Measuring Amplifiers - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 969Likes
post #1381 of 1783 Old 12-04-2017, 11:41 AM
Jason kiDD's Avatar
Quoted: 56 Post(s)
Liked: 35
Want to sell one of your amps?
Sure its just sitting there in the box..
Jason kiDD is offline
post #1382 of 1783 Old 12-04-2017, 12:05 PM - Thread Starter
notnyt's Avatar
Quoted: 3816 Post(s)
Liked: 3771
Originally Posted by Jason kiDD View Post
Fp measurements up next?!
I measured the only thing anyone cares about from them, max power
I have a bt enhanced fp14k sitting here still. I can run some sweeps on it at some point.
biga6761 likes this.
notnyt is offline
post #1383 of 1783 Old 12-04-2017, 12:18 PM
Jason kiDD's Avatar
Quoted: 56 Post(s)
Liked: 35
Yeah it would still be cool to see max power over frequency bands, sustained, and also THD.. But its only been since March and I know your busy..
post #1384 of 1783 Old 12-04-2017, 12:25 PM - Thread Starter
notnyt's Avatar
Liked: 3771
I posted the info for the sanway fp14k earlier. The older ones sustain like 2800 or so, newer ones 3800. The BT enhanced will put out 4800 for a little under 2 seconds then about 3800.
4.4ohms bridged sanway fp14000
Hz Vpp burst Burst Watts
5 504 7214
10 584 9686
20 624 11058
30 632 11344
40 680 13132
80 728 15052
notnyt is offline
post #1385 of 1783 Old 12-04-2017, 12:33 PM
Jason kiDD's Avatar
Quoted: 56 Post(s)
Liked: 35
5 504 7214
10 584 9686
20 624 11058
30 632 11344
40 680 13132
80 728 15052
okay awesome thanks for all the hard work of course...
MKtheater, notnyt and biga6761 like this.
post #1386 of 1783 Old 12-05-2017, 01:36 PM
MKtheater's Avatar
Quoted: 2525 Post(s)
Liked: 2625
What are the 8 ohm numbers bridged?
Building the room, speakers, and subs.
MKtheater is online now
post #1387 of 1783 Old 12-05-2017, 02:38 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Didn't test, but since those numbers are primarily current limited, you're looking at at around 7-8kw.
notnyt is offline
post #1388 of 1783 Old 12-06-2017, 12:06 PM
Liked: 1
I'm patiently waiting your test on the Botai enhanced FP14000
dB_Max is offline
post #1389 of 1783 Old 12-06-2017, 12:12 PM
Liked: 1
Sorry the quote is a mistake..... don't know how that got in to the post
dB_Max is offline
post #1390 of 1783 Old 12-06-2017, 12:14 PM
Liked: 1
Sorry the quote in the previous post is a mistake.......don't know how that got in to the post
dB_Max is offline
post #1391 of 1783 Old 12-08-2017, 10:37 AM
murphy2112's Avatar
Quoted: 694 Post(s)
Liked: 387
5 504 7214
10 584 9686
20 624 11058
30 632 11344
40 680 13132
80 728 15052
Why do amps have such a hard time with lower frequencies? Does it have anything to do with DC?
murphy2112 is offline
post #1392 of 1783 Old 12-08-2017, 10:38 AM - Thread Starter
notnyt's Avatar
Liked: 3771
The signals are more demanding. Each cycle of 5hz is 200ms. Each cycle of 50hz is 20ms.
dgage, murphy2112 and biga6761 like this.
notnyt is offline
post #1393 of 1783 Old 12-16-2017, 11:40 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Not quite an amplifier, but figured it'd be worth testing.
So here's the cleanest interface I've seen yet, the MOTU 8a (which performs pretty much identically to the 1248 and the 16a). Tests looped into itself, and then into the RTX6001 analyzer.
0.000025% THD and 0.0002% THD+N
The best THD+N performance was at about 10v out. Best THD performance was just under 1v out.
MOTU 8a looped into itself
MOTU 8a into RTX6001
Going to test the RME UFX+ next, but I don't want to pull it out of my rack. Will have to move the test gear over to it, but that's another day.
