave numbers were still a bit higher.. *shrug* I'd do a quick test of a prolite but I don't there are too many around compared to the IPR2s. I bet they can burst a good deal better. If I used these I'd even try to add another cap on the empty spot
notnyt is offline
post #1371 of 1783 Old 12-01-2017, 12:28 PM - Thread Starter
notnyt's Avatar
Liked: 3771
I have the minidsp pwr-ice250 on the bench right now, which uses the 250asx2 module.
Performance is pretty solid. With one channel running, it will output and sustain 285w into 4 ohms at 1% THD+N. 250w at <0.1%THD+N. At lower levels, THD+N drops to below 0.02%. Distortion is primarily odd order and there's a decent bump in it at higher frequencies.
Performance is significantly better into an 8 ohm load. It will output 125w into 8 ohms at <0.02% THD+N up until about 1khz, where it rises to 0.07% at 5khz. Backing off a bit, THD+N drops to below 0.02%.
There's a bit of power supply noise evident in the spectrum.
LTD02, lukeamdman, Patzig and 2 others like this.
notnyt is offline
post #1372 of 1783 Old 12-01-2017, 12:47 PM
coolrda's Avatar
Quoted: 1391 Post(s)
Liked: 1506
Is this going in a project? Been interested in this.
coolrda is online now
post #1373 of 1783 Old 12-01-2017, 01:11 PM - Thread Starter
notnyt's Avatar
Liked: 3771
2265hpl + 2453h-sl + stx825 waveguide
LTD02 and Lynkage like this.
notnyt is offline
post #1374 of 1783 Old 12-01-2017, 04:02 PM
coolrda's Avatar
Liked: 1506
Very nice. Are you retrofitting your LCR’s or a complete new build?
post #1375 of 1783 Old 12-01-2017, 04:09 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Not for me. It's similar to my center (linked in sig). It's a build to replace a friends front stage that's using 3677s.
My L/R are using 2452h-sl with bex4008 diaphragms on 2384 horn over 4509 lf enclosure. Using by 6x hypex nc400s amps with rme ufx+ interface hooked up to a mini pc running brutefir for processing.
These are basically gonna be like my center with the pwr-ice250 instead.
LTD02 and biga6761 like this.
notnyt is offline
post #1376 of 1783 Old 12-02-2017, 09:24 AM
stegen's Avatar
Quoted: 183 Post(s)
Liked: 118
Id love to give you my Emotiva XPR-2 for testing but shes a tank. I've always wondered if running my Yorks off it vs a crown 1500 really makes a difference. I tried it before and couldnt tell a difference.
stegen is offline
post #1377 of 1783 Old 12-02-2017, 10:37 AM - Thread Starter
notnyt's Avatar
Liked: 3771
If you want, will do once I get this audio analyzer situation sorted out. They just confirmed the issue I reported. Not sure how that gets missed. Once the inputs see 6v a bunch of distortion pops up. Annoying.
Marc Alexander and biga6761 like this.
notnyt is offline
post #1378 of 1783 Old 12-02-2017, 10:48 AM
stegen's Avatar
Quoted: 183 Post(s)
Liked: 118
I appreciate the offer but I'm not that curious to ship that monster.
stegen is offline
post #1379 of 1783 Old 12-04-2017, 07:09 AM
Jason kiDD's Avatar
Quoted: 56 Post(s)
Liked: 35
Fp measurements up next?!
Jason kiDD is offline
post #1380 of 1783 Old 12-04-2017, 09:16 AM
MKtheater's Avatar
Liked: 2617
Want to sell one of your amps?
