Can someone please help me build a 8" subwoofer? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By doc5150
post #1 of 7 Old 12-03-2014, 08:18 PM - Thread Starter
likemovies's Avatar
Quoted: 28 Post(s)
Hi, I've read lots, but I'm getting stumped on WinISD. Whenver I model something like this, I get ridiculous low Hz numbers and it cannot be right. Was hoping for some help. With this one, I can't even find the sd value for WinISD. Using these directions.
Do I just build a
  • Vented Volume1.275 ft.³
enclosure?
and something like this? Can it really get to 24Hz? Granted it won't be mind blowing, but I wanted something small to learn on.
http://www.parts-express.com/dayton-...ifier--300-802
Sorry to dump all this information, but I wasn't sure what to do. Thanks for any help.
http://www.parts-express.com/re-audi...-ohm--268-8050
  • Nominal Diameter8"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance4 ohms
  • Frequency Response24 to 500 Hz
  • Sensitivity82.63 dB 1W/1m
Thiele-Small Parameters
  • Resonant Frequency (Fs)24.5 Hz
  • DC Resistance (Re)3.74 ohms
  • Mechanical Q (Qms)8.36
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.42
  • Compliance Equivalent Volume (Vas)0.84 ft.³
  • BL Product (BL)11.95 Tm
  • Maximum Linear Excursion (Xmax)13 mm
Materials of Construction
  • Cone MaterialPoly
  • Surround MaterialSantoprene®
  • Voice Coil Wire MaterialCopper
  • Basket / Frame MaterialSteel
  • Magnet MaterialFerrite
Mounting Information
  • Overall Outside Diameter8.70"
  • Baffle Cutout Diameter7.30"
  • Depth4.5"
  • # Mounting Holes8
Optimum Cabinet Size (determined using BassBox 6 Pro High Fidelity suggestion)
  • Sealed Volume0.59 ft.³
Samsung 51" PN51E450A, Pioneer VSX-918V, Polk Tsi300, Polk CS 2 series ii center, Energy S10.3.
likemovies is offline
post #2 of 7 Old 12-03-2014, 09:58 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
http://www.diysoundgroup.com/anarchy...r/anarchy.html
http://www.diysoundgroup.com/ported-...narchy-th.html
you can use that plate amp with this...they say its a great sounding sub for the price
GreySkies and pgwalsh like this.
doc5150 is offline
post #3 of 7 Old 12-03-2014, 10:07 PM
Samps's Avatar
Quoted: 1235 Post(s)
Liked: 908
It can easily reach 24hz, but at what spl? 24hz is more feel than hear. And when we go after feel you need more than that 8 can provide. You're better off with more spl at 30hz which you can actually use. Once you get winisd sorted out you can experiment with different port tuning to find the sweet spot for that driver+that amp+the box size you're comfortable with. I'm betting closer to 28hz but I didn't model it. I hate entering ts specs. Sorry.
You'll probably walk out of here with an 18.
Samps is offline
post #4 of 7 Old 12-04-2014, 05:49 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2729
Lol I came in here to to post this.
Mfusick is offline
post #5 of 7 Old 12-04-2014, 06:46 AM
Bill Fitzmaurice's Avatar
Liked: 5778
Sure it can, but this is the trade off: Sensitivity 82.63 dB 1W/1m
Bill Fitzmaurice is offline
post #6 of 7 Old 12-04-2014, 07:02 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 226
You would also have to figure out the best way to fit something like a 3" x 23.6" port inside a 1.275 ft3 box. That also means accounting for the port volume which will make your box slightly bigger. Say a box that's 14"x15"x16" out of 3/4" material. Get a 3" pvc pipe and use a 3" pvc elbow fitting like this to make the port fit
http://www.lowes.com/pd_23354-1814-P...ductId=3132777
Jay1 is offline
post #7 of 7 Old 12-04-2014, 07:23 PM - Thread Starter
likemovies's Avatar
Quoted: 28 Post(s)
Is SPL what you can "feel"? Is that measured in db?
Can you tell me what you mean?