LTD02 and Patzig like this.
notnyt is offline
post #1394 of 1783 Old 12-19-2017, 03:17 PM
desertdome's Avatar
Quoted: 1535 Post(s)
Liked: 1837
Here is my MOTU 624 looped:
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #1395 of 1783 Old 12-19-2017, 03:19 PM - Thread Starter
notnyt's Avatar
Liked: 3771
A bit of that distortion comes from the a/d. The a/d also has a bunch of hf noise. The 624 is in the same family as the 8a, both perform really well.
notnyt is offline
post #1396 of 1783 Old 02-01-2018, 07:04 PM - Thread Starter
notnyt's Avatar
Liked: 3771
new little guy on the bench. Connex IRS2200SMPS. Tiny little mains powered thing. Measured best of 0.0005% THD and 0.004% THD+N at 1khz into 8 ohms on the test bench so far. 0.01% THD+N at 1w into 8 ohms, 0.015% at 4 ohms.
Very efficient, very quiet. This will likely be my test amp for the bench, and will pick up another two for my surround//side channels.
Detailed measurements coming at some point.
1w into 8 ohms. It's no hypex, but it's not bad.
18Hurts and biga6761 like this.
notnyt is offline
post #1397 of 1783 Old 02-01-2018, 08:27 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
Does it come in a finished box? Or is it just the board?
Samps is offline
post #1398 of 1783 Old 02-01-2018, 10:29 PM
Augerhandle's Avatar
Quoted: 1253 Post(s)
Liked: 1256
http://connexelectronic.com/product/irs2200smps/
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #1399 of 1783 Old 02-02-2018, 02:25 AM - Thread Starter
notnyt's Avatar
Liked: 3771
Connex IRS2200SMPS
pros: cheap, high efficiency, small, decent power output, balanced
cons: slightly rising frequency response above 10khz at 8 ohms, bit of HF distortion when pushed.
frequency response...
Distortion 8 ohms...
Distortion 4 ohms...
IMD
current draw...
1khz square wave...
LTD02, kibe29, dwaleke and 2 others like this.
notnyt is offline
post #1400 of 1783 Old 02-03-2018, 11:39 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1795 Post(s)
Liked: 1713
I'd try to find someone to fix the IPR2-7500 for cheaper to start with. Which xxx18s do you have? What's the impedance?
Also where are you getting the ipr2-7500 for $700? That's a good deal.
I agree with Not on getting the IPR2-7500 foxes if you can ensure it would be fixed to like new.
Regarding amps FOR SUBS, I’m not at all impressed by the iNukes since they lack power down deep. The best subwoofer amps on the market are the SpeakerPower SP2-8000 (120V) or SP2-12000 (240V). However those are almost double the price of the IPR2-7500. So for most users for subs, I recommend the Peavey IPR2-7500 (DSP) or the slightly better sister amp in the Crest Prolite 7.5 (DSP). Those amps would give you about 80-90% of the capability of the SpeakerPower amps for about half the cost.
shpitz and biga6761 like this.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #1401 of 1783 Old 02-03-2018, 12:02 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Regarding amps FOR SUBS, I’m not at all impressed by the iNukes. The best subwoofer amps on the market are the SpeakerPower SP2-8000 (120V) or SP2-12000 (240V). However those are almost double the price of the IPR2-7500. So for most users for subs, I recommend the Peavey IPR2-7500 (DSP) or the slightly better sister amp in the Crest Prolite 7.5 (DSP). Those amps would give you about 80-90% of the capability of the SpeakerPower amps for about half the cost.
The PL7.5 / IPR2-7500 are definitely way better than the inukes, and are on my short list. They can run lower impedance loads and output double the power. Efficiency is much better as well. I don't know about that 80-90% of a speakerpower amp part... The IPR2-7500 run out of steam around 5kw... one channel of an sp2-12000 will outperform that... I think Luke measured like 8kw of output from one of those for sustained for a some seconds.
The speakerpower amps are definitely the way to go if you can put a low impedance load on them and have the budget. The PL7.5 is also a good choice. A clone will manage similar sustained output to the pl7.5, but it can do so with a higher impedance load and have another 3-4db of burst capability over it. Obviously there are drawbacks to the clone amps, but they're serious performers.
