My 1099 Build - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 4 Post By mlah384
  • 2 Post By cesar123
  • 1 Post By Burrell
post #1 of 9 Old 08-19-2015, 07:24 PM - Thread Starter
mlah384's Avatar
Quoted: 502 Post(s)
Liked: 229
My 1099 Build
I did this 1099 build a year ago. I ran across the pictures so I decided to post them in case it helps anyone. Although, it looks like I lost some pics!
Before I started this project, I made a feeble attempt in SketchUp to see what would fit on my wall. I wanted a killer Media room, but wasnt sure what would fit. I figured out that two Mini-Marty's would fit leaving enough room for a small AV cabinet/rack in between. I could then use the Mini-Marty's as stands for the 1099's... here is my noob sketchup (Don't LOL!):
The 1099's arrived extremely well packed. @EricH does an awesome job packaging the kits!
The CNC on these kits is totally awesome. So clean! (makes me want a CNC machine!)
Using a right angle, I went ahead and drew a line up each side panel so I could accurately place the internal partitions when it came time to glue them in place:
I assembled using wood glue (titebond II I think! or Gorilla wood glue.. both are good). I usually use a nail gun but these CNC kits are so perfect all you need are clamps:
After the glue was dry, i removed clamps and placed front baffle on the enclosure to see what this beauty was gonna look like! Also in this pic, you can see some of Erich's fine packing skills in the top right corner of pic!:
Unfortunately I can't find the pics of the center speaker but here are the Right and Left side by side (baffle not glued yet, it's just sitting on box so I can see them!):
I paid @mtg90 to assemble the crossovers for me since he has so much experience with them and he offers a killer deal! They were beautiful!:
I used Velcro to mount the crossovers in the center chamber:
I bought acoustic foam off eBay to line the outer chambers. The foam was really nice. I didnt glue it in yet, but I cut them all to perfect size. I wanted to glue the front baffle on first so I could make sure all seams were sealed. I glued the foam in after front baffle was installed. I used spray adhesive from Lowes or HomeDepot. Make sure you drill your speaker wire holes first! You don't want to have the foam wrap around your drill bit!:
In this pic you can see where I made sure there was room for ports! You don't want to block the port's airflow:
I glued the front baffles on. (More clamp porn!):
After they dried I removed clamps and started preping for finishing. I used Duratex. Unfortunately I can't find my pics of the Duratex application either! That's what I get for waiting a year to post my build thread!
I use a speaker terminal cup from PE. I used a router to flush mount it in the box. (again, no damn pics! argggg)
I used black paint for speaker holes and terminal hole. Then I duratex'd all the rest. I did 3 coats of duratex. If you use the 9" roller it's easier to avoid roller lines since the enclosure is narrow!
I put them on my Mini-Marty's as stands!
These things sound AWESOME. After a year, they are definitely broken in and sound better. I have a Denon 4520 powering them. On Bluray movies it's hard to turn it louder than -4dbs or so, they get extremely loud. With the 2 mini marty's, really anything louder than -10db on a Bluray gets ridiculous.
These 1099's are probably the best sounding speakers I've heard in a LONG time. They sound equivalent to my brother's old Whispers (if not better on some things), however the Whispers had killer mid bass with those 15" drivers! Pic:
My setup sounds better to me, not only because it's mine!, but because these 1099's are so damn good, in addition to the superior subwoofer system as well. I think I will try adding the mid bass modules next...
mlah384 is offline
post #2 of 9 Old 08-20-2015, 06:35 AM
LTD02's Avatar
Quoted: 2954 Post(s)
Liked: 3685
awesome!
it is always tough to know if that killer midbass you are hearing is simply an spl thing, an eq thing, or something else as may be the case with the open baffle woofers on the whispers. the 1099's have a gentle rolloff in the bass iirc whereas the whispers may be a little flatter, so in room you get a little bump with the whispers. if you can give your 1099's a bump around 70-100hz, you may get some of the same effect assuming all else is good.
Listen. It's All Good.
LTD02 is offline
post #3 of 9 Old 08-20-2015, 07:02 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
Look great. I agree with LTD02 also. I you wanna jack up the eq go for it. They can handle it.
tuxedocivic is offline
post #4 of 9 Old 08-20-2015, 07:34 AM
cesar123's Avatar
Quoted: 390 Post(s)
Liked: 579
If you scroll up and down really fast, the egg crate foam makes you dizzy
Oh, this is an awesome build! Those 1099 look sick. Jealous guy right here!
brazensol and k1n3t1k like this.
Yippee-ki-yay...
cesar123 is online now
post #5 of 9 Old 08-20-2015, 09:53 AM - Thread Starter
mlah384's Avatar
Quoted: 502 Post(s)
Liked: 229
awesome!
Yeah, I need to spend some time with REW. So far all I have done is run Audyssey. I'm sure I need to tweak some more. It definitely could use some more midbass. My room has 12ft ceilings and is open concept into kitchen, dining room, breakfast room, and foyer; so my space might be killing the midbass. I'm debating on building the new MBM's from diysg. I might turn my mini martys vertical and place the MBM's on floor as stands for the 1099's. Not sure if that will work or not.. I'd have to measure the space on that wall, it's already packed! I might have to wait until we get our next house and have a dedicated room.
I also forgot to mention that I packed the center chamber with polyfil.
I put the gaskets on the box instead of the drivers.
mlah384 is offline
post #6 of 9 Old 08-20-2015, 09:56 AM - Thread Starter
mlah384's Avatar
Quoted: 502 Post(s)
Liked: 229
LOL... yeah, i noticed that right after I posted! Was kinda fun!
Thanks cesar123!
mlah384 is offline
post #7 of 9 Old 09-04-2015, 03:19 PM
frankie2075's Avatar
Quoted: 473 Post(s)
Liked: 115
Very cool! Can't wait to get mine and start building!
frankie2075 is offline
post #8 of 9 Old 09-05-2015, 10:08 AM
brazensol's Avatar
Quoted: 751 Post(s)
Liked: 572
I spent more time on that than I'd care to admit!
brazensol is online now
post #9 of 9 Old 06-19-2017, 06:30 AM
Burrell's Avatar
Liked: 1
Cant wait to hear these in person!
They look great!
mlah384 likes this.
Burrell is offline
