Johnnysub rew - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-28-2015, 06:22 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
Johnnysub rew
Hi I'm starting to mess with rew and make sense of this graph, any input? or a place to start?
thanks
Name:	multeq xt off.jpg
Landshark77 is offline
post #2 of 15 Old 08-28-2015, 06:36 PM
LTD02's Avatar
Quoted: 2954 Post(s)
Liked: 3685
if you pull the peak down around 45hz a little, it may not 'boom' quite as much.
the 25hz peak is probably fine. a little extra fun for movies.
its not that bad of a response.
Listen. It's All Good.
LTD02 is offline
post #3 of 15 Old 08-28-2015, 06:40 PM
LTD02's Avatar
Liked: 3685
also, if possible, experiment with some placements/rotations etc. aiming it about a half a foot from the wall may eliminate some of those cancellations. it is tough to make a suggestion without knowing the room...
LTD02 is offline
post #4 of 15 Old 08-28-2015, 06:44 PM
corradizo's Avatar
Quoted: 1537 Post(s)
Liked: 1598
A couple of questions:
Have you read and followed AustinGerry's 109 page guide? If not, it's a must.
Is that a single measurement or an average response? I'd take a measurement a foot in each direction around where you plan to sit and then hit the all spl graph button, then hit the average button in that window and eq that average measurement.
corradizo is offline
post #5 of 15 Old 08-28-2015, 06:59 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
Why aren't the hz under 25 registering? When I see other rew charts it seems that the dbs for hz start under 20.
post #6 of 15 Old 08-28-2015, 07:02 PM
LTD02's Avatar
Liked: 3685
what driver are you using?
LTD02 is offline
post #7 of 15 Old 08-28-2015, 07:02 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
Found the guide.
Also its a single measurement, thanks ill take the suggestion of different mic positions.
post #8 of 15 Old 08-28-2015, 07:03 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
si ht18d4
post #9 of 15 Old 08-28-2015, 07:22 PM
corradizo's Avatar
Liked: 1598
For reference it can be downloaded here:
https://www.avsforum.com/forum/91-aud...-graphs-3.html
Post 275
Not sure it's a sticky anywhere.
Once done with that, if you have multiple subs or want to best integrate your mains with your subs read up on mgt90's thread/guide here:
https://www.avsforum.com/forum/155-di...ow-thread.html
Pete
post #10 of 15 Old 08-28-2015, 09:46 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
Here is a view of the subs placement in room, it is against the back wall
Name:	Screen Shot 2015-07-30 at 7.18.34 PM.png
post #11 of 15 Old 08-29-2015, 02:12 AM
Augerhandle's Avatar
Quoted: 1249 Post(s)
Liked: 1250
thanks
Attachment 912994
Just for giggles, switch your phase 180 degrees, and take another sweep.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #12 of 15 Old 08-29-2015, 06:02 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
I'd also like to run sweeps at a higher db, but the mic clips at 85+/-. How can I raise the mic threshold and run sweeps around 95db. Maybe this will give me a better idea of the lower hz (under 25)?
post #13 of 15 Old 08-29-2015, 06:04 AM
corradizo's Avatar
Liked: 1598
post #14 of 15 Old 08-29-2015, 06:12 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
What mic are you using? the AG guide has the info in there.
Umik-1, he has it for windows but not mac
post #15 of 15 Old 08-29-2015, 09:01 AM
corradizo's Avatar
Liked: 1598
What is this "mac" you speak of?
J/K. I don't know how to adjust the mic levels in a Mac sorry.
