iNuke 3000 dsp issue - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Pain Infliction
post #1 of 10 Old 12-28-2014, 11:31 AM - Thread Starter
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
It seems that it developed a nasty hum. Input A is worse than B, but both have it. I tried different cables, unplugged from the receiver, nothing helped. It only goes away when nothing is inserted into the input in the back. Could it be the power supply? Anybody have an idea what it could be?
SvtFoci is offline
post #2 of 10 Old 12-28-2014, 11:42 AM
Pain Infliction's Avatar
Quoted: 980 Post(s)
Liked: 515
Ground loop issue. Run a grounding wire from your avr chassis to the chassis of the inuke amp and the hum should go away.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #3 of 10 Old 12-28-2014, 12:05 PM - Thread Starter
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
WTH, that was exactly the issue. Makes no sense since I've had the system for months now, and the issue just appeared last night.
SvtFoci is offline
post #4 of 10 Old 12-28-2014, 12:13 PM
Quoted: 980 Post(s)
Liked: 515
Anything new in your system?
post #5 of 10 Old 12-28-2014, 12:25 PM - Thread Starter
SvtFoci's Avatar
Quoted: 30 Post(s)
Liked: 24
No
SvtFoci is offline
post #6 of 10 Old 12-28-2014, 03:26 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
A small shift in the cables caused my system to get a ground loop hum that became annoying. I had a slight hum and the tube amp/ subs were the problem. I finally brought this:
It solved the problem for around 6$.
derrickdj1 is offline
post #7 of 10 Old 12-28-2014, 03:31 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 276
I had a hum when my speaker wires were too close to the power cables.
Who needs 4K?... just go see your optometrist.
NODES is offline
post #8 of 10 Old 01-06-2015, 01:42 AM
Liked: 0
I have the same exact problem
I solved it by plugging the USB from the inuke into the usb channel of my receiver. 100% gone bit it aint pretty
How exactly would you do this? I assume that i am doing the same with the usb cord
Søren Bertram Pedersen is offline
post #9 of 10 Old 01-06-2015, 05:40 AM
Quoted: 980 Post(s)
Liked: 515
There should be a ground terminal on the back of your avr. Attach a wire to that and to a screw on the back of the inuke amp that is touching metal. They are grounded together at that point without seeing any wires. If no grounding block on the back of the avr, do the same with a screw just like the inuke amp.
OJ Bartley likes this.
post #10 of 10 Old 01-06-2015, 05:44 AM
Liked: 0
Got ya, thanks!
