Fusion 10 Max Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #121 of 246 Old 01-15-2015, 09:46 AM
Erich H's Avatar
Quoted: 1856 Post(s)
Liked: 2659
If you get an accurate frequency response, can I use post it on the Max page? I was also going to put a link to this thread because you really did a good job on explaining the build.
jbrown15 and wvu80 like this.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #122 of 246 Old 01-15-2015, 09:55 AM - Thread Starter
coolrda's Avatar
Quoted: 1388 Post(s)
Liked: 1503
Absolutely.
coolrda is online now
post #123 of 246 Old 01-16-2015, 11:42 AM
pbc
pbc's Avatar
Quoted: 437 Post(s)
Liked: 217
Didn't Tux have full measurements of the speaker in teh original thread? Or are you also adding some "user in-room" sort of measurements to the site?
My DIY Subs ... https://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #124 of 246 Old 01-16-2015, 02:45 PM
tuxedocivic's Avatar
Quoted: 2300 Post(s)
Liked: 2225
Originally Posted by aaronlinkous View Post
Intersting... I've always just rested my mic on the top of the headrest.... anything in particular I should put over the couch to help or a new place to put the mic?
Like cool said, just leave it. Or put it near where your ear would be using a boom stand. Your ear is shaped so you don't hear that dip in the response. And your brain is very good at hearing the difference between the direct response and the reflected response. Which is why I prefer to use room measurements only to look at 1. Comparisons, 2. Low frequencies. Also why I don't like how a lot of room correction software works. I audessey corrects for that null, you'll actually hear a peak. Thankfully, they'll gotten a lot better and don't hammer the response around too much.
My long way of saying, just ignore stuff like that. Focus on <500hz with a seat measurement.
tuxedocivic is offline
post #125 of 246 Old 01-18-2015, 11:36 PM - Thread Starter
coolrda's Avatar
Liked: 1503
He did post a graph in the Tux and Erich's new creation thread.
post #126 of 246 Old 01-19-2015, 12:04 AM - Thread Starter
coolrda's Avatar
Liked: 1503
I took a quick measurement and tried to line up the mic as best I could. The XD screen is pretty transparent. This graph matches Tux's including the bump above 10khz.
post #127 of 246 Old 01-19-2015, 09:43 AM
Liked: 2225
Now there's no question it's working as intended.
FYI, the measurements of other tech details are kept here: http://www.diysoundgroup.com/forum/i...sg3920#msg3920
Stole a photo cool
post #128 of 246 Old 01-19-2015, 02:18 PM
Rcris's Avatar
Quoted: 88 Post(s)
Liked: 104
I'm making cab's for Fusion 10 pure version, how long should I leave the clamps ON while making the cab
Rcris is online now
post #129 of 246 Old 01-19-2015, 04:19 PM
wormraper's Avatar
Quoted: 379 Post(s)
Liked: 234
what adhesive are you using? if it's just titebond wood glue, 45 minutes to an hour is fine. if it's something like poly construction adhesive than I'd wait 12 hours
wormraper is offline
post #130 of 246 Old 02-11-2015, 01:22 PM
DevonDeyholos's Avatar
Quoted: 224 Post(s)
Liked: 231
Does the flat pack dimensions take into account this kind of bracing and the volume it takes up? Basically, should I make the box a little bit deeper if I want to heavily brace it like coolrda did?
DevonDeyholos is offline
post #131 of 246 Old 02-11-2015, 07:47 PM - Thread Starter
coolrda's Avatar
Liked: 1503
The area of my 4x 11"x11"x.75" bracing with 4x4" holes in each, subtracted, equals about 4x54cu in or 216 cu in total or one eighth of a cubic foot. That equates to less than 3/4" in depth added in comparison to no bracing at all. The difference is negligible so I wouldn't sweat that too much.
post #132 of 246 Old 02-12-2015, 08:22 AM
Quoted: 224 Post(s)
Liked: 231
Ok. Thanks, coolrda. Your build looks awesome by the way. I think I'm going to make my boxes just a little bit bigger than the listed dimensions. 14 deep, 14 wide and 33 high with a 1/4" dado groove all the way around the front panels, hopefully the speaker baffle just pop right in there.
