TritSub 10 - A modest 10" HT subwoofer design - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By the-jessman
post #1 of 7 Old 08-17-2015, 10:53 PM - Thread Starter
the-jessman's Avatar
Quoted: 30 Post(s)
Liked: 55
So here is a subwoofer design I've been working on for a while. Its a modestly sized 10" sub enclosure that should work well with several different subs.
First off, here are some pics:
The goals of this system were to get as much performance from a ported 10" sub as possible while keeping the size of the enclosure reasonable. I wanted something that would have good output to the low 20's, but had a narrow enough profile I could hide it easily. Here are the specs of the enclosure:
Net volume: 2.0 Cubic feet
Tuning: 23 Hz
Port Area: 19.7 sq
External Dimensions: 12" W x 21.25" H x 24.75" D
External Volume: 3.65 Cubic Feet
Sub drivers that should work:
JBL GTO1014 (This is what I used)
Dayton UM10-22
Dayton RSS265HF
Infinity 1060W/1062W
Here is what it does:
This measurement was taken at 10 feet with 6.3 volts of input power and 1/12 octave smoothing. It should be very close to a 1W/1M measurement.
If anyone would be interested in building one for themselves it takes a little over 1/2 sheet of 3/4" plywood.
The cutlist is as follows:
Sides x 2 - 21.25 x 24.75
Top/Bottom x 2 - 10.5 x 24.75
Front x 1 - 10.5 x 17.875
Front doubler x 1 - 10.5 x 17.125
Back x 1 - 10.5 x 19.75
Lower port x 1 - 10.5 x 21.375
Upper port x 1 - 10.5 x 15.375
Braces x 2 - 10.5 x 2
This is the internal layout:
The port is 1.875" tall.
Here are some pics from the construction of mine:
I didn't get a picture of it, but the inside of the box is lined with felt. I rounded over the ends of the port panels and put a 1" roundover on the port mouth.
LTD02 likes this.
"Nothing prevents people from knowing the truth more than the belief they already know it."
"Making bass is easy, making music is the hard part!"
My Audio Facebook page - http://www.facebook.com/triticumaudio
Instagram: http://instagram.com/triticumaudio
the-jessman is offline
post #2 of 7 Old 08-17-2015, 11:10 PM
LTD02's Avatar
Quoted: 3003 Post(s)
Liked: 3765
nice build.
with respect to your measurement. that is with no filters (eq/shelf/high or low pass), right? spl seems high. was it indoors?
Listen. It's All Good.
LTD02 is offline
post #3 of 7 Old 08-17-2015, 11:20 PM - Thread Starter
Quoted: 30 Post(s)
Liked: 55
Measurement was with no filters and was taken outdoors. Closest building was over 50 feet away.
I agree that it seems a bit high, it could be something in my measurement setup, but I'm not sure what it would be. I had my volt meter hooked up during the test and voltage stayed right around 6.3 volts (+/- .2 volts) during the whole sweep.
The mic I'm using is a Dayton UMM-6 w/ calibration file.
post #4 of 7 Old 08-18-2015, 12:41 AM
LTD02's Avatar
Liked: 3765
is my eye seeing a small roundover on the baffle around the driver?
LTD02 is offline
post #5 of 7 Old 08-18-2015, 07:21 AM - Thread Starter
Quoted: 30 Post(s)
Liked: 55
Yes you are
post #6 of 7 Old 08-18-2015, 10:37 AM
Quoted: 1331 Post(s)
Liked: 2255
Nice build!
Your chart indicates an F6 of around 20Hz so you achieved what you wanted. Throwing this one on my favorites file in case I want to add behind the couch subs.
18Hurts is online now
post #7 of 7 Old 08-18-2015, 10:44 AM
dtsdig's Avatar
Quoted: 1135 Post(s)
Liked: 1400
That looks pretty familiar! Very nice build!
Mine uses a 10" Ultimax and is also 2 cu ft. Tuned to 23-24Hz.
dtsdig is online now
