So much work.... and it doesn't work! :( - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #91 of 240 Old 12-05-2014, 10:12 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Originally Posted by lemonslush View Post
Has anyone suggested hooking up a device such as an ipod or cd player to the amp directly? That should insure your giving the amp full voltage compared to what the AV would send it.
I used a 3.5mm jack to rca, than used RCA to XLR converter plug and it should tell if if its the signal making it soft or not. Or at least let you know if its a weak signal out from the AV.
If it works but its still quiet at full gain then the subs wired incorrectly.
You can check to see if its in correct phase by hooking a 12volt battery up to the +/- to the +/- of the sub wires. I would take the speakon connector end that goes into your amp off and hook the wires up to that. If the sub pops OUT then its wired correctly, if it pops IN then its out of phase and need to be required. I would say use a fresher 12volt as the 18" subs wont move a bunch with a almost dead battery. It wont damage the subs. I use this method for trouble shooting and saves you the 30 or so minutes prying the sub out of the box to check the wires.
But that wont tell us if you have it wired for 8 or 2 ohms amusing its a dvc4
Already did the battery test (with a AA) and it popped out.
dman918 is offline
post #92 of 240 Old 12-05-2014, 10:18 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Originally Posted by dtsdig View Post
That may work, but my suggestion at this point is to get away from the adapters and go for one single cable like what I linked to. I know for a fact that this specific one is configured correctly for an iNuke input:
http://www.guitarcenter.com/Live-Wir...38-i1172393.gc
OK, I could give this a shot as well. I was trying to use the RCA cable as it is brand new and a nice quality cable. Plus the adapter is a whopping $2 shipped.
dman918 is offline
post #93 of 240 Old 12-05-2014, 10:34 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 108
I'm going to echo what has been said once before....it most likely is the cabling between your AVR and amp. It is incredibly rare that a piece of electrical equipment is DOA. However, bad cables or incorrectly wired cables are much more common. Trust me...this is a battle I've had for a decade in the industrial world. The first thing is to always blame the equipment...then blame the operator...then after two weeks actually look at the wiring and fix one bad connection.
dtsdig and chalugadp like this.
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #94 of 240 Old 12-05-2014, 11:46 AM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
To me it sounds like your receiver doesn't output enough voltage on the LFE output. The iNUKE only needs 0.75v which is not a lot compared to other pro amps but your receiver may not go that high. You can measure the output of the receiver using a 60hz sine wave and multimeter.
Originally Posted by dman918 View Post
-15.
When I had my old sub, the bass was pretty loud at that level. Here, you barely can hear it. The sub barely moves as well.
Consumer gear works on a much lower voltage level. You need more voltage for a pro amp. You can buy a converter that will "bump" up the voltage of the rca output and convert to a XLR. Someone else mentioned that you should try raising the LFE trim to +15. Have you tried that? Raising the trim will output more voltage but going too high may cause clipping.
Mrkazador is online now
post #95 of 240 Old 12-05-2014, 12:58 PM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
I haven't raised the LFE trim yet. I am going to try a new adapter first (gonna pick up the adapter or cable today after work). If that doesn't change anything, I'll jack the LFE up.
dman918 is offline
post #96 of 240 Old 12-05-2014, 04:46 PM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
There has been so many of this type of post, it seems it almost always comes back to a cable/connector/adapter issue between the AVR and the amp. If the XLR adapter or RCA to XLR or whatever isn't wired properly for this specific application, people end up with low/no signal/noise issues. When I was going from my Onkyo AVR to my NU4-6000 (or the previous EP2500 for that matter), the cable linked below was configured correctly. I had to change things up when I added a MiniDSP into the mix, but I did use this cable for several months before that.
The page linked below has some excellent information regarding balanced/unbalanced cables and applications. I have used the diagrams from it on several occasions to help folks on here struggling with the same types of low signal issues. It's worth the read!
http://forum.blu-ray.com/showthread.php?t=214470
They didn't have the full cable in stock so I bought a RCA - 1/4" adapter: http://www.guitarcenter.com/Live-Wir...91-i1166773.gc. It didn't make any difference.
So I maxed my LFE on my AVR to +12. Went into my AVR's built in test tone with it set to this (which means the tone plays at reference) and the amp showed one power bar. I guess that's progress, but I am not what to make of it and further, what to do about it.
Thoughts with this new info? Do you think the above OOS cable could make a difference? Do I need a voltage booster? Bad amp? Please help!!!
dman918 is offline
post #97 of 240 Old 12-05-2014, 05:28 PM
Pain Infliction's Avatar
Quoted: 980 Post(s)
Liked: 514
I bought four of those cables and use all of them on every channel of both of my inuke 3000dsp's. THey have worked perfectly for me and I have never had an issue with them. Cable directly from my avr to the amp without anything in between.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #98 of 240 Old 12-05-2014, 05:32 PM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
But do you think it will make a difference from the two options I've now tried?
dman918 is offline
post #99 of 240 Old 12-05-2014, 05:55 PM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
Do you have a multimeter to check the voltage?