I get 2.8 Ft3 total internal volume without subtracting driver, waveguide, or bracing volume. Will the added volume also be a negligible difference or should I cut it down a bit?
post #133 of 246 Old 02-12-2015, 04:17 PM - Thread Starter
coolrda's Avatar
Liked: 1503
Thanks. Yes, your fine with that size box. Your cabs will have an extended bottom. Looking forward to seeing your build.
post #134 of 246 Old 02-16-2015, 10:27 AM
Quoted: 224 Post(s)
Liked: 231
Did you happen to get some measurements for the spacing on the bracing? I'm going to build my boxes before the kits get here and will cut dado groves for each of the braces. I'm wondering what height to put the braces at for the woofers and also the spacing for the waveguide.
post #135 of 246 Old 02-17-2015, 12:14 PM - Thread Starter
coolrda's Avatar
Liked: 1503
I don't have the measurement. What I did was place the center two braces with baffle laying in place, then placed next braces equidistance between bottom and brace and top and brace if that makes sense. If you have the waveguide cutout dims, just add a little to that. Ryan or Erich should have those on request.
post #136 of 246 Old 03-29-2015, 08:04 PM
genofive0's Avatar
Quoted: 32 Post(s)
Liked: 32
Just purchased 3 of these for my LCR for my current theater build. Cant wait for them to arrive... along with my 4 volt surrounds..
genofive0 is offline
post #137 of 246 Old 03-30-2015, 04:53 AM
pbc
pbc's Avatar
Quoted: 437 Post(s)
Liked: 217
Making your own boxes?
pbc is offline
post #138 of 246 Old 03-30-2015, 05:02 AM
genofive0's Avatar
Quoted: 32 Post(s)
Liked: 32
For thr cinema 10s yes I am building my own for the volts I bought the flat packs
post #139 of 246 Old 06-07-2015, 08:46 AM
vondoom88's Avatar
Liked: 3
Coolrda,
I'm really liking your screen setup! Do you have a build thread on the theater itself? I tried searching but nothing came up.
Display: Panasonic PT-AE8000U/Schneider Cine-Digitar 1.33x A-Lens/Carada 120" 2.35:1 Criterion w/BW
Sources: Oppo 103D/ PS3/PS4/Audio-Technica AT-LP120
Audio: Denon AVR-4310ci/Emotiva XPA-5/ Def Tech BP-2004TL/ CLR-2002/BP2x/Mirage BPS-400
vondoom88 is offline
post #140 of 246 Old 06-07-2015, 09:11 AM - Thread Starter
coolrda's Avatar
Liked: 1503
Originally Posted by vondoom88 View Post
Coolrda,
Thank you. Not yet for two reasons. Haven't had time and and its very time consuming. I've started getting one together though with links to each of the DIY components.
post #141 of 246 Old 06-07-2015, 09:17 AM
vondoom88's Avatar
Liked: 3
Cool looking forward to it!
post #142 of 246 Old 06-07-2015, 05:37 PM - Thread Starter
coolrda's Avatar
Liked: 1503
With the center covering eighty percent of the program its appearing like I'll need to address this MBM thing at some point this year, after all other speaker builds are done. @EricH and company and anyone have any suggestions on a good match in a 1-2 driver arrayx2, one per each side of my center? Keep in mind the height and depth limits and DIY only of course.
post #143 of 246 Old 06-07-2015, 06:41 PM
Liked: 2225
Need more midbass? Or are you distorting the speaker? Have you seen my thread in the DIYsoundgroup forum: https://www.avsforum.com/#/forumsite/...1934809?page=1
post #144 of 246 Old 06-07-2015, 06:57 PM - Thread Starter
coolrda's Avatar
Liked: 1503
Hi Tux, no on distortion. I don't think I could if I tried to distort it, its that strong plus the small room. Would just like to fill the 60/80-200hz a little better. The problem is the position in the room with the center being mid wall in both height and width. Not getting the reinforcement that the L&R are getting. The L&R to subs are fine with the corner loading. Center is pretty good but I want great. With play with the transition between the C10max and the subs more. I'm making some adjustments to the baffle wall this month and its made a difference over not having it so far. This speaker has really come along nicely.
post #145 of 246 Old 06-07-2015, 07:40 PM
Liked: 2225
Oh I see. Ya, I've found that in a lot of systems where the center has a very different modal behavior from the L&R. Often in the opposite way to you, where the near by sideways create a big suck out that is impossible to fix. MBMs are a great option.
post #146 of 246 Old 06-07-2015, 09:55 PM - Thread Starter
coolrda's Avatar
Liked: 1503
I'll check it out. Is this the right link?
post #147 of 246 Old 06-07-2015, 10:00 PM
Liked: 2225
Link works for me, but I'm on my phone. Maybe that goofs it up. It's under the vendor forums.
post #148 of 246 Old 06-08-2015, 01:53 AM - Thread Starter
coolrda's Avatar
Liked: 1503
Your link takes me to the front page of AVS. I found the MBM thread your referring to here Tux's MBM Thread
post #149 of 246 Old 07-10-2015, 09:53 AM
lemonslush's Avatar
Quoted: 835 Post(s)
Liked: 424
anyone compare these the the PSA 210's?
Did I already ask this questions :-)? Im getting old.
lemonslush is offline
post #150 of 246 Old 07-11-2015, 05:04 AM
frankie2075's Avatar
Quoted: 469 Post(s)
Liked: 115
I'm still waiting for videos? lol
frankie2075 is online now
