Measuring Amplifiers - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 936Likes
post #1441 of 1707 Old 07-10-2018, 05:48 PM - Thread Starter
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
I just put the NU3000DSP on the bench again.
It looks like the efficiency numbers I previously reported were incorrect. Apparently my amp probe was giving faulty results. I've replaced it once it became obvious, but apparently those faulty numbers slipped through.
NU3000DSP Summary: about 75% efficiency into 2ohms/4ohms bridged, 85% into 4ohms/8 ohms bridged, and 90% efficiency into 8 ohms. 1600w max output power.
I just ran these at 120hz up to clipping... The high power runs go into protect after a few seconds, so you can pretty much consider this max power available from the amp.
2ch into 2.3 ohm 713w x2 (1426w) it's consuming 1930 watts of power. 74% efficiency. The NU3000DSP can only sustain this briefly before going into protect.
2ch into 4.6 ohms, 394w x 2 (789w) it's consuming 946w, about 83% efficiency.
2ch into 9 ohms, 256w x 2 (512w) it's consuming 566w, about 90% efficiency.
bridged into 4.6 ohms, 1556w it's consuming 2050w, about 76% efficiency.
bridged into 9 ohms, 984w, it's consuming 1150w, about 86% efficiency.
So there's about a 2-3% efficiency gain in bridged mode.
DigiWega and biga6761 like this.
notnyt is offline
post #1442 of 1707 Old 07-10-2018, 06:01 PM
corradizo's Avatar
Quoted: 1527 Post(s)
Liked: 1583
Are these numbers consistent with the 6k numbers?
This is great info, thanks!
corradizo is offline
post #1443 of 1707 Old 07-11-2018, 04:43 PM
BassThatHz's Avatar
Quoted: 3682 Post(s)
Liked: 4180
Were fp's calculated with the faulty values? Perhaps for Sanway's but not Smith's?
johnson636 likes this.
BassThatHz is offline
post #1444 of 1707 Old 07-11-2018, 06:00 PM - Thread Starter
notnyt's Avatar
Liked: 3705
not sure, but I don't think the values were faulty. The older sanway amps didnt produce as much power. The newer PSes were better.
notnyt is offline
post #1445 of 1707 Old 07-12-2018, 12:10 PM
BassThatHz's Avatar
Liked: 4180
and by not much power, we mean: more than any Behringer or Crown ever made, or almost anything else niether.
post #1446 of 1707 Old 07-12-2018, 12:26 PM - Thread Starter
notnyt's Avatar
Liked: 3705
They only sustained 2800 watts or so, so that statement is not correct.
notnyt is offline
post #1447 of 1707 Old 07-12-2018, 01:17 PM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
I'm sure I'm being dense but what's the link to the amplifier test results? Also is the smith's fp14k 2 ohm stable?
Vince_B is offline
post #1448 of 1707 Old 07-12-2018, 02:23 PM
johnson636's Avatar
Quoted: 1152 Post(s)
Liked: 679
1. Which Amp?
2. Yes
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #1449 of 1707 Old 07-17-2018, 03:51 PM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
What about the fp14000q? Would you run an hs24 off two channels and a couple of side subs off the other two? Or possibly four smaller sealed subs. Guessing it makes comparable total power to the 14000 but divided by four channels. That would put it sustained power a touch under 1000 wpc?
Vince_B is offline
post #1450 of 1707 Old 07-18-2018, 05:46 AM
johnson636's Avatar
Liked: 679
Do you mean FP20000Q? If so, Then yes you can run an 2 HS24 on it's own channel...That's what I do
post #1451 of 1707 Old 07-18-2018, 05:48 AM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
I was looking at smiths and they have a 14q that looks like the enhanced 14k but is four channels. I want to fan mod it and the 20q sounds like a lot of heat in a small box and maybe not the best fan mod candidate. Did you fan mod yours?
Vince_B is offline
post #1452 of 1707 Old 07-18-2018, 06:09 AM
johnson636's Avatar
Liked: 679
Do you have a link to this fp14Q four channel amp. All I see on there website is 10Q, 18Q, and 20Q 4 channel amps.
http://www.imsmiths.com/page45?_l=en&product_id=105
post #1453 of 1707 Old 07-18-2018, 06:30 AM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
It's on their aliexpress page
Vince_B is offline
post #1454 of 1707 Old 07-18-2018, 06:49 AM
johnson636's Avatar
Liked: 679
I'd get their fp20Q if I were you.
post #1455 of 1707 Old 07-18-2018, 07:20 AM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
Do you have one? Would you fan mod it? In the 20q thread it was stated how hot the xbs one gets. And maybe the smiths is more efficient but enough to make that much heat difference?
Vince_B is offline
post #1456 of 1707 Old 07-18-2018, 07:31 AM
tential's Avatar
Quoted: 413 Post(s)
Liked: 276
I thought it was that it wasn't recommended to do hardcore dubstep for hours on it that it would get hot.
tential is offline
post #1457 of 1707 Old 07-18-2018, 07:54 AM
johnson636's Avatar
Liked: 679
Yes I do, but it's an XBS. I've not noticed my fp20Q becoming abnormally hot to the touch after watching a movie or a couple of hours of music session. I'd imagine if I pumped a 20hz sine wave at 0 MV for an hour, my fp20q probably would not like that.
post #1458 of 1707 Old 07-18-2018, 07:58 AM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
Got it thanks. What kind of circuit are you connected to?
I thought there were comments that the 14k delivered about the same overall output as the xbs 20k but I may have that wrong. The price is definitely tempting.