Guitar center probably carries a rca/xlr voltage converter. Buy it and try it out. If it doesn't work you probably could return it.
post #100 of 240 Old 12-05-2014, 06:05 PM
Quoted: 980 Post(s)
Liked: 514
Probably not, but you never know. You could have a connection that is not that great between your cables and adapters. That is why it is best to use less in the chain. Come to think about it, I am using two different Y splitters to run all four of my connections off of one sub out on my avr because the first sub out goes to another sub by itself. I still have not had any issues. that means whatever voltage out of my avr is getting split four times and the inuke takes it no problem. So I do think that your avr is probably good on outputting enough voltage. This is real strange that people are having issues with this lately.
post #101 of 240 Old 12-05-2014, 06:35 PM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Any links to the converter I may need?
dman918 is offline
post #102 of 240 Old 12-05-2014, 07:08 PM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
Samson S-Convert is what you need and it looks like guitar doesn't carry it. Another converter is the Behringer MIC2200, I don't know of any others. Call your local pro shops and see if they carry the Samson converter.
post #103 of 240 Old 12-06-2014, 08:16 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
OK, well I am have a replacement amp on the way. I think I am going to test first with that before buying any converters or such. Seems weird because it seems like I'm one of the only people on here to have this problem. I don't see a lot of talk about ever needing a converter, just raising LFE trims to compensate.
Also, anyone else have any thoughts about trying this cable? http://www.guitarcenter.com/Live-Wir...=1py4h77k41enr
Keep in mind that I already tried http://www.amazon.com/Hosa-Technolog...ywords=rca+xlr and http://www.guitarcenter.com/Live-Wir...91-i1166773.gc and I had the exact same resulting ouput from each.
I did also test with my phone. Same output results.
dman918 is offline
post #104 of 240 Old 12-06-2014, 09:32 AM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
Most receivers shouldn't have a problem with pro amps but there are a few that need the converter. What is the model # of your receiver?
post #105 of 240 Old 12-06-2014, 09:36 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Pioneer VSX-1120
http://www.pioneerelectronics.com/PU...ers/VSX-1120-K
I had the problem connecting my phone directly to the amp as well.
dman918 is offline
post #106 of 240 Old 12-06-2014, 09:43 AM
Mrkazador's Avatar
Quoted: 308 Post(s)
Liked: 428
I don't think a phone can put out 0.75v but I could be wrong...
post #107 of 240 Old 12-06-2014, 09:46 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Oh ok, just checking.
Any thoughts on the adapters not being sufficient and first trying the cable I have linked from guitar center? I know it couldn't hurt trying but if it realistically shouldn't make a difference, I don't want to go through the hassle.
dman918 is offline
post #108 of 240 Old 12-06-2014, 09:52 AM
LastButNotLeast's Avatar
Quoted: 2347 Post(s)
Liked: 1977
The only other thing I would try would be to rewire the cable to 1+ and 1- (at both ends ) and run the amp in mono mode, just in case something's messed up with biamp mode.
Michael
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #109 of 240 Old 12-06-2014, 09:54 AM
Quoted: 980 Post(s)
Liked: 514
I know for fact that cable from guitar center works.
post #110 of 240 Old 12-06-2014, 09:55 AM
Quoted: 980 Post(s)
Liked: 514
Michael
Sounds like he is getting issues on the input side of the amp.
post #111 of 240 Old 12-06-2014, 10:08 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
Yes, I can pretty much 100% narrow it down to:
1. Need the cable Pain Infliction is recommending as there is something weird with my monoprice RCA and adapter(s) - not sure if it would be this as I did try two adapters with same result.
2. Bad amplifier - new one on the way so we will see
3. Not enough juice coming from my sub out - which makes me like one of a hundred who actually have an issue. LOL!
I don't think I am missing anything else? Everyone has looked at my screenshots and the amp is setup correctly, right?
dman918 is offline
post #112 of 240 Old 12-06-2014, 10:12 AM
datranz's Avatar
Quoted: 63 Post(s)
Liked: 48
I'm using a 1522 with an inuke 6000dsp, no problems, and a older vsx23 with an inuke 3000dsp, no problems either.
datranz is offline
post #113 of 240 Old 12-06-2014, 10:13 AM
Quoted: 980 Post(s)
Liked: 514
Do you have another avr by any chance? Also, remind me of your sub settings in the avr. What the trim is and if the sub on.
post #114 of 240 Old 12-06-2014, 10:15 AM
datranz's Avatar
Quoted: 63 Post(s)
Liked: 48
Monoprice cable did give me a hum, so I switch to some amazon cable, I don't remember the name anymore.
datranz is offline
post #115 of 240 Old 12-06-2014, 10:16 AM
datranz's Avatar
Quoted: 63 Post(s)
Liked: 48
I also have a denon 4310 that I use with a minidsp and crown k2. No issue there.
datranz is offline
post #116 of 240 Old 12-06-2014, 10:18 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
I don't have another AVR to test. Sub settings were at default, which was 0 for LFE and 10' for distance. I maxed the LFE to +12 and still only get one power bar with the inuke maxed. Speakers set to small and sub to yes.
dman918 is offline
post #117 of 240 Old 12-06-2014, 10:19 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
No hum here. Just no output.
dman918 is offline
post #118 of 240 Old 12-06-2014, 10:29 AM
Quoted: 980 Post(s)
Liked: 514
When you said that you got one power bar, is that on the front of the amp or in the software?
In the software, look at the configuration page and on the right side you should see input and output bars light up. What do you see?
post #119 of 240 Old 12-06-2014, 10:46 AM - Thread Starter
dman918's Avatar
Quoted: 393 Post(s)
Liked: 122
One power light on front of amp lights up. Input and output in software shows around -30db.
dman918 is offline
post #120 of 240 Old 12-06-2014, 11:16 AM
Quoted: 980 Post(s)
Liked: 514
Yea that is low and confirms that it is an input issue. I have my sub out split four times and this is what I get on my amps. This is with the Hulk blu ray
Talking
Medium to heavy bass scene
Heavy bass scene with serious ULF. 5hz content
Sorry about the pics. I do not know how to post them on here anymore.
ID:	405562   Click image for larger version
ID:	405578   Click image for larger version
