1260s as MBM/Stands - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By rhodesj
  • 1 Post By Kazorb
post #1 of 16 Old 05-07-2015, 10:37 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
1260s as MBM/Stands
Due to the price drop recently, I have begun to rethink the idea of 2 1260s as the bottom of a three way setup. How high do you guys think these could play? My avrs low pass only goes to 200hz but I like what I heard and I thing these could work as a part of a 2.2 setup. Any advice?
manuetdeo is offline
post #2 of 16 Old 05-07-2015, 10:52 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
So if i go with a 2 cu.ft. net box with a single 4 in port at 25 hz I get 25ms wind speed, is that too high for this application?
post #3 of 16 Old 05-07-2015, 10:58 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Or I could go sealed as this would be strictly music only
post #4 of 16 Old 05-07-2015, 04:25 PM
A9X-308's Avatar
Quoted: 1792 Post(s)
Liked: 1483
I doubt anyone's used them as an proper midbass, so you'll need to measure for yourself.
A9X-308 is offline
post #5 of 16 Old 05-08-2015, 04:13 AM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
1260s as MBM/Stands
I posted measurements of one of my 1260w subs in the More on Inductance thread. Here's the FR graph. This is in a 38.6 L sealed box. Note that the FR has a big peak around 60 Hz and is down something like 9 dB by 200Hz. Doesn't really seem like a good choice as a woofer in a 3-way. I'm still happy with my pair as bedroom subs, but I did have to heavily EQ them.
LTD02 and More is Better like this.
rhodesj is offline
post #6 of 16 Old 05-08-2015, 08:42 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Thanks for that, @rhodesj . I guess then my stand idea as a 2.2 setup may be where I'm heading. I can still low pass at around 150 and have the mid play down to 100 or so.
post #7 of 16 Old 05-08-2015, 05:26 PM
Quoted: 17 Post(s)
Liked: 662
How close to the cone did you place the mic to get such smooth response?
andyc56 is online now
post #8 of 16 Old 05-09-2015, 12:41 PM
rhodesj's Avatar
Liked: 600
Half an inch or so.
rhodesj is offline
post #9 of 16 Old 05-10-2015, 04:43 AM
Quoted: 566 Post(s)
Liked: 64
I recommend that you read Wayne Parham's flanking sub(s) approach. It's been a while since I read it but this seems to be a great choice when building a music not setup.
Tip24/96 is offline
post #10 of 16 Old 05-10-2015, 04:19 PM
jjgear's Avatar
Quoted: 16 Post(s)
Where are you finding the drivers for cheap?
jjgear is offline
post #11 of 16 Old 05-30-2015, 09:55 PM
Liked: 3
Originally Posted by manuetdeo View Post
Thanks for that, @rhodesj. I guess then my stand idea as a 2.2 setup may be where I'm heading. I can still low pass at around 150 and have the mid play down to 100 or so.
Did you go forward with your plan??
I am also starting a MBM build / experiment. I have 3 1262w, each will be in a sealed 1.5 cu ft box used as stands for the LCR mains.
They will be powered by one channel on Inuke 6000dsp, wired parallel/series to 6 ohm.
Just using for 50 to 150 range, I'm good in the below 50 department with my other subs.
Maybe I am wasting my time, maybe they will work great as cheap DIY MBMs.
Good Luck!
Boomassiv likes this.
Kazorb is offline
post #12 of 16 Old 06-04-2015, 08:19 AM - Thread Starter
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Good Luck!
No, it is in a holding pattern right now as I am completely swamped with work.
post #13 of 16 Old 06-04-2015, 12:25 PM
Liked: 3
I hear you, my 3 boxes are almost done but going really slow because of work and family.
Kazorb is offline
post #14 of 16 Old 06-04-2015, 01:01 PM
LTD02's Avatar
Quoted: 2920 Post(s)
Liked: 3626
@rhodesj
nice measurement. that one will get referenced quite a bit.
Listen. It's All Good.
LTD02 is offline
post #15 of 16 Old 06-04-2015, 05:09 PM
Boomassiv's Avatar
Quoted: 130 Post(s)
Liked: 53
Good Luck!
Let us know how that works.
Boomassiv is offline
post #16 of 16 Old 06-04-2015, 06:29 PM
LTD02's Avatar
Liked: 3626
just an fyi, something like the pa-460 would be a better choice for a mbm. the increase in sensitivity provides 10db+ per watt which then translates into higher spl with less compression.
LTD02 is offline