Vince_B is offline
post #1459 of 1707 Old 07-18-2018, 08:14 AM
johnson636's Avatar
Liked: 679
30a 240v circuit. The fp20k hasn't been officially tested with all channels driven, so no one really knows what it can do. All I know is I love mine
post #1460 of 1707 Old 08-09-2018, 05:05 PM - Thread Starter
notnyt's Avatar
Liked: 3705
XBS FP22000Q
Short version:
This amp is serious business.
It can output 4kw per channel into 4 ohms. Overall power output is limited to 8kw. This is a lot of power, likely too much for any circuit this amp will ever be on. It will easily trip a 30a breaker if pushed to these levels.
It can burst to about 12.5kw at 20hz, 14kw at 40hz, and 17kw at 80hz and up.
Best THD+N at 8 ohms is about 0.04%, at 4 ohms is 0.08%, and at 2 ohms is 0.18%
Efficiency is excellent, mid 90s into 4.5 ohms.
It is not 2 ohm stable. In fact, an amplifier board let out the magic smoke during sustained high power tests into 4 ohms. The signal in the image below was captured moments before it let go. XBS sent a replacement board. Replacement was trivial and took about 10 minutes. I doubt this is a load the amplifier will ever see in actual use unless playing electronic music at very high levels. That said, the thermal protection was inadequate and did not react quickly enough. There should likely be some intelligent limiting circuitry to prevent this, or components used that can handle the power, but it appears the protection is lacking. This is interesting, since there is some protection for high output at high frequencies. When trying to perform output tests at 10khz and above the amp would go into protect within a second.
Also of note, the heat sinks are not actually copper, but anodized aluminum.
Tests were performed with a 120v unit on a 30a circuit.
This is pushing close to max power at 40hz on a single channel into about 4.6 ohms (voltage scale multiplier is 10x too high and amperage is 10x too low). Output is magenta, power input is purple, voltage input yellow, amperage input blue.
1 channel driven into 4.5 ohms
2 channels driven into 4.5 ohms using separate ps
1 channel bridged into 9 ohms
2 channels bridged into 9 ohms. This gives you a good idea of the maximum output capabilities of the amp.
LTD02, dsl1, BassThatHz and 13 others like this.
notnyt is offline
post #1461 of 1707 Old 08-09-2018, 07:30 PM
WereWolf84's Avatar
Quoted: 402 Post(s)
Liked: 170
Spoiler!
is the fan noise as loud as FP14K clone? is it run as hot as FP14K clone?
would you switch from SP12K to this one? or if you haven't own the SP12K, which one will you choose between SP12K and XBS FP22000Q?
WereWolf84 is offline
post #1462 of 1707 Old 08-09-2018, 07:44 PM - Thread Starter
notnyt's Avatar
Liked: 3705
You know you don't have to quote the whole message right?
Yes, fan noise is like the FP14K. 62dbspl a weighted 6" away from the front or back.
No, I wouldn't switch from an SP12K. One of the modules in there can sustain the power of this amp, though at lower voltage but higher current levels.
This amp also lacks decent protection, the SP12K does not.
This is probably the most power for dollar you're going to get, however they have drawbacks as listed.
notnyt is offline
post #1463 of 1707 Old 08-09-2018, 07:48 PM
j.d.'s Avatar
Quoted: 58 Post(s)
Liked: 27
great work Not , everyone is thankful for your contributions here.
MKtheater, notnyt and biga6761 like this.
j.d. is offline
post #1464 of 1707 Old 08-09-2018, 07:51 PM
johnson636's Avatar
Liked: 679
Fans get loud as hell when pushed. I've never owned an FP14k so I can't speak to the comparison. I would say it gets any hotter than any other amp I've had.
Remember, you can get 3 of these amps and they may still be cheaper or around the same price as one SP12K
WereWolf84 and biga6761 like this.
post #1465 of 1707 Old 08-09-2018, 10:53 PM
Liked: 4
Oops.
That's some serious beef in the output stage! Kind of surprised they used metal cased transistors because of the cost and assembly hassle. But if you look at the spec sheet, they can take more thermal abuse than the plastic cases. OBTW, those are recent production, date codes show late February '18.
If this is the standard "Class TD" topology, that's one of the tracking rail switches that blew up. I can't tell from your pic if something else took it out, or if it just couldn't handle the load.
On my Sanway DP10Q, those transistors have had the markings obliterated. Looks like XBS does the same. So no telling what that part is, beyond a power MOSFET.
SVChucko is offline
post #1466 of 1707 Old 08-09-2018, 11:09 PM - Thread Starter
notnyt's Avatar
Liked: 3705
Originally Posted by SVChucko View Post
Oops.
The markings are all there, the blown part is IXTK82N25P
notnyt is offline
post #1467 of 1707 Old 08-10-2018, 12:46 AM
SpinMonster's Avatar
Quoted: 487 Post(s)
Liked: 300
What is meant by "one channel bridged into 9 ohms"
Did you mean two channels bridged into one 9 ohm load?
SpinMonster is offline
post #1468 of 1707 Old 08-10-2018, 01:14 AM - Thread Starter
notnyt's Avatar
Liked: 3705
yes, it's technically two channels bridged, which is kind of self explanatory with the bridged part, but I was indicated one channel of output. The two channel bridged is with all 4 amplifier modules working.
SpinMonster likes this.
notnyt is offline
post #1469 of 1707 Old 08-10-2018, 07:49 AM
MKtheater's Avatar
Quoted: 2377 Post(s)
Liked: 2340
So what could one expect with 4 channels driven into 4ohms? One driver per channel?
You said it could produce 4k per channel but limited to 8k which means 2k per channel all channels driven?
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
post #1470 of 1707 Old 08-10-2018, 08:00 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
With great power come great responsibility..
I would love to see what a stable version would look like under more demanding loads. I guess only time will tell as the product matures..
Jason kiDD is offline