All that said, all the amps listed above aside from the speakerpower units are loud. I've yet to have the fans in my SP2-12000 even spin up. If you have the amps in their own room, not a problem.
My personal order of preference would be
1) SP2-12000 / SP2-8000 depending on electrical availability. the 8000 is more efficient by a few percent (~5) and can run on 120v, the 12000 requires 240 for full performance.
2) Smiths FP14000 clone
3) PL7.5 then IPR2-7500
If you were to group these in dollar to watts, it'd be ordered 2, 3, 1.
Honorable mention to the Powersoft K20 and K10, which are great as well, but they price themselves out of competition. They also sound like they're going to take off with all the 1U high rpm fans.
dgage, shpitz and biga6761 like this.
notnyt is offline
post #1402 of 1783 Old 02-03-2018, 12:23 PM
Deep Sea Sound
dgage's Avatar
Liked: 1713
Thanks Not. I was trying to be nice to the IPR2-7500 by saying 80-90% since I do use them in my products, I didn’t want to be too partial. So I’ll defer to your measurements although in some testing head to head in anecdotal real-world tests, the IPR2-7500 availed itself pretty well but gave up before the SP2-8000 running the same HS-24 sub. This was at Beast’s GtG several years ago. So overall, especially for the money, the IPR2-7500 is quite capable. I really don’t consider the clones due to UL issues in case of fire.
Marc Alexander and notnyt like this.
David Gage
Deep Sea Sound
dgage is offline
post #1403 of 1783 Old 02-03-2018, 12:26 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Depending on the load, the IPR2-7500 may end up closer to the SP2-8000. Examples given earlier were with optimized loads on them. If you're using 3-4 ohm loads, it's much closer.
notnyt is offline
post #1404 of 1783 Old 02-03-2018, 12:38 PM
FriscoDTM's Avatar
Quoted: 432 Post(s)
Liked: 391
I was looking at the Connex CxD 500 boards to try on my Crowsons a while back, but I thought they might be a bit skimpy on power and might have issues at very low frequencies. Thanks for sharing the test. I still have an empty amp chassis that I never populated, and perhaps now is a time to revisit my amp projects. Why did you pick that integrated one over the other boards like the CxD?
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #1405 of 1783 Old 02-03-2018, 12:55 PM - Thread Starter
notnyt's Avatar
Liked: 3771
size and efficiency. It definitely hit the rated power numbers. I'd trust his stats for that at least.
notnyt is offline
post #1406 of 1783 Old 02-04-2018, 12:34 PM
bear123's Avatar
Quoted: 2655 Post(s)
Liked: 4151
Has anyone fan modded the Peavey IPR2 7500 or Crest pro-lite 7.5? Any issues?
Also, does anyone have one of these on a smart strip for auto on/off? Wondering if there is the power on/off thump like the I nuke 6k’s have.
bear123 is online now
post #1407 of 1783 Old 02-04-2018, 12:58 PM
MKtheater's Avatar
Liked: 2625
Thanks for the input guys. Unfortunately the peavy needs a $400 part. I can get a new one for $700 or a clone for the same, old clone used or new clone for whatever they go for. I have two 4 ohm subs but could wire them differently
post #1408 of 1783 Old 02-04-2018, 03:24 PM - Thread Starter
notnyt's Avatar
Liked: 3771
Also, does anyone have one of these on a smart strip for auto on/off? Wondering if there is the power on/off thump like the I nuke 6k?s have.
would not recommend fan modding unless you add a temperature based fan speed controller. There's not too much for cooling inside.
what part out of curiosity?
notnyt is offline
post #1409 of 1783 Old 02-04-2018, 07:56 PM
Moderator
rboster's Avatar
Quoted: 1628 Post(s)
Liked: 2235
We've had some complaints of offers to buy, sell or services outside of the classified forum, which is against AVS rules set out by the owners .
rboster is online now
post #1410 of 1783 Old 02-04-2018, 10:22 PM
MKtheater's Avatar
Liked: 2625
I think it was for a couple things. I will have to ask. I know the amp was toast. Power supply, boards or something like that.
